my robot has power to it because the reviver light is on so the power is going through the esc's but there is no movement on the motors? :uhoh:
need a bit more info mate
what would you like? :lol:
what make is the esc ....does it have a built in BEC or are you using a battery to the receiver
this is the esc
http://www.ebay.co.uk/itm/2x-Marine-50A ... 3f0df2b70d
and it dosnt need a seperate battery
are you using a v trail mixer as well
yes
i had fun with this u have to disconnect the bec on both speed controllers a get a separate battery or BEC as the 1s on the speed controller will fight each other and 1 wont give enough power to run everything
http://www.youtube.com/watch?v=zdUhLH7BS4E
a good vid about it
Just disconnecting one bec should be enough.
i tried that with my set up and it didn't it could just be the v trail but when i disconnected both and added a separate BEC it worked
so ive got to cut the red radio wires coming off the esc and add an external power sorce to the reciver
well on the vid is shows you how to pop them out incase you ever need the bec .. and then u just use some insulating tale to rap them up............. it might work if you just disconnect 1 i think it depends on the v trail but i read on another post that your better off with a separate bec cos if the controller gives up u can still use weapons and 1 side of ur bot will still work
cool thanks alot! 8)
i got a bec off ebay for about £2 or £3
cool
I used them up until a few days ago in Eric Jr and didn't use a external BEC or do any surgery on the wires.
Few simple things you can check:
Are the switches on the ESC in the ON position?
Are the batteries charged?
Is it wired up ok?
A few photos might help us :)
thanks it now only works (very badley) for the first few seconds?
shove a picture up of how you've wired it. btw it's a good idea to take the switches off and solder the wires together.
i would lol bit of a problem the robot is in peices due to major re design lol :lol: so it will have to wait but thanks anyway everyone :D
