hi iv'e been looking at some second hand 1s on eBay and a lot of them seep to be either mode 1 or 2 and i was wandering if it matter which type i get
it's to do with which side the throttle is on. most people go for mode 2 if they're right handed.
Ive just bought a spektrum dx5e I have a couple of questions if someone could help me.
The reverse servo buttons are below the surface are they supposed to be like that.
It only takes 4x aa bats, is there a battery pack that I can get that would charge via the socket on the spektrum.
What receivers are compatable that gives the fail safe mode?
Thanks
yes they are. Stops you accidentally hitting them mid fight/flight
4 rechargeable double As would do the job if it takes regular AAs. Then you just have to get a charger that plugs in and charges at 6v.
Fraid I can't help you on the receiver side, been a while since I've looked at spektrum kit
The DX5 normally come with a AR500, these stop outputting a signal in failsafe mode, so as long as your speedos have failsafes built in, you will be fine. I have had issues with all of my AR500s failing though after about 2 years.
Like Gary said, just put normal nicad/nimh AA cells in, i guess you can buy a charger for 6v, dont use a normal TX charger as they're for 8cells.
thanks for the help guys
has anyone ever used any of these receivers?
http://www.ebay.co.uk/itm/Orange-6ch-Re ... 27c1a4ad3e
http://www.ebay.co.uk/itm/spektrum-ar61 ... 20c1d3abf5
with the specktrum dx5e?
yes, no problems for me.
yes and they both work well. That said they only have the failsafe on the throttle channel. There is one of the cheaper receivers for the dx5e that does fail safe but i can't remember which one it is :uhoh:
I've used the orange one, it worked well, but I prfer the AR500
is there any receiver that will failsafe on all channels for the spektrum dx5e?
any one used these transmitters before and can suggest which is better
http://www.giantcod.co.uk/giantcod-24gh ... 03852.html
http://www.inwoodmodels.com/product_inf ... b539188730
or would it just be a better idea getting a dx5 for £45 and a receiver off ebay
Yes it would. I can't comment On the Saturn set but giant cod radio gear plagued me with problems in the past, I now use a dx6i.
well the saturn and the dx5 i'm looking at are from the same shop so will probably go have a look
just came across this tx from our local model shop and was wandering if any1s used them as they sound pretty gd for the price
http://www.inwoodmodels.com/product_inf ... ts_id=3410
Seems pretty expensive to me, the giant cod ones look to be doing basically the same thing, although depending on how small their alternative micro controller is it might be good in AW's.
Could be wrong though :)
well there are the 3 that im looking at a Saturn.... a dx5 and the hitec
i would have to buy a receiver for the dx5 but the transmitter cost about £45 from the shop
I haven't used any of them i'm afraid, but if you can get the DX5 for £45 you can get compatible RX's for under a tenner.
