Re: Which would be better?
One of your options includes overvolting, the other doesn't. It's not difficult lol.
Buy a 4S LiPo pack. Cheapest solution I can see.
if you have the space you could always add these to the motors
http://www.ebay.co.uk/itm/Ansmann-Racin ... 3cc12b17cf
not sure how effective they will be
No space for additional fans so need to figure the best way of taking the strain out
This battery
combined with
Imax B6
Total pricetag. £ 35.97 +P&P
Cheaper than any other good solution for your overheating drives. And it will free a lot of weight and space for future upgrades.
Yes, the machine will be slower and will have less torque. But will run a lot more controled and with less maintenance problems.
I know I like the less maintenance situation. It's rather frustrating making emergency repairs during an event on a machine that didn't get any battledamage.
Indeed it is!
What about all the lipo safety bits as well?
You need a fuse which is safely below the peak of the pack, so around 100a for the battery Mario posted, though the lowest you think you can get away with is obviously advisable.
Such a fuse can be found on Technobots but is probably cheaper on Ebay. Something like this, you might save a a few pennies if you search deeper: http://www.ebay.co.uk/itm/2-X-100-AMP-1 ... 3f1b0ee5af
And a fuse holder, for example: http://www.ebay.co.uk/itm/Maxi-Blade-Fu ... 2ec1bce2c5
I'd also suggest a Lipo Alarm, though I don't think that's in the rules.
You need to mount it securely, though with shock absorption, and with at least 2mm of metal between it and the arena floor.
My only amendment is not to bother with a fuse holder, just solder it directly into the circuit and cover the terminals with electrical tape. Will save you about 80g and takes up less space.
Before I go buying, which would seem preferred? Upping the motor capacity or dropping the battery voltage?
Higher voltage motors running at their designed voltage often have more torque than lower voltage motors running at their designed voltage. So from that, you may be more interested in upping your motors. That said I imagine the difference in the arena will be negligible.
Also remember that you're never going to get super high performance if you're running (I assume) two NiMH packs in series. In effect a single pack's worth of discharge capacity is powering everything in the machine. Probably fine if all you have is two drive motors, but not much more.
Its just 2 drills right now, the next upgrade would be lipo
Scrap two of the wheels. Turning a 6wd machine is very tough as you have to skid 4 wheels. 4wd the turning stress is less.
6 wheels is fun though :lol:
