Hi Guys
Having not built a robot since Robot Wars, I'm going to start again with a Feather. Can you post links for batteries? 18v, suggestions + help would be cool :D
Hi Guys
what bot did you have on the old wars?
Sabretooth. We made 3 different versions, out in the 1st round every time because it broke itself :lol:
ah, looks like it could have been great, shame about the luck. could it really do 70mph? :lol:
cant go wrong with vapex ni-mh batteries
It was mental 17 hp fully automatic engine, with electric start, yes it did go that fast. On that occasion we had massive radio interference, I had no control of it throughout the whole match. Do you have a link for those battery's
Hi Gabriel,
I've spent the past couple of minutes wondering why your name rings a bell. I realise now that I bought a small linear actuator off you waaaay back in 2005! Okay, randomness aside...
A couple of good online stores for battery packs are:
Component Shop
http://www.component-shop.co.uk/
And Vapextech
http://www.vapextech.co.uk/acatalog/Hig ... eries.html
They're both suppliers of sub-c sized Nickel Metal Hydride packs, from 4.8V packs up to 12V packs (just connect a couple of packs up in series to get your desired 18V+).
These days, lithium-based batteries are quite popular, especially among featherweights, as they are capable of providing much-improved power output for their size and weight. But for getting back into the sport, I'd say Nimhs would be the best option. Have a look around some of the threads though and there will be some info on lithium packs, rules and suppliers.
Have you got a particular design in mind yet?
that sounds mental!
Brilliant ! Well I hope the actuator was put to good use. Sabretooth 4 has a large disc made out of steel in a dome shape. I have a chum who will make a miniature version for my feather. It will have a domed disc, with a interchangeable drill press weapon. Thanks for the links. I will start a build diary once I start on the cardboard mock up chassis
Another question what size MAH should I choose. I will be running 2 x 14.4 motors and a couple of others to drive the disc and animate it
as big as you can afford, i use 4000mah to 4700mah in my feathers, most people use 3300mah or 3700mah
So how long do they last ? 4700? . There are 5000's on there
What type of motors do you have in mind to spin the disc?
Drill motors will happily get through a 3-min fight with a battery around the 2000mAh mark, but it all depends on how current-hungry your weapon motors are.
Also, not sure if you know or not, but current regulations mean that you can only run FW spinners in a fully-enclosed arena (10mm thick polycarb walls and, I think, 6mm roof) and the only arena in existence at the moment that complies is the Robo Challenge arena. These guys only tend to host a couple of events a year, so with a spinner, you will be limited to the number of times that you can compete with it, unless you run it without spinning it or fit a different weapon at non-spinner events.
(James from Robo Challenge has said that they're working on one or two possible full-combat events in the spring-time)
I could do with a pointer on a disc motor. I will build a spinner and then build the interchangeable drill press weapon. The plan is to build more than one and fight them in the barn, old school style. I have a idea I might build a mini chaos 2 :o
For a spinning disk most people use speed 900 motors (£36 from Sussex model centre or Cornwall model boats), there are also some cheap (£12) motors like the speed 900 on eBay- they are a bit discoloured and spin faster and less speed than real speed 900s but still not bad I think. Some people use brushless motors and magmotors but I now nothing about them!
Thank you
When it comes to disc motors, your first choice is brushed or brushless motors. Brushless motors are really proving their worth now but brushless-powered spinners tend to fall into the 'bloody hell that's insane!' category and are considered the higher end of the power scale. If you want something that will still do damage but is cheaper than a brushless setup, there are two main options that have proven to be decent.
The first is to go for a Speed 900 electric motor (or two) to power your disc. Drumroll/Boner, Savage Evo and Inertia XL have all had success using them. They're relatively cheap (just under £40) and can be powered either by a speed controller or relay.
I bought my most recent one from Cornwall Model Boats, and it made it from Cornwall to Scotland in less than 24 hours!
http://www.cornwallmodelboats.co.uk/aca ... _6373.html
There are a couple of other sites that stock these but they're all around the same price mark.
