Featherweight Database
Id like to ask if youd all like to start this
topic by putting your robots (featherweight) name and details up here...
Ill start off:
Robot- Micro-Maul
Speed- 20mph
Power- 1x ni-mh 3300mah 14.4v batt-pack
Drive- 2x 12v drill motors (150watt each)
Weapon- 4 bar lifter, lifts in 1/2 a second
Aromour- 6mm-12mm polycarbonate with 2.2mm titanium
Cheers, Ewan :)
Robot - Storm Vortex
Speed - 6 mph
Power - 2 x 12v NiCad packs
Drive - 2 x 35w Bosch Motors
Weapon - 3Kg Disk, 4000rpm, S280-150 Magmotor
Armour - 10mm 2014T Aluminium
Robot - Alpha
Speed - 15mph
Power - 24v 3Ah NiCads
Drive - Gold Motors with Direct Gear reduction
Weapon - Spikes
Armour - 4mm SSteel scoop, 6mm poly and 4mm ali on sides
http://www.blazerbotics.co.ukwww.blazerbotics.co.uk
Robot - TKM2
Speed - Over 20mph
Power - 14.4v 3Ah NiMH which is not enough
Weapon - Compressor driven flipper
Armour - 8mm T6 Ali front, steel box frame with poly infill.
+ overweight so some work to do over Winter.
Robot - Wizard
Speed - 7mph
Drive - 2x bosch 35w motors, with a 3.5:1 reduction
Weapon - co2 flipper
Armour - 6mm polly
Robot - Venom
Speed - Never Measured
Power - 24v 3AH NiMH
Drive - 2x Gold motor with a 10:1 worm reduction
Weapon - Crusher
Armour - 3.2mm - 1.5mm Hardened Steel
Robot-Scorpion Jr.
Speed-20 MPH +/-
Power-2x12V 3AH NiMH
Drive-2x Gold motor @ 4.5:1 ratio
Controller-Vantec RDFR 23
Weapon-200mm dia. 2.5Kg 3500RPM disc
Armour 6mm polly
Minimoth
Speed: 12mph
Power: 3x 8.4v NiMH (25.2v)
Drive: 2x PML GPM12s (Modified) 110w
Traction: 6x Guitel 100x32 Blue Resilex
Controller: Make Robotics Feather01 (Prototype)
Weapon: Full Pressure Flipper
Armour: Titanium/ Polycarbonate
Frequency: 40.985MHz
Status: Under Construction
Kane Aston
http://www.makerobotics.com/http://www.makerobotics.com/
Delta
Speed - 8mph
Power - 14.4v 3Ah
Drive - 35w Bosch Motor
Controller - Probably Electronize
Weapon - Flipper (powered by a 330kg force ram)
Armour - Poly/Ali
Status - Mock-up chassis in progress
Should be done for first event nxt Yr.
FlowRate
Speed: 14mph
Power: 1x 12v 3300mAh NiMH Pack
Drive: 2x 480watt motors via custom gear box
Controller: 2 x New Enhanced 30amp Electronize
Weapon: High flow rate low pressure 16bar Pneumatic Flipper
Armour: 3mm Titanium / 10mm Polycarbonate
Frequency: 40.805MHz
Status: Moving and flipping - but not battle Ready.
Stu
http://www.teamkat.co.ukhttp://www.teamkat.co.uk
Robot - Conundrum
Speed - Unknown
Power - x2 12v 3Ah NiCads / x1 12v 2.2Ah SLA
Drive - x2 14.4v Drill Motors
Controller - x2 30A Electronize Controllers
Weapon - Spinning Drum
Armour - 3mm T6 Ali / 6mm MDF
Frequency - 40.875MHz
Status - Ready And Waiting
______________________________
Chris Levick
http://www.featherweights.org/forum
Robot - BEAM aka the bull
Weight- 12kgs
Speed - Unknown
Power - 2x 2.8ah slas
Drive - 2x gold motors running on 5/1 reduction
Controller - 2x 15A cpu Electronize Controllers
Weapon - steel spikes
Armour- 1mm mild steel
Robot: Dark carrot
Weight: 12kgs
Speed: 15mph
Power: 24v or 20v nicad 1.8ah
Drive: Powerdevil 18v cordless
Controller: 2x 4QD ncc35-24, quazar interface
Weapon: 40x115 ram sodatream 10/12 bar flipper
Armour: none
Status: undergoing weight loss to allow for armour
Robot: Hellbringer
Weight: 12kgs
Speed: 4 km/hr
Power: 12V 7Ah SLA
Drive: Windscreen wiper motors
Controller: Home made pic based relay controller
Weapon: Modular; Solid Steel Scoop, Fixed Hatchet (thwack-bot), Circular Saw
Armour: 3mm Perspex (ploycarb soon)
Status: Going to add a crushing arm soon. Oh, were Australian. http://www.abbl.orghttp://www.abbl.org
Robot ......Stiff Breeze
Speed .....15-20 MPH
Power ......24v 3Ah Ni-Cad
Drive .......2x 12v Gold motors,six wheel drive
Controllers.GT Electronics H6
Weapon ....Rambot
Armour .....2-3mm Stainless steel
Status ......Bag of bits
Robot: Super Dinky
Weight: 2kg
Speed: 20mph
Power: 18volt NiCads
Drive: 2 x 9v drill motors
Controller: Secret!
