hi all
just wondering if these would be ok as the price etc seems to good to be true!
http://www.pickegg.com/wholesale/aa-ni- ... elcome=254
hi all
or would this set be better?
http://www.shopxter.com/index.php?main_ ... s_id=33161
neither if you were thinking of using them as your main power unit in a featherweight. The AA and similar design of batteries are not designed for high current applications and the wiring on those is the major giveaway (very small).
The old phrase is very true, if it seems too good to be true then it probably is.
though so :) got any batteries that would be?
matt, go for 2 of these wire them in series
http://cgi.ebay.co.uk/8-4V-3300mAh-NiMH ... 564093b27c
that will work well for you. just check with someone on here your electronize can take the voltage coz i dont know that one. you would want to change the tamiya connectors too, use your deans connectors instead.
this is how you wire batteries in series in case you didnt know, double the voltage :-)
http://www.google.co.uk/imgres?imgurl=h ... 24&bih=587
if my 15a esc's would take the voltage then i would use those ones. are my batteries in parallel or series ade? aint had a chance to look at em since whitwick
I'll be throwing some vapex nimh in the for sale section in the next day or two.
would wiring 2 9.6V in series be too much to get away with or would 2 8.4V be better?
anyone know?
too much for what? You need to be more specific with your questions
