Gary's garage/shed clear out
Ok need to get some cash together for a housing deposit asap so whilst i'm going to regret having to let some of this stuff go, it's time to sell some stuff that's been in the I'll get around to doing something with it pile. Photos will follow in a couple days when I have access to the items in question.
-Vertical bulkheads and axle (as shown in other thread) - £100 and the whole assembly is yours
-Disc to go with bulkheads (solid tool steel disc, chamfered on the teeth in opposite directions and it has been surface hardened) - £150. Weight is around the 3 to 4kg mark
-Brand new still in the fancy tin brushless scorpion 4035-xxx (can't remember the exact kv number but it's around the 500 mark, will confirm later), retails at around £100. Yours for £80 (the motor fits the bulkheads perfectly too)
-A number (around 4) bosch 35w motors and integral gearboxes - £10 a piece
I will have more in the coming days once I actually have a right good look through and will get up some pictures. Might throw up some electronizes etc soon as well. All prices are excluding postage. Now I've been in the sport long enough to know what these parts are actually worth so please don't make me some rediculously low offer
Re: Gary's garage/shed clear out
Bosch 35w all gone subject to completion of sale
Do you have a picture of the disc and what is its maximum diameter?
https://fbcdn-sphotos-a.akamaihd.net/hp ... 1304_n.jpg
It's an older pic. Since that one was taken the teeth have been chamfered on opposite sides and it has been surface hardened. Diameter wise off the top of my head it's either 250 or 270mm diameter. I'll get an updated pic in the next couple of days.
Incidentally if someone wants to take the motor, bulkheads and disc i'm willing to throw in a discount
Ok got some pics
http://imgur.com/a/Hf0vK
Ignore the exhaust finisher unless you need a replacement for a peugeot RCZ :P
Other items there,
3 x 24v drill motors. These are big beefy motors, not been used in the arena in anger. They have seperate drive shafts so will need a bearing or similar to keep the shaft from sliding out however great potential for a powerful drive for a featherweight. £15 each or 3 for £40
1 x Norgen 15 bar ram. Specs are written on it. 100mm travel, 50mm bore. Comes with the two push connectors there. £25
2 x banebots orange wheels. Completely new and unmolested. 3-7/8 diameter (or 98mm), 20mm wide. Retail for £7 with sell for £5 a piece
1 x vapex 6v 3300mAh pack. Still to put a multimeter to it but believe it's still good. Only used in testing, never in the arena. £5
PM if interested. All items are plus postage.
Any chance of a discount if the bulkheads, disc, motor, drive motors (24V ones) and wheels were purchased together ? Also, what diameter are the shafts on the motors ? Just wondering if the banebot wheel adaptors would fit those motors.
Sure Dave, PM me and we can come to a deal
Shafts are 11.5mm diameter on the gearbox side
Are those the 24v motors and gearboxes I sold you a while back?
Yeah I think so. Haven't really been able to use them in anything. I'm sure there was 4 but wasn't able to find the other one when having a quick look.
what grade tool steel is the disc made from?
P20 if I remember right. Mind you, at 5000 rpm it doesn't matter. It's going to do the business
Bulkheads, disc and brushless are gone. All other parts are still up for grabs.
That's what I get for umming and arring about it.
Lol you would have been third in line Dave had you made your mind up!
