3 Attachment(s)
The Grim Reaper!!
Name to be changed most likley to Reaper as the original team want to keep the name i believe.
Had a propper look at it today, mainly gave it a coat of primer to stop it going rusty since matt got it sand blasted before i got it.
pics,
[attachment=2:2sv1pwz5]BILD0004.JPG[/attachment:2sv1pwz5]
not in too much of a bad condition really, few bends here and there but nothing too major
Picture of the damage Sgt Bash caused with its claw from RW..........
[attachment=1:2sv1pwz5]BILD0005.JPG[/attachment:2sv1pwz5]
With the lids and flipper arm off ...
[attachment=0:2sv1pwz5]BILD0008.JPG[/attachment:2sv1pwz5]
what i've sprayed red is getting cut out as its bent upwards from the ram pulling up as it reached the end of its travel, and instead a 3.2 hardox base which will mount the motors, ram etc etc
2 Attachment(s)
Re: The Grim Reaper!!
Few more pics.....
[attachment=1:wswngbkb]BILD0006.JPG[/attachment:wswngbkb]
[attachment=0:wswngbkb]BILD0007.JPG[/attachment:wswngbkb]
Flipper arms pretty much ok, think im going to rebuild the top panel/lids thou as they are a bit past it- wouldn't take too long
Looking great Calum, gotta have a go when your finished ;)
3 Attachment(s)
Spent a few hours on grim reaper yesterday, mainly chopping it up and planning what i can do with what parts etc.
motors i was given for it don't fit in the slightest so having to sell them off and get some bosch 750s or 400s sorted
can't believe it but at work thursday i was thinking about grim reaper and um-ing and ar-ing about hinges for stuff and out of no where managed to 'find' some steel scrapped parts at work with a 20mm hole in the center which will work perfectly!
pics
[attachment=2:3yqxxe5r]BILD0003 (5).JPG[/attachment:3yqxxe5r]
[attachment=1:3yqxxe5r]BILD0006 (2).JPG[/attachment:3yqxxe5r]
[attachment=0:3yqxxe5r]BILD0004 (2).JPG[/attachment:3yqxxe5r]
i've got a sheet of 4mm hardox i want rid off so thats going to be the base with aload of cut out sections eventually replaced with steel or something. the hardox is just for the strength really more than anything. im off work monday and tuesday so hopeing to get the base done, ram and everything mounted and mabye even get to try the ram out :)
more to comee
Looks fantastic calum, really look forward too seeing it back in action :)
there's a Bosch motor on ebay the guy has 2 but said he only found 1 of the in his garage so far
http://www.ebay.co.uk/itm/BOSCH-24-12-V ... 500wt_1287
what motors did you have for it?
used to have sim motors, now belong to trevor wright thou as of last night lol
ill sort out buying a pair of 400s for it when i get paid thursday
3 Attachment(s)
day off work today so spent it working on grim reaper.
the heavy weight bug is catching but at the same time i can't believe how shattered i am lugging the robot around every which way but loose all day. everything on me aches! feathers are so much easier to work on!
bottle holders almost done, new hardox base for it and the rams pivot is made. its crazy I started the day welding the base on which took an hour with some amazing welds, and as the day went on especially in areas where they would be clearly seen its like i forgot how to weld and some are eye sores! they'll hold for now at least anyway thou.
quite a lot of pictures to follow, starting off with the chopped chassis laying ontop of hardox so I could mark out what to cut out for the new base. Then mounting things inside like the rams pivot and the bottle holder, having a play with where a pair of batteries could go and just seeing what the arms like fully open etc etc.......
[attachment=2:15jy2gv1]BILD0005.JPG[/attachment:15jy2gv1]
[attachment=1:15jy2gv1]BILD0006.JPG[/attachment:15jy2gv1]
[attachment=0:15jy2gv1]BILD0007.JPG[/attachment:15jy2gv1]
3 Attachment(s)
[attachment=2:2to6y1cy]BILD0008.JPG[/attachment:2to6y1cy]
[attachment=1:2to6y1cy]BILD0009.JPG[/attachment:2to6y1cy]
[attachment=0:2to6y1cy]BILD0010.JPG[/attachment:2to6y1cy]
3 Attachment(s)
[attachment=1:1ite5dfm]BILD0012.JPG[/attachment:1ite5dfm]
[attachment=2:1ite5dfm]BILD0011.JPG[/attachment:1ite5dfm]
[attachment=0:1ite5dfm]BILD0013.JPG[/attachment:1ite5dfm]
3 Attachment(s)
[attachment=2:3l5cyvef]BILD0014.JPG[/attachment:3l5cyvef]
[attachment=1:3l5cyvef]BILD0015.JPG[/attachment:3l5cyvef]
[attachment=0:3l5cyvef]BILD0016.JPG[/attachment:3l5cyvef]
Hope I'll see it back in action soon Calum, we need to have a fight once it's done
Looks neat, cant wait to see more pics as even more progress is made!
pics to follow of various parts and trying a few things out. Robots in my room for a bit so i can work out and draw a few parts up when i get a spare minute- saves me having to go to the shed lol the arms on, im taking the wheels to work tomorrow so i can get them sorted out, hopefully from the pics ya can work out whats goin on.......
3 Attachment(s)
[attachment=1:2wtjp2o1]BILD0021.JPG[/attachment:2wtjp2o1]
[attachment=2:2wtjp2o1]BILD0020.JPG[/attachment:2wtjp2o1]
[attachment=0:2wtjp2o1]BILD0023.JPG[/attachment:2wtjp2o1]
3 Attachment(s)
[attachment=2:2trup5tu]BILD0023.JPG[/attachment:2trup5tu]
[attachment=1:2trup5tu]BILD0024.JPG[/attachment:2trup5tu]
[attachment=0:2trup5tu]BILD0025.JPG[/attachment:2trup5tu]
1 Attachment(s)
[attachment=0:26r55fau]BILD0022.JPG[/attachment:26r55fau]
Looking great Calum! But that £20 is mine :lol:
Looking good calumco, should be pretty sweet when it's done.
cheers guys, and matt your gonna loose
Wait and see I guess, I just need too get you out before I run out of gas :L
gave the wheel to the guy at work who runs the cmm to find out the 3 hole positions from the center, im gonna add another 3 to make them stronger, i can finally get making bits now
3 Attachment(s)
Few more bits done, need to buy another battery and get a smaller co2 bottle now, may go for 2 600g bottles yet.
[attachment=2:23y4on41]BILD0029.JPG[/attachment:23y4on41]
[attachment=1:23y4on41]BILD0030.JPG[/attachment:23y4on41]
[attachment=0:23y4on41]BILD0031.JPG[/attachment:23y4on41]
1 Attachment(s)
[attachment=0:14nrr7j1]BILD0032.JPG[/attachment:14nrr7j1]
looks great! But cover up those holes on the Bosch motors!
lol i will do eventually!
drives the next major thing, gonna pull my finger out now and try get this done for the next RL event
Trying too for Leeds or going for Swansea?
Better get a move on then, but Swansea grim reaper will be going down ;)
cover the holes as soon as possible, during the build there is more change of iron/steel or stuff like that getting in.
I cleaned my the other day, it was closed from day one, i was amazed how much dirt was in it.
When your working on robots you will be surprised what them magnets suck in.,I would stick some tape on em at least.
going to spend a few hours friday after work on this so ill get it done then :)
going to parkside steel tomorrow after work to get some 20-20mm box section to start rebuilding the lids and today from work i got some 15mm bar for where the ram connects to the arm. So now thats the flipper side of things completly sorted, just drive mainly now which is being sorted soon as
might have a cheeky go with the weapon friday too by just bodging the pneumatics for now with a random valve some 12mm pipe and spare fittings i have.
3 Attachment(s)
Had a bit of time today after work so did a bit on grim reaper.
pics below....
[attachment=2:323uh7d4]BILD0037.JPG[/attachment:323uh7d4]
[attachment=1:323uh7d4]BILD0038.JPG[/attachment:323uh7d4]
[attachment=0:323uh7d4]BILD0039.JPG[/attachment:323uh7d4]
3 Attachment(s)
[attachment=2:gz5bggtq]BILD0040.JPG[/attachment:gz5bggtq]
[attachment=1:gz5bggtq]BILD0041.JPG[/attachment:gz5bggtq]
[attachment=0:gz5bggtq]BILD0042.JPG[/attachment:gz5bggtq]
1 Attachment(s)
[attachment=0:2jkm16dq]BILD0043.JPG[/attachment:2jkm16dq]
old and new next to each other, not going to put any of the central box section on, just going for 3.2 hardox instead to make all the shape.
more to come soon
3 Attachment(s)
[attachment=0:um7353vd]BILD0044.JPG[/attachment:um7353vd]
[attachment=2:um7353vd]BILD0045.JPG[/attachment:um7353vd]
[attachment=1:um7353vd]BILD0046.JPG[/attachment:um7353vd]
1 Attachment(s)
[attachment=0:1epfxr2h]BILD0047.JPG[/attachment:1epfxr2h]
few more hours today, left out 1 section as im not sure what wheel set up im going for yet
more to come soon :)