Weapon: spinning disk (lesson learnt from Dinky)
Armour: Duarlium/Titanium/Gaffer composite (Tafffium)
Status: Being buildeded now Dinkys dead.
oh, hes got 12kg friends too, but youll have to wait for them
Robot - Over Bite
Weight - 12Kg
Speed - Unknown
Power - Havent decided yet
Drive - 2 x 12V Drill Motors
Controler - 2 x 30A Electronise
Weapon - Grabbing/Crushing Jaw
Armour - Havent decided
Status - In the build.
This database is looking good, anyway, Jas I know that you are looking for a linear actuator but I might aswell say this here aswell (I have put this message in in the featherweights.org forum aswell)
anyway...
email me for more info but heres the main specs on my actuator:
Weight: 2kg (ish)
Speed: 5mm per second @ 24v can be run at 12v or 36v though
Force: 400kg push/pull Average, can get to 800kg...
All this for only 25 pounds (this includes p&p!)
Cheers, Ewan
Swear your in competition with Technobots with all your batteries, motors, videos, toys, anything else robot related for sale. :)
Stu
I buy, I sell most of the time I make a profit...
Robot -....... DTK
Speed - .......10MPH APROX
Power - .......19.2 VOLT NIMH
Drive - .......2X BOSH 35W MOTORS
Controller -.. 2X H5,S
Weapon - ......10/16+ BAR PNEUMATIC FLIPER
Armour - ......CARBON FIBER / KEVLAR
Frequency - ..40.985
Status - ......RE WORKING WEPON SYSTEM
Robot....... RIP
Speed - .......12MPH
Power - .......14.4 VOLT NICADS
Drive - .......2X DRILL MOTORS
Weapon - ......10 BAR FLIPPER
Armour - ......ALL TITANIUM
Frequency - ..40.785
Status - ......BENT, AND TIRED AFTER MR SYCO BULLIED IT BUT STILL WORKING WELL
Robot: CBF
Power: 2 x 12V SLAs
Drive: 2 x 24V Gold Motors
Armour: 5mm Polycarbonate and 2mm Titanium
Status: Transmission Rebuild
Robot - Rebel
Speed - N/A
Power - x1 14.4v nicads
Drive - x2 24v golds
Controller - x2 15A Electronize Controllers
Weapon - CO2 powered Flipper
Armour - Polycarb and Ali
Frequency - 40.685MHz
Robot....... G2 (or is it Cheese 2?)
Speed - .......7mph
Power - .......22v nicads
Drive - .......Wiper motors
Weapon - ......140psi co2 flipper
Armour - ......4mm ali and 6mm polly
Status - ......Just ready to fight after RW
Definatly Cheese 2
Cheese boy
Robot....... microCHIP
Speed - .......18mph
Power - .......24v 1.8Ah NICADS
Drive - .......18v Goldmotors 5:1 gearbox
Weapon - ......LINAK crusher/lifter
Armour - ......2mm Ti on 4mm Polycarb
Status - ......Working OK, under test.
and
Robot....... BlacknBlue
Speed - .......5mph
Power - .......24v 3.3Ah NiMH
Weapon - ......45cm dia vertical spinning blade
Armour - ......3mm Ti and 6mm Polycarb
Status - ......semi-retired, on the mantlepiece
Robot - Bitchslap
Speed - Unknown
Drive - x2 24v Drill Motors
Controller -30A Electronize Controllers
Weapon - 44cm ali plate
Armour - 2mm ali/2mm poly
status - give me a event and Ill show you a bot.
