Best wheels ?
hi all been looking at wheels and tyres for what seems like forever and still unsure, looking to build my first heavy will be 2 wheel drive at rear, front mounted axe and hopefully some kind of grabbing jaws
2x high power scooter motors, 2 in consideration 750w and 100w both 36v, similar too tomahawks motors
wheels gearing should not be a problem as i am planning to use t8f chain which is used on small mopeds and large electric scooters etc has a good load capacity for size of around 670 lbs depending on grade.
here in lies the problem,
go kart wheels - wide lots of grip, heavy and requires lots of work to fit
10 inch faom filled barrow wheel - easy to fit and cheap, narrow tread ,plastic hub weak large od
heavy grade castors - cheap , strong, easy to fit, narrow tread
any ideas greatly welcome
thanks adam
Re: Best wheels ?
We make ours from ali bar and have Vulcalon bonded on, just means you can have whatever diameter and width of tyre you want.
Re: Best wheels ?
They all have their merits, I personally like kart wheels as they give a ton of grip, I shoved 4wd robots with my kart wheels but they are difficult to build into a design simply due to the size
Re: Best wheels ?
I'd get some strong castors like these:
http://www.bearingboys.co.uk/BZMH125WRN ... eel-8699-p
And then just double them up to increase the tread width. Cheap, light, strong, grippy and can't be punctured.
Re: Best wheels ?
while this thread is here i might as well ask what do everyone think is the best tyre material for grip, egc- rubber, polyeurathane ? want to get the grippiest available and must have bearings fitted.
Re: Best wheels ?
found some nice trolley wheels 260mm foam filled high grip and cheap £12 for 2
next question done some maths based on the motor rpm etc
max speed at proposed gearing is 13.56 mph with no losses
too quick or about wright ?????????????????????????????
Re: Best wheels ?
What motors, controllers, batteries are you using?
Re: Best wheels ?
1000 watt scooter motors
not sure on batts yet depends on available space and funds
probably ncc70
Re: Best wheels ?
I would gear abit lower, 4QDs aren't the smoothest of controllers, if its too fast you will struggle to drive it.
Re: Best wheels ?
would these 9amp 12volt batteries be ok, as they are quite light at 2.5kg each
Re: Best wheels ?
link? doubt it, its the current handling thats the issue, you will probably find they can only deliver 30-40amps. Even bigger SLAs like the 18ah (the size most used) will only deliver about 100amps. The only exception are Hawkers which will chuck out 500+amps, but your looking £100each.
Re: Best wheels ?
Re: Best wheels ?
The spade connector ain't a good sign. It says 100 amps, if you're lucky.
On the other hand, Gravity and TAN did, and do good on that type of battery (other brand tough).
Re: Best wheels ?
But is has Ultra Max written on the side! They've got to be good right?
I liked the idea of using hobby LiFePo packs in a HW, cheap, light and powerful.
Re: Best wheels ?
looking for a 2kg co2 bottle or there abouts, design changed to possible co2 axe or lifter bought the high flow reg thanks to ebay and WRANGLER, just waiting very happy should be great, any ideas ideally aluminium to save kgs
thanks adam
Re: Best wheels ?
2 x 1000w scooter motors
2x10 teeth 2x11 teeth sprockets
4x74 teeth sprockets
all orderd just deciding on wheels, and weapon
Re: Best wheels ?
4 large 260mm faom filled wheels ordered
will this co2 be ok not sure on size if to big,
http://www.ebay.co.uk/itm/221177181354? ... 1423.l2649
