Hi all, need to ask the stupid question to make sure I have this down.
1. Inrunner means a powered shaft, outrunner means a powered outer can?
2. kv is how many rpm per volt the motor does?
3. Amps is how many amps it will pull at full chat?
4. Wattage is similar to any other motor, in that its volts x amps and therefore the max power it gives off regardless of can size?
Been looking at brushless motors for a planned beetle and whilst some manufacturers give you something like 2830, it's a 28mm can with 30mm shaft length, you can have two 2830's and one be double the power of the other depending on manufacturer. Other manufacturers don't even give you that you just get something like NT17 etc. So...to try and get round this I'm just looking to confirm the above so that if I select motors on Hobbyking etc. by size I can then compare the power outputs of the different models to get to where I wnat to be.
As ever any input with examples of what your using for feather vs beetle applications massively appreciated. (ie. what do the big feather spinners run vs the scary beetle spinners. What sort of wattage and kv do you look for. Pro's cons to inrunners and outrunners.
The info is scattered through a few different threads but want to get it all down in one place so I can refer back to it.
Thanks in advance as ever.
