heavyweight wheel material for best grip
having trouble deciding on wheel material (best grip) and centre material, the ally ones have bearings which are great but would the ally crack ? here is the page ive been looking at.
http://www.castors.org.uk/160mm-c-4.html
all ideas muchly appriciated :)
Re: heavyweight wheel material for best grip
get the green ones, nobody else has green wheels! :proud:
:uhoh: I can think of one :mrgreen:
Have a look at bearing boys similar site might give you other options though. (just search on google)
yep they do have a few more, but im stuck as to what material will give best grip,
polyurethane, elastic rubber etc,
also im thinking of getting the wheels with 20mm bearings in so its less work
they mostly have aluminium hubs and im worried they will crack as they look cast ?
mind you though they are rated up to 800kgs sometimes so prob ok
this one looks good but not too cheep up too the job but not sure about grip
there is some more on the page below aswell.
http://www.rosscastors.co.uk/160mm-heav ... rings.html
just emailed these chaps as to best traction and centre type
https://www.technicawheels.co.uk/industrial-wheels
loads of good ones .
Have a look at this article, it might help you
http://www.thombert.com/white_papers/Po ... rTires.pdf
To be able to compare you have to know the durometer of the wheels you're comparing, as polyurethane hardness can vary over a wide range, but most probably being heavy duty wheels rated at 800kg, they will be of the hard type....
Hope this helps
http://i8.photobucket.com/albums/a49...psda90959c.jpg
that is a great help thanks, after comparing loads they are all nearly 70a so it dosent really mater which material, you would thing that if someone had listed an elastic rubber it would be grippier but not true, there discriptions are misleading and one of the polyurathane tyres i was looking at was 95a so i wont bother with that !
Been looking for some new wheels for bulldog myself so be interesting to see what you go for
These are the softest I've found in 6 diameter, at 50 shore A they look fine... but they're from the states so most probably not worth the hassle
http://www.castercity.com/eshop/10Expan ... wheels.htm
ratings:
http://www.castercity.com/caster-wheel- ... -chart.htm
