I am not quite sure how to phrase the question so I will give the scenario.
I am looking at the following system in C3 as an upgrade in the future which I can design in.
Power: 2X 6S 2200mAh 40C Lipos in Series = 12S, 80C & 2200mAh capacity
Control: 1x Castle Creations Phoenix Edge 160 HV ESC (50V & 160A)
Motor: 1x Align 750MX 530Kv.
If my maths is right I can average 44A over a 3 minute fight and that would drain the batteries totally. Of course you can't actually use all the power in a pack due to voltage drop off.
So...
Is an average of 44A over 3 minutes even possible with a 2.9kg weapon?
(Runs on a 3:1 reduction giving (44.4*530)/3 = 7844 lossless)
And how many amps can I drain from the Lipos before I hit the 3.2V cut off built into the ESC?
The lipos would be these: http://electriflyer.co.uk/gens-ace-6...00mah-40c-new/
160A ESC from here: http://www.castlecreations.com/produ...x-edge-hv.html
