anyone got any contacts - ie used before?
cheers
cheers
We use one in Stoke-on-Trent on a regular basis when we need material cut, let me know if you want the details can post them when i'm in work
I use Draftek in Birmingham, they first did all the titanium chassis for Satans Mutt we did for gadget show. Mouldy has since used them aswell for the drum things.
cheers guys
We use DV METAL SERVICES in Burslem, Stoke-on-Trent Tel 01782 267444, speak to Ken
No kind of insider reduction but these guys cut the disc, lipo plates and motor mounts for conker. they seem to be quite a bit cheaper than the other 5-6 places i got quotes from.
http://www.yorkshireprofiles.co.uk/
hope thats useful
I've used creative waterjet a few times now and are happy with there service
http://www.creativewaterjet.co.uk/index.php
thanks everyone big help
http://www.doncasterlaser.co.uk/
These are who cut all our steel for the RoboDome. VERY cheap, friendly and fast.
Mike.
creative waterjet did all the cutting for the battleratz, quickly as well. Will work from very basic dxf files.
Trev
I know this is a bit of an old thread but do any of the companies mentioned also stock Hardox that they would waterjet?
Building a featherweight and dont need much (if it was mild steel it would called an offcut :) )
Yorkshire Profiles do but its only Hardox 400. If you want anything harder you would have to either source it yourself and take it to your local cutter or go for some kind of high carbon tool steel and have it case hardened. [I think thats right with the carbon but I am not sure...]
