Originally Posted by widow_twanky
As the smoke from lipo's is toxic the answer is yes to both of these.
And is it more toxic than NiCD smoke, or even the smoke from burning insulation?
Lipo fires are rare and fuses will actually stop the vast majority of those which are thinking about happening. Consequences are quite high. When you do a risk assesment you have to balance the probability and the consequences.
I know. A part of my job too.
The fire is not sustained by the usual influences such as heat, fuel and oxygen. It is a chemical reaction which once started will not stop until it has finished doing its stuff.
Not true, any chemical reaction can be stopped.
For Lithium
Remove any oxygen -even in bound form- and the reaction stops.
Remove all heat- and that's difficult, as lithium will reduce CO2 to carbon and oxygen, generating even more heat-
Arenas by their very nature (contained boxes) are not easily ventilated so if it does happen the fumes hang around for a while. As they're full of heavy metals and stuff they're not nice and the 'poisonous' effect is cumulative.
That is why any containment is used for things like painting cars, working with radioactive materials and so on. It's called a ventilation system with filters....
The issue here to my mind is that there is a very small risk of this happening BUT if it does then there's no way of stopping a lipo fire until it's burnt itself out. You can put the remaining flames out after its finished but the initial fire will happen once started and each cell will go individually.
I think the testing will show that lipos can be used safely in a well constructed machine. I also think we need to test some of these to destruction to see how effective safety measures are by introducing heat, piercing some of them, exposure to shock etc etc.
We just need a budget for that.
And I suggest we test a worn out max-power pack (37V 20Ah ) in a thin HDPE foam filled box , lets see how fast that ignites
Also we need to get on top of how age and deterioration increases any risks etc. Over time the internal resistance increases which means the heat produced in every fight increases the risk of it happening. That being the case, how do you monitor that?
Rather simple, good chargers do it on their own.
With stringent rules these could be safe but more research needs to be done but we also need the plan of how to clear them up if they do go.
You can make the rules foolproof, but then mother nature will appoint a better fool.
