The OddBots Championship
Hello! Welcome to my utterly unexpected return to vapourbot writing!
This is a very quick, very small tournament of six entrants. The format is three 1v1 first round fights and a three way final. The arena will be a fairly plain square with 2 pits and 4 fire grills.
However, there is a bit of a twist! For when creating your robot, you are only allowed to have features from ONE of the following three categories. For instance, if you wanted a wheeled robot, you wouldn't be allowed to use any of the armours or weapons listed. This is mainly aimed at having a tournament with some exotic entires.
Category A: Weapons- Any variation on flywheels or fullbody spinners
- Wedge shaped robots
- Axes
- Flippers
- Crushers: Either vertical or horizontal
- Lifting forks or similar
- Spikes including ramming spikes
Category B: ArmourAny of the following in the form of solid armour or an external chassis:
-Polycarbonate, Polyethylene, Polypropylene
-Kevlar
-Any metals or alloys including the following:
Copper, Iron, Tungsten, Vanadium, Tantalum, Titanium, Chromium, Nickel
**For the sake of this category armour includes all forms of full body weapons such as full body spinners, wheely big cheese style flippers and TAN style crushers etc**
Category C: TransportTracks
Wheels
Competition will start when I have all six entries ready, one entry per person, 100kg for all entriesregardless of transport. Look forward to seeing what people come up with!
Re: The OddBots Championship
Reserve a spot for me too SVP :uhoh:
*reserves a spot while he thinks of something*
Good to see you back Alex, I think I may have some fun with this one ^^
Quick footnote: Aluminium was supposed to be on the armour list, so consider it added
So hang on, you cannot use any metal at all if you have an active weapon, or just the metals listed? It's unclear.
*pondering a magnesium/osmium walker*
its under the armour section
the metals listed
and for that matter you can have an active weapon if you have steel armour, just not the active weapons listed ;)
What Martijn said.
To give some examples of what would be allowed:
If you pick the weapons category, you'd be allowed to have any of the weapons listed there, but not any of the armours or transportation listed.
Example: A wooden armoured walker with a flywheel.
If you pick the armour category, you'd be allowed any of the armours listed, but not any of the transport or weapons.
Example: A hardox armoured hovercraft with a hammer.
If you pick the transport category, you can have wheels or tracks, but not any of the listed armours or weapons.
Example: A platinum armoured wheeled robot with a drill weapon.
Still working on my entry. :) Just to let people know, I have chosen the transport category. :)
I have chosen the weapons category - my entry will be a bit delayed though, unfortunately (in short: university) ^^;
As people are taking their time a bit just as a bit of impetuts to get this going, I'm going to say that unclaimed reservations run out from Monday. Which at the current rate of entering should still give everyone a good opportunity to enter, but might hopefully result in one or two entries appearing.
Also, one minor thing, if possible, in your stats, just declare which category you are going for, just to help me a tad.
Thanks!
I'm going for the weapons class, even though this concept boggles my mind entirely :p
I'll try to get mine up today to start the ball rolling... I'm selecting transport.
No one going for armour yet? Interesting...
KILLSWITCH: ENGAGE
BODY SHAPE: Similar to Stinger, but with flat wheel hubs and with interchangeable weapons on the arm.
WEIGHT: 100kg
DIMENSIONS (L X W X H): 108cm (with arm) x 77cm x 47cm
COLOUR: Red tyres, the wheel hubs and arm are painted yellow and the arm also has blue chevrons running down it.
LOCOMOTION: 2 x 470mm diameter custom built wheels, made of 8mm diamond*
GROUND CLEARANCE: It's an axlebot and so doesn't really have one.
DRIVE MOTORS: 2 x LEM-130 lynch motors @ 36v
DRIVE BATTERIES: 4 x 30cell 36v 3Ah Sanyo NiCad packs
SPEED: 30mph
TURNING CIRCLE: 0 metres
BODY ARMOUR: 5mm
WEAPONRY: Between the wheels is a 65cm long arm made of diamond*. It has various attachments, the primary one being a four bladed bludgeon ala Stinger itself that allows it to thwack both vertically and horizontally. The other options are...
a) a petrol driven chainsaw tail, mounted vertically.
b) a low spiked scoop (not wedge) for both bludgeoning and getting in underneath other robots, made of 1cm diamond*.
