DX6i mixing modes
So, with these TX is there any way to set it up to perform tank drive => steering mode?
Basically got a couple of victors working on simple tank drive mode, but want to do the old L/R + F/R
Still have an old board that does the mixing + invert , but wondered if there was a way now to do it in the TX itself?
Do you basically want tank controls on one stick?
I'm not too familiar with the menu setup on these, but yeah there is an option somewhere for it. I think there's a 'Mixing' menu or sub menu you need to go into to select and set up mixing, but that's about as much as I can offer you I'm afraid. There'll probably be a manual for it online somewhere.
EDIT: Yeah just Google 'dx6i manual' and there are plenty of results. Had a quick look through and it looks like you need to go into the Wing Tail Mix option on the main menu, which then gives you V-Tail and Elevon mixing options.
Ta, will have a try later this week. I've got an old mixing board that has a flip mode setting but I'm starting to think about an arduino and using a tilt switch for "devolved autonomy" to flip the steering when upside down . It's certainly going to be getting a raspberry pi zero too but that's no good for timing reasons.
I've used a dx6i for years and wouldn't change. I've not had any issues with setting up any set ups I've needed. The built in mixing and other features are great I think without things getting too complicated.
Ok, i'm being dense i'm sure but I cant figure this out. How do you get the dx6i to mix? Itching to test the new ESCs :)
The way I did it was to basically mix each of the drive channels into each other. I don't know if this is the right way by any means. But basically, say you've got your left drive on the vertical axis of a stick and your right drive on the horizontal. You press the little scroll wheel in and move down to 'mix 1' and press it again. Then you should be able to select the channel you want to mix, and the channel you want to mix it into. You then just have to alter the throttle level for both (I think I set mine both to +100% or -100%) and then do the same on 'mix 2', but now you mix the channels the opposite way around. This basically means that when the regular action of the channel is added to the mixing input you've added, the output causes both drives to go forward when the stick is forward, and go in opposite directions when it's left or right.
Sorry if this explanation made no sense, I'm doing this from memory right now, and it's hard to put concisely into words. I'll do a video showing how I did it if nobody else can explain better.
Hi Rory,
Thanks for that, i'll give it a go tonight and let you know how I get on :)
Hi, ok I did what you suggested by programing the mix 1 and mix 2, but I also had to turn on the 'Elevon' on in the Wing Tail Mix menu. But by doing this, the top speed of the motors is reduced. what have I done wrong?
Hmm, I don't think I ever turned on Elevon mixing, but I think I have your solution. I believe it's because it's designed for mixing the elevons on an aircraft, so it tones the power down a bit.
https://youtu.be/6Ewa79_9Iq4
You have to turn the trim adjust up from 100% to 125%, works fine now :) Thanks!
Nothing.
Go to the endpoint settings and put aileron and elevator both on +125% and -125%
Hi all wondering if anyone can help me out, I've set mix 1 and 2 and it works but I've some how managed to get forward and reverse set up on the left and right of the stick and to turn left or right I have to move the stick up and down. I'm probably being a complete numpty but if anyone could help me out I would be very greatful.
Thanks, been a long day why I didn't try that I don't know.
Switched out the ESC's only thing it did was make it go forward pushing the stick left instead of right :(anymore help? Currently have it going forwards and backwards on moving stick left and right and turning on moving stick up and down.
mix 1 is aile - aile
mix 2 is elev - elve
trim active on both.
Pretty sure you need to do aile - elev and elev - aile, since you're basically mixing the action of one channel into another. Then work out your % values as needed to make the motors go the right way.
It's done! Kept my mix 1 and 2 the same and followed the instructions in the picture and it's worked a treat :) just need to work out now how to dile it down a bit as it's rapid lol
http://www.fightingrobots.co.uk/webk...a2e7b/imagepng
Look for a function in the transmitter menu called dual rates (or similar). It allows you to set two values that you can toggle between which can be used for reduced speed. So say with the switch off, you get 100% speed, then with the switch on, it limits the speed to 50% (as an example, this is adjustable). You can usually set different rates for different channels, I find it useful to reduce the left/right control more than the fwd/back control as it gives less erratic control when turning but still allows good straight line speed.
