I know what I need to do the job, just don't know what it's called so I can't find them.
I need to have some way of attaching Saw blades to a shaft in my wooden robot, and since they have often have a 20mm internal hole I was stuck for ideas.
I think I can do with with some sort of hub that sits in the 20mm hole and has a wider flange that can attach to the blade.
Something like this if you looked at it from the side:
http://i1228.photobucket.com/albums/...25at194742.png
