What is everybodies favourite featherweight speed controller and if you could get them in England would you buy them? eg. Scorpion
I think the best cheap speed controller I've used is the electronize, easy to get in uk, pretty cheap and really rugged. Main critism would be size as they are quite big and no built in mixing but most tx have that.
I've also tried the sabertooth an although it is quite compact and has lots of features they are not very rugged, have to get them from america if you want the guarenty so large import charges and can't be pushed to their limits. But they are more compact and very simple to use.
I have no experience with the marine escs but they are even cheaper which I think is better because at end of the day if it makes a motor go back and forward that's all you need an in a robot which is supposed to get destroyed why spend more than you need to?
I also haven't used the more expensive controllers so someone else will have to give their opinion on them
where do you get your sabertooths from
technobots
In my opinion the only ones to use in a featherweight is the scorpion xl and xxl
all the others arn't upto the job
I got my sabertooth from dimension engineering as it means to can get it replaced if it breaks sometimes even if it's your fault! Kenny, I know I am not the most expirianced but I'd would say almost all speed controllers can and have been used to very good effect.
how much do you pay for your saberooths and for scorpion users where and how much do you get them for?
sabertooths. all of mine have ended in a smoking mess.
scorpions are brilliant, you can get them from robot power
I payed £125 for the sabertooth but there were some import charges. Remember I recommend using the electronize rather than sabertooth. If space is an issue then go for scorpion or something rather than sabertooth
what sabertooth is it ?
sounds like a 2x25
It's a 2x25, some people use the 12A version but I think that's a bit of a risk and they are often the ones which blow I think
if you got them in England what would you pay for them?
Sorry meant $125 which according to google is about £80. From technobots it costs £100 but no import charges but again don't go for the sabertooth!!!! I was advised to go for it but after reading the forum a lot more and having spent a lot of money I found out how fragile they are an how often they break and wished Id gone for the electronize.
If you had money and wanted scorpion XL how much would you pay
i'd pay what robotpower ask for them gladly.
I fine the scorpions fine, they are very versitile, good precision controlers. But they are a little fragile, not from the current, they survive fine from that (high current, and thermal cut outs) but it's the majour impacts, and contact with debris that cause the damage, so if you shock mount them, and put them enclosed in something, eg a metal box (metal for good heat distribution) or just makesure you robots enclosed. And if you buy them from demention engineering, they thay can easily be repaired or replaced if damage does occur. And electronises are also good (and cheaper) but the control isn't so precise, and there is only a fuse rather that a high current cut out. So if a big motor stalls, with electronises your out of the battle, where as with sabertooths you continue driving after the high current cut out has finished doing its thing.
how much would you pay for a scorpion?
other options.
a few roboteq kicking about for sale. they are more heavyweight though.
banebots do speedos but import taxes are like double the price.
scorps/sabretooth/electronize all seem very popular.
oh yea victors. slightly more than the others but are used in all high power fw/hw systems
where do you get your esc from?
