I have built rage but I didn't think it was that good so I will be posting pictures as I rebuild it and see what you think of it
I have made the base using polycarb I used a dremal it was the first time I had ever used a dremal and here it is http://i1101.photobucket.com/albums/...9/c76f543e.jpg
It's just a Practise with the dremal I am going to make a better straighter less chipped base
This is the base http://i1101.photobucket.com/albums/...9/4e8e7453.jpg
This is the side panel http://i1101.photobucket.com/albums/...9/6ad87436.jpg
Oh great I have the wrong sized glue sticks I will have to go and buy some more
That looks good for your first time with a dremel.
I like people who keep detailed build diaries with lots of pictures because it helps other people learn how to do things
Here it is with a weapon servohttp://i1101.photobucket.com/albums/...9/f9c500a4.jpg
Hay added theelictrics in http://i1101.photobucket.com/albums/...9/de97c51b.jpg
Oh great the wheels on the front don't turn I will have to buy a different type of wheel I need this doun by tomorrow
The robot looks very neat pugster!
I have found getting straight lines with thin polycarb 1-1,5mm can be quite easily done if you use a ruler to draw the edge and then cut or have someone help you cut it 2-3 times in that straight line with the help of the ruler to keep the knife going straight.
If you then bend the polycarb with this cut line at the egde of a table or similar the polycarb will crack just along the straight line and you get a really straight edge, it might be worth a try on your next robot or something like that :)
just use scissors for 1-1.5mm
I have finished it look http://i1101.photobucket.com/albums/...9/b0541911.jpg
You made that really quickly!!! :o how did you bend the plastic or the flipper?
How did I bend it I just melted the plastic then it was super easy to bend :D
that's a brilliant robot for your first! :)
That looks really cool!!
Here is a vid of it http://www.youtube.com/watch?v=vFZrcuWJ ... ata_player
a lot better than your last antweight, well done :)
It is better because my dad built the last one I built this one :P
wish I could say the same
my dad built all mine
takes over most times
building stuff myself now. :)