Robot - Thuggernought
Speed - slow controlled crawl
Power - x2 12v 2Ah NiCads
Drive - x2 24v Gold Motors
Controller -relays
Weapon - poor control
Armour - 2mm ali/2mmpoly/3mm steel
Status - beginning major rebuild
stu,when are you going to update the featherweights.org database?
Whirlwind 3Volution is no more,
make way for its successor...........
Whirlwind 3Volution MkII
Robot - Whirlwind 3Volution MkII
Speed - approx 6-10 mph
Power - 7.2V 2000MaH nicads
Drive - 2x 6v r/c car motors(overvolted)
Controller - custom made
Weapons - 4x case hardened steel ramming spikes,1 titanium spinning disc blade,removable front scoop/plough,removable anti crusher weapons cage,removable Windcutter weapon system(can be combined with the scoop or the blade or the spikes to give better weapons
Armour - Polycarb and kevlar
Frequency - 40.680 Mhz
(starts to laugh evilly to himself over its potential):wink:
well amybe if you let us know about ur changes we can do something about it. And maybe somre updated pictures about it also. And how do we know that your robot is no more etc? In all hoensty, ive never seen it any even apart from RW in Extreme Series 2, so how are we supposed to know mate.
Regards,
Stu
Robot - screwed
Speed - 13mph
Power - 12v 7Ah SLA
Drive - 2x9.6v drills @ 12v with 150mm wheels
Controller - custom made microswitch boards
Weapon - spinner killer plough and wedge
Armour - 6mm lexan, 2&3mm aluminium and 4mm steel
Status - retired after wooden motor mounts broke
Robot - So Screwed
Speed - 13mph
Power - 12v 7Ah SLA
Controller - oatley electronics 60amp PWM ESCs
Weapon - thwack spike 470mm from center at 50km/h
Frame - 20x20x1.2 steel box section MIG welded
Armour - 6mm lexan and 3mm aluminium
Status - being built.
Robot....... STRIP
Power - .......12V 7AMP SLA
Weapon - ......NASTY 500MM SPINNING BLADE
Armour - ......STEEL
Status - ......BRAND NEW PROTOTYPE, TESTED AND OVER WEIGHT AT THE MOMENT. IF IT WORKS WELL THEN THERE WILL BE A NEW TITANIUM VERSION FOR 2004
Robot - Icklerus
Speed - 12MPH
Power - 2 x 12v 3ah Nicads
Drive - Drill Motors
Weapon - 80mm bore pneumatic flipper
Armour - ti, polycarb, aluminium
Controller - electronize
Status - Being Built
Robot....... STRIP (aka Tantrum 2 you idea robbin git!! :) kidn )
Power - .......12V NiCad
Armour - ......Titanium
Frequency - ..40.765
Robot - Trinity
Speed - top secret
Power - top secret
Drive - top secret
Weapon - top secret
Armour - Duralium/titanium
Controller - top secret
Status - awaiting gearboxes...... be afraid!
Robot - Whiplash
Speed - 8mph
Power - 14.4v Nicd
Weapon - 80mm bore pfull pressure pneumatic flipper
Armour - titanium/polycarb
Status - prototype works, need to get reliable bits made now (ie broke it!)
Robot - Tantrum
Speed - 30mph in theory
Power - 28.8v nicad
Drive - gold motors
Weapon - silly 500mm spinner
Armour - eh.... dammit, must write things down! none!
Status - Built, fought, banned, modified, close to retirement.
um..... thats it for now I think
oh, hang on
Robot - carnage (formally known as wrawhead)
Speed - 10mph
Power - top secret
Drive - top secret
Weapon - spinning dome
Armour - ti, aluminium
Status - Being held ransom.
James,
Reading through that lot, Im struck by one thought....You have far, far too much time on your hands!! :)
what ya on about.... its nothing like tantrum....
the disc is old neoterics, which was the 24kg walker in last years extreme, and when you see it.... you will notice the difference. :)
jonno
I know, I thought it was that one. I saw it at Ironbridge last year.
Just messing wiv ya because on paper its quite close.
too much time on my hands.... oh if only.
Too many projects not enough time.
Started a bloody 24kg walker now, and the others are still not all finished. One day Ill learn. At least Dinky is dead so I cant use that as an excuse not to finish another....
Gear boxes for Trinity arrived today, any heavyweights want a fight?
Hey, What weapon are you using for your featherweight walker?
Cheers, Ewan
James - Trinity a feather weight right?
Dont mind having a little play with Pussycat against it :proud:
Mr Stu
ok stu. do you want to run your disc? :)
Ewan, the walker has a vertical disk head, and an articulated crushing body.
