, hi, i am building a featherweight robot like wheely big cheese. i have built featherweights, but need advice on how to build. thanks :)
Ach i'll bite, explain a bit more and we'll do our best.
Some questions to consider including answers to:
1. What materials do you want to build it with?
2. What bits do you know how to do and what bits do you need help with/what sort of things have you done before?
3. Do you have anything in particular you want to include in the robot
4. What sort of tools to do you have access to
Thats a start and we'll hopefully be able to help from there :)
didn't know you had build feathers, thought you only had an ant?
i only have built an ant, but i am now trying to build a pnumatic axe like steel avenger
i have acess to lots of tools, all the ones ill need
i might build with hardox,
and i can get most materials, and items.
OkQuote:
Originally Posted by JED1999
Nor cheap, nor easy to do well.Quote:
but i am now trying to build a pneumatic axe like steel avenger
Basic tools. Drill, (pillardrill is a big bonus), anglegrinder with cutting off and flap disks, welder or a large supply nuts and bolts.Quote:
I have acess to lots of tools, all the ones I'll need
Good for you, a supply of drillbits or experience with sharpening drills is recommendend.Quote:
I might build with hardox,
So can everybody, that's just a question of budget.Quote:
and I can get most materials, and items.
sorry i ment pneumatic spike robot
useless weapon and still hard and dangerous to build :)
well what would you recomend?
Electric lifter / crusher via either a linear actuatoer or a drill motor / threaded rod setup would be a good starting point i guess.
I'm doing that on my FW as pneumatics and spinners seems a bit down the road
ive got a FW horizontal crusher/grabber, their fairly easy to build and they look dam good, what more could you want :rofl:
ok, i will try to build a razoresque robot, anyone got any good links?
and any helping ideas, what would be the basic parts?
You will need an actuator, batteries for it and a rc switch (I use a 15a ESC for this) plus all the usual parts for a bot
got acsess to a pilladrill,Quote:
any good plastics?
I prefer HDPE, less brittle than polycarbonate.Quote:
got acces to a pillardrill,
any good plastics?
And you'll have some fun with that pillardril if all goes as plannend.
Thanks for the tips, trying to get feather robot :proud: :D
