hi, i'm looking for a 50cm by 2cm or there abouts piece of titanium around 2mm thick. anyone got some i can buy?
are you gonna be cutting this piece down into smaller bits or is it to stay intact ?
i got some 1.8mm sheet
pretty much intact, just making it pointed at the end
would 1.8mm be ok ? i could sort it early next week and send it straight after cutting ??
yeh that's fine, could you also make the end pointed?
yeh thats fine ill be using an angle grinder to cut it so there edge might not be true straight be not far off :) how much of a point do you want?
roughly like so:
http://i990.photobucket.com/albums/a...Untitled-1.jpg
i can cut this piece today do you still want it??
Yes :)
are you going to worthing?
Yep
unfortunately alex was unable to cut me the piece so i am still looking
if mainly after 3mm if possible?
thanks
matt
Making a sword? :)
yep :)
still looking and still really need it! only need 40cm long now though, would consider up to 3mm thick ti!
Give me all the dimensions and ill see what i have in my stock ....
pete
:lol: :lol: :lol: :lol:
40cm by 2cm with a pointed end (see other page) 1.8mm-3mm thick