Alternatively, get yourself down to your local car breaker's yard and hunt out a car fan motor. Ford Mondeos seem to be the popular choice. These motors are similar to the EV Warrior that used to be available, and they're capable of performing around the 1hp mark. Better yet, you can usually get them for £5-£10. Dragonstrike is the best example of how effective those motors can be.
I'll get some video links that show the performance of the two.
Yes please on the links, I will look into the suggested motor options
One Speed 900 at 19.2V:
http://www.youtube.com/watch?v=r7B9vKIJ5nU
Thanks for that, not much in it. Which motors are lighter ? I'm now really looking forward to getting started. I will start purchasing all the bits next week
the the fan motors dule direction? i may upgrade my drive for them :)
The Speed 900s are lighter
Yeah I think the fan motors are 1.2kg? Speed 900s are around 650g although since two of them are the popular option, then there's little weight difference.
And yeah Matt, to my knowledge they're dual direction.
Depending on total power, but currently, brushless motors and controllers are getting idioticaly cheap compared to brushed motors and relais.
Do you have a link to brushless motors that are good
http://www.hobbyking.com/hobbyking/stor ... 55%5F.html :proud:
That is a VERY nice spinner motor...... For a heavy....
Team RCC has one of these wandering, waitning for a robot to be build around it.
That is a monster thanks
Its the motor Buzzbar (Little Spinner 2) is using for his spinner at the moment, quite heavy though so would take a lot of clever design to be able to use it.
It's not so much the motor that bumps up the cost with brushless spinner setups, but the ESCs (and depending on brand, lipo packs too).
I got a nice Scorpion motor for £85 but a quick look into reliable controllers left me looking at a £200 pricetag. Suffice to say that'll have to wait a month or two.
Brushed electric spinner setups using Speed 900s or car fan motors are usually reliable and rugged. While brushless setups are becoming much cheaper in general and are possibly comparible in price to a motor/relay setup, to get a brushless setup in a featherweight spinner that is as reliable and rugged as the brushed option, you will have to pay much more. Go for the cheaper option and you might find that you have to replace bits on a more regular basis. Thankfully for the general UK roboteering community, Dave Moulds (360) has gone through a lot of models of motor and ESC, as well as a lot of money, to help determine what brands are better and what are not when it comes to featherweight brushless spinners.
ME?
lol... that motor posted above is utter rubbish for the size of it...you'd be much better of going with a smaller more efficient motor such as a scorpion HK4025, it will give more then enough power on 6s lipo than that bigun and weigh a lot less....
for example 360 uses a scorpion hk4025-890kv and generates 5000w (more then the advertised spec of the motor) on spin up.... i think LS4 uses the 12s version and that can produce even more power and its only like 5mm longer in size.
i originally used dual scorpion hk3026-1400kv motors in 360... and even one of those tiny motors could just about spin up the 5kg blade...
Glen in Aus is using a 3026 with a 3kg blade and its won pretty much every competition over there...
When using brushless always over rate the motor you need
Never over volt it
Over rate the esc you need and dont go for rubbish brands
If in doubt ask on here if your serious about building something.
price.... a decent motor will be around £120, a good esc will be about £150, and a suitable lipo will be around £80 depending on the setup.
from what ive seen... its a good idea to not go below a ratio relevent to the weight of your disc on a decent sized motor as a rule of thumb;
2kg disc... 2:1 ratio or more
3kg disc... 3:1 ratio or more
etc
examples of brushless discs;
http://www.youtube.com/watch?v=9C-FZlWJ4Oc
Thanks Dave,
Watching 360 on YouTube has inspired me to build again, I love it's hypnotic, gyroscopic dance
it that the kinda stuff you could use for drive?
http://www.ebay.co.uk/sch/i.html?_nkw=f ... m270.l1313
and whats the feeling on the SR15-100 magmotor for a spinner? :lol:
