What do people use to control their Burket valves?
Need to figure out something different for bulldog as it's not dumping the gas yet I figures it can just be scaled up
http://www.hobbyking.com/hobbyking/stor ... itch_.html
Cheap, light, failsafes and hasn't let me down yet.
[quote=mr_turbulence]http://www.hobbyking.com/hobbyking/s... <br /> Cheap,
We've been using Battleswitches in Mute, only done a few events but they seem fine
http://www.dimensionengineering.com/...s/battleswitch
Got them direct from states because we needed a couple but think you can get them from the UK, was a really good service from the states
Andy, my turnigy switch doesnt latch on as you describe, single action on or off.
Had nothing but problems with dimention engineering products... bec's esc's and i know many had troubles with there switches being intermitent and un-reliable.
Use them in Skyfall, never failed me. Been in use since Barnsley this year, still going strong as ever.Quote:
Originally Posted by team_mute
Only problems we found were when firing the flippers, sorted with a diode on the solenoid valve and haven't had any problems since, but like i said only fired it over the few battles we've had.
We used to use the team delta boards http://www.teamdelta.com/products/prod2.htm (think they were these, Daniel does all the elctronic stuff) worked a treat though
used battleswitch, would never use again.
don't like Battleswitch's far too sensitive and regularly mis-fire when you get a hard knock. The electronize ones were great but you cant get them at the moment. Team Delta ones from the states have always been good. A few people are using the Technobots ones without issue.
i use bot switches seem fine dont know if they caused some misfiring on arming up for the previous event , it didn't happen at deeside. dont get me started on burkerts though :!:
I had 3 spare kits for the champs just incase but didn't need any, maybe they are building them better.
matt are you going from lp to hp with 2 2kg buffers straight away :?: big increase you want some power then !
I'm going from FP no buffers to FP with buffers, power is what I'm after but a better way of controlling the valves aswell, the current system works but takes far to long to exaust so want something thats just on/of as it was before