SRIMECH: The robot is fully invertible
STRENGTHS: Fast & powerful
THEME SONG: Princess of China by Coldplay
*question: Is this possible? To be honest I was stumped for armour:/
You do realise that you can shatter diamonds with a hammer? Hard but brittle.
anything but wood will do :P
Thing is wood would actually be a decent choice given the limited range of materials.
interesting design lewis, but Im wondering if a scoop might be considered a wedge by the rulings or not ;)... but its only 1 setup... splendid machine
Good start, I assume your category was transport?
I've only got two things I'll bring up:
1) Though while you can have diamond in the rules, you can't really get sheets of diamond, what you could have would perhaps be loads of diamonds set in some other material to hold them together. Any plastic or metal not mentioned would do, tho the results would probably be fairly brittle unless the base material was thick enough.
2) I'm not entirely sure where scoops fall in regards to wedges, I'll allow it this time, but that might be up for review in there is an Oddbots II :P
Which leaves us with the current entries standing at:
1) Killswitch: Engage (Lewis)
2) ?
3) ?
4) ?
5) ?
6) ?
Time for a quick prod - any more entries?
My half baked entry for the weapon category. If you need any clarification just say and I can come up with a diagram or something.
Shape: Irregular pentagonal prism (think house).
Weight: 100kg.
Dimensions: 70cm*70cm*22cm(l*w*h).
Colour: Ivy pattern body with orangey/red bar tips.
Locomotion: A rubber coated aluminium hemisphere attached to each side of the bar and a pair of cams to tilt the robot. Tilting the robot changes the hemisphere's contact angle so causes the robot to move.
(If you don't like that the hemispheres could be made from nylon and attached to the chassis. Tilting the robot causes it to move via gyroscopic precession).
Drive power: The cams are powered by a 24v DeWalt Hammerdrill run on 36v geared down by some ratio to give about a 40mm range of motion (20mm up 20mm down) quickly. They're run like servos.
Ground clearance: 25mm
Batteries: 4*10 cell A123 M1 packs in parallel (basically 4xDeWalt DC9360).
Armour: 30mm thick FR4 Glass Reinforced Epoxy (pcb material) top and bottom.
Weapon: Ti-6Al-4V bar with and s7 tips (2kg each) powered by a Turnigy 80-100-A 130Kv Brushless Outrunner on 36v (4500ish rpm, 1m long, 50kg including tips).
Speed: Some :P
Turning Circle: 0m (I think).
I think a diagram is definitly in order, as I draw a blank when trying to picture this!
1 Attachment(s)
[attachment=0:7s95i8i5]Poison Ivy.png[/attachment:7s95i8i5]
The hemispheres are attached to the bar so spin with it. When the giant servo/cam things are in the centre position the robot goes nowhere. By raising and lowering each side of the robot the contact angle of the hemisphere and the ground changes driving the robot.
In this picture raise left and lower right to go forwards, the opposite to go backwards, Raise both to turn right and the opposite to turn left.
I know you said it was too late to claim the 7th spot but if no one has decided on their robot I might as well try!!!
Name: look out below (or lob for short)
Weight: 100kg
Shape:horizontal 3/4 of a cylinder 1300mm long and a diameter of 550mm
Wheels/Motivation: it's a walker, it uses the same system as spiderbot, the legs are made from 20mm hdpe
Motors: Bosch 750s running at 36v
Speed: not the fastest of robots but quite fast for a walker due to high gear ratio- around 12mph but not very good at pushing
Turning circle: 0m
Armour: 10mm carbon fibre with a 4mm layer of rubber to absorb impacts
Ground clearance: large ground clearance due to walking mechanism- 180mm
Srimech : uses the 3/4 cylinder shape to role back over
Weapon: big axe with a 20kg tool steel spike as axe head! Powered by 75mm bore 500mm stroke full pressure ram single acting ram through a rack and pinion system. Has a custom made main tank simular dimensions to a 2kg fire extinguisher but with a 75mm outlet with a hydraulic ball valve on it and made from aluminium. It has another 75mm ball valve inlet to the ram for a large flow but the system doesn't have a buffer tank!!! The axe retracts using bungee cord to give more hit but it can't use it for self righting. The axe arm is 1m long so have a big reach.
Hope that all sounds ok as this is my first time at vapourbots :blush:
robot name: tweedles
armour: 5mm iridium
locomotion: a walker system similar to anarchy from robot wars powered by 2 bosch 350 wheelchair motors
weapon: a pneumatic flipper with 2 buffer tanks powered by a 50mm bore, 200mm stroke ram and a 5kg gas bottle made from titanium for plenty of flips. the flipper arm acts as a wedge and has a shape similar to that of explosion/eruption, the flipper arm can be used to self right
shape: corcular with the flipper arm on the outside, similar to revenge of trouble and strive
turning circle: 0m
ground clearance:25mm
dimensions ( w x h x l) 0.9m x 0.4m x 0.9m
speed: 10mph
Thanks for the entry - I don't suppose you'd mind doing me a quick sketch in paint so I can picture what it looks like?
http://gametechmods.com/../uploads/i...23tweedles.jpg
forgot to say, the flipper arm is black and the rest of the bot is, meant to be crimson
I owe some apologies here - to Alex for being late, to Jordan for inadvertedly copying his armour idea, and to everyone for the quality of these stats XD I did do most of them at 3am last night in a surge of creativity, so they may be subject to revision when reality sets in.
Anyway, je te presente:
Broken Wings
Weight: 100kg
Dimensions: 100 x 80 x 24 cm
Shape: There is a render coming up, but for now: A box possessing wedges on all sides, with the front wedge being shallower than the rear wedge, which is in turn shallower than the side wedges.
Colour: White - the armour and chassis are coated in a calcium silicate based substance for fireproofing - with some black trim.
Drive: Two Yamaha 550cc motorbike starter motors, run from a 17ah 12v Odyssey SLA battery giving about 1kw each. The motors each drive eight 2014 aluminium legs (for 16 in total) in an arrangement similar to the antweight Type 0 (which is more or less the bottom half of the Anarchy/Scuttle system with the tops of the legs held semi-captive - this is a bit more resistant to damage than Anarchy and more compact) through a 2.5:1 gear ratio. This gives the drive system very good speed (~12mph maximum) for a walker, and the high torque from the two starter motors should give it enough pushing power to be competitive - in theory. The legs have urethane rubber 'feet' over spiked ends so that if the rubber is torn away, the legs can still grip (if anything, even better) and the entire base panel is also coated in flame retardant rubber making it difficult to push the robot around.
Speed: 12mph
Turning circle: Zero
Ground clearance: 0 at the front, maintained by a pair of 3mm titanium hinged forks, with the sides and back varying from near 0 close to the front to between 5-15mm at the back due to the walking gait; however this is under 5mm FR4 fibreglass skirts.
Chassis: 2014 aluminium in tube, plate, box section and various angles in a space frame, cross braced as much as is practical within the weight to provide support for the legs and make the robot much less reliant on its armour for protection (aided by there being quite a bit of space between the outer armour and any vital components)
Armour: 5mm FR4 fibreglass/Garolite, reinforced at the front and top with 10mm birch plywood beneath.
Weapons: The main weapon is a 65cm pneumatic axe, constructed of 2014 aluminium with a P20 tool steel spike tipped with a diamond crystal, run on CO2 from a modified Sodastream bottle and 2 litre buffer tank at 20 bar to a 50mm bore 200mm stroke ram on a Shunt-esque linkage, giving 400kg force at the ram. The combination of fairly low pressure and fairly cautious use of the axe (me being paranoid and keeping some gas back for self righting) should ensure that the gas supply is adequate for a fight.
Srimech: The axe - the robot can't land on any side other than its back or base.
Notes: Pretty much everything inside, where practical, has rubber mounts and other devices to protect it from a) shocks induced by large rotating objects and b) vibrations from its own walking mechanism.
Strengths: Speedy for a walker with good maneuvrability, stable, good weaponry, and Richard Page
Weaknesses: The armour - although the strength of the chassis should minimise this being an issue - and anything involving pegasi
Rough weight breakdown:
Chassis: 40kg
Drive and all associated electronics and mechanics: 30kg
Armour: 15kg
Weapons: 15kg
Hopefully this is okay Alex ^^
Here you go!
Name - One for the Money
Shape - Render coming soon, but generally it is what you might imagine an invertible horizontal thwackbot with wheel guards would look like.
Weight - 100 Kilogram
Speed - 29 km/h (18mph)
Dimensions - 120x60x30 cm
Ground Clearance - 1 cm under the actual, you know, body, pretty damn massive everywhere else
Power - 2x LEM130s at 48v
Movement - 2 wheels baby
Turning Circle - Zero
Weaponry - One big effing pole running through the body of the robot, with on one end a massive concrete head of a sledgehammer, and on the other a horizontal diamond rescue circular saw blade powered by a Mag that is part of the pole. Linear actuators can move the whole pole forward and backward, so that I can either have a thwack with a hammer at the end and a sawblade close to the main body, OR the saw at the end of the thwack and the hammer head closer to the main body.
Armour - A monocoque of 2 mm depleted uranium sandwiched between 2 layers of polyurethane foam for shock protection on the inside and outside!
