Holes
I was wondering why people don't drill holes into their machines much to lighten them, they prefer to mill it down, or use 2wd compared to 4wd, is there a particular reason for this, are holes considered ugly? Are they particularly damaging to the integrity of a robot?
Re: Holes
They just don't really save that much weight. Especially compared to, in your example, dropping 2 motors, wheels, esc(s) and al the material savings that go with that reduction in size and mounting pieces.
Re: Holes
when things are peppered with holes it don't look too great.
nothing really wrong with them though
Re: Holes
Makes sense, if I have to use them I'll have them in the bottom, kind of razer-esque.
Re: Holes
It's better to alter and optimise your design before building if you reckon you're gonna be overweight. I saved over a kilo on the original Drumroll by chopping out large sections of Nylon and peppering the base with holes. But if I'd given the design more thought, I could have changed the material type and/or thickness before building to reduce weight and save myself from butchering the chassis. Having said that, drilling holes can be quite fun and you can mess about with funky shapes and patterns :crazy:
Re: Holes
If mine is overweight, it will be because of a buffering tank, I don't know if I will use one yet. I doubt the armour will be too thick, its roughly .5ali base and .7 ali checkerplate top armour. I can't be too sure yet, because half the robot is in various boxes, in post offices! :lol:
Re: Holes
5mm and 7mm ali? Or 0.5mm and 0.7mm ali?
If it's the second option, and if this is for a featherweight, you'd be better off armouring it in paper.
Re: Holes
Your joking, right? :(
I'm not planning on using this in full combat events, no spinners! What sort of thickness would it need? Should I be looking at a steel compound?
Now I realise my mistake. I meant 5mm and 7mm, lol! :rofl:
Is that strong enough?
Re: Holes
Its 5mm Ali Jamie, the old Daiske II :) Can't imagine a 0.05mm Ali baseplate holding everything together too well :lol:
Re: Holes
Anyways, the armour should hold together right? I'm doubting myself now...
Also, will it need an L bracket to attach the HDPE sides to the base better? (With weight allowance it'll be armoured too, but for now its suppossed to keep the drive in place.)
Re: Holes
Ahh okay :)
Yeah that's a decent thickness then. 0.5mm ali would have been funny though, even antweights use thicker stuff!
Re: Holes
The scoop on Bitza was 0.7mm Steel, look how well that worked!
Re: Holes
Bitza looked like a good robot, what happened to its scoop?
Re: Holes
Thanks!
It would bend if you blew on it too hard. We were right on the weight limit, it's actually the metal from the side of a dishwasher, hence the white....
It would buckle under the robot and make it difficult to drive, or we'd get stuck, or it would become ineffective. Saved us from LS4 though.
http://www.youtube.com/watch?v=q8aE1iJEiLM
Re: Holes
Wow. But aluminum is quite springy, I doubt it will get stuck. Thanks for sharing the video!
