Hi All
Does anyone have any sheets of 3.2 or 4mm 450 hardox they might want to move on
currently building my new heavy and require some more steel
any size above 500mm square considered
thanks
Hi All
thanks
We're planning a new group buy for a 6000*2500*3.2mm sheet.
A plate I could definitely still use, bring back to the next MMM, would be ideal! ;)
great keep me informed Mario please
anyone else have anything a little closer to tide me over
PM me with the confirmation.
At the moment , 14 sheets of 1*1.5m are to be divided, and 4 are already sure.
One thing.
We want to avoid the issue with the last sheet, that Jeroen payed for the full sheet, and it took a year before the last "buyer" payed for his order.
Price per sheet? Im interested
For the group buy I have 2 large sheets of 6x2,5m of 3.2mm Hardox 450 in mind, that will be plasma cut by hand into 20 sheets of 1x1,5m. I will remove the sharp edges with an angle grinder.
18 of them are already reserved including 2 for adz600 and 2 for Mattdragon.
The price per sheet is 102 Pounds (€137,50). (exclusing transport)
At the moment there are still 2 sheets for sale on a first come first serve base.
If there is a large request for them, then its possible to get larger basic sheets. But I have to know before wednesday.
The only problem might be transport from The Netherlands to the UK. The easiest would be to bring them to the first event that I can attend, which propably will be Portsmouth.
Adam and Matt, can you please send me a confirmation if you want the sheets that you reserved?
Thanx.
Ill take one
Email me david moulds 88 at hotmail.co. uk
Who is recieving them in the uk?
Jeroen, I will have the last sheet - pm me with the details.
Trev
Great 2 sheets - still I need a small 3.2mm piece within the next few weeks 300x300mm would do ?
pm if you might be able to help
All 20 sheets are spoken for and unfortunatly I might have to dissapoint someone as there is already a request for one more.
If there are more people interested in buying a sheet, we can get 28 sheets instead of 20, but for this I need reservations for atleast 3 more sheets (out of 7 available) before wednesday.
So are there maybe more people interested?
The price per sheet is 102 Pounds (€137,50). (excluding transport)
3.2mm Hardox 450, 1x1,5m
jeroem- did you get my latest PM about postage?
My appologies for the late reply.
Yes I got your PM, but I must still call some companies.
Just so you know, we can't always supply material to you due direct due to the size of our trucks and our sheet sizes being too big. We have found some Hardox customers in the past to lend a hand with offcuts for some of you but with H&S rules the way they are it is not always possible for them. You can always contact me at SSAB though, or through this forum, and I will try and help you out if I can.