Srimech - It€™s invertible!
Thats our roster full!
- Choice:
2) Poison Ivy (Jordan)
- Choice: Weapon
3) Look Out Below (Max)
- Choice: Weapon
4) Tweedles (Jack)
- Choice: Weapon
5) Broken Wings (Joey)
- Choice: Weapon
6) One For the Money (Martijn)
- Choice: Transport
I'll have a thorough read through all the stats in the next few days to make sure everyone meets the entry requirements, but barring that, hopefully we'll see the first fight before Friday!
I have no idea how this will fare, but here goes nothing...
Legion
Shape: A box with a front wedge, sharpened as much as possible at the end to give the lowest ground clearance there. Render to come, I guess...
Colour: n/a
Weight: 100kg, hopefully...
Motors: 2 LEM130s @ 49.5v geared 6:1 for average speed, acceleration, and control
Power: 5 packs of 15 M1 A123 Lithium-Ion cells
Motivation: 4WD, with the wheels cambered inwards 26 degrees for better turning ability.
Top Speed: 15-20mph
Chassis: 5mm Steel box section, reinforced with plywood in key areas.
Armour: Attached to the chassis are several, several layers of interwoven carbon fibre threadings. By themselves (according to the website I got it at), the threads are very strong, but when interwoven in layers, to the point where the thickness is 10mm, this is pretty damn resilient. This armour is found everywhere except the baseplate and front wedge, which are 4mm nickel-beryllium alloy.
Ground Clearance: 0mm at the front, 20+mm everywhere else
Dimensions in CM: God knows :P I'll see where the render takes me :P
Weaponry: Inside the front wedge is a hole, from which a tethered chain enters, and on the end of the chain is a barbed spike. It is fired using full-pressure pneumatics, and then pulled back by a winch. If a robot gets reeled in by it, or Legion gets reeled towards the robot, they'll end up stuck on the wedge, and Legion can then shove it around. Powered by a 2kg CO2 tank, it can fire around...maybe 20 times in a fight?
Srimech: Invertible.
Please be gentle with your flaming. :lol:
EDIT: ...wha...how did the tournament get full without my knowledge...
Hey, Sorry it took so long. Loads of GCSE stuff came up...
Shape: A T shape, with the legs mounted inside the robot at the rear (that is the - section) and the disk mounted on the longer | section. There is also a hinged wedge at the rear of the robot behind the wheels. If its hard to understand drop me a line and i can whip up a sketch or something.
Weight: 100 Kilograms
Speed: 12mph
Dimensions: 110x50x30 cm
Ground Clearance: 0mm under the wedge,
Power: 2x LEM motors on 48v (2x 24v A123 packs).
Locomotion: A simple leg mechanism, 4 legs per side, each mounted inside the robot and tall enough to poke out both sides thus making it invertible. Each side is powered by one motor via a custom gearbox.
Turning Circle: Zero
Weaponry: A 40mm spinning Hardox bar powered by 2 magmotors.
Armour: 7mm Hardox all over
Srimech: Invertible, also Zeus... and teacakes.
Hope thats okay?
EDIT: Wait what? Did i reserve a place? :uhoh:
Well as we now have a 8/6 roster spaces, I'll expand it to 8 spots, although I'm going to keep with a 4-way final rather than 1v1 all the way round just because I think it'd be a bit more fun.
On the flipside of that, there are still some revisions people are going to need.
Pennyroyal T - At the minute your robot doesn't meet the entry requirements at all - you mention wheels (transport category) hardox (armour category) and a spinning bar (weapon category) so you need to ditch two of those for replacements.
Legion - Sorry to be a pain, but I did specifically mention that wedges were considered weaponry, and while I'm not going to be as tough as saying no tapered fronts are allowed, but nothing that looks like its mainly designed to get under robots.
Tweedles - Meets the rules, but you are going to we a significant degree overweight mainly due to the armour.... iridium is 3 times heavier than steel and twice as heavy as lead...
LOB - 20kg is fairly excessively heavy for a spike and probably puts you well overweight, for comparrison Mortis' axe blade weighed 3kg. If you were going for the terrorhurtz bludgeoning kind of axe that'd make sense, but even then its a bit excessive. I'd suggest you either reduce the weight to under 5kg, or change it to a terrorhurtz style blade and take it down to 12 or something.
I'm not the kind of person who forces people to weigh up alll their components (because I can't be bothered to check their workings) but if there is something that blatantly looks excessive I will question that in the sense of fairness.
There may be one or two other bits and bobs I'll spot, but thats a start for people to do revisions to.
