FRFFT: Series Two: Redone!
To all those to entered FRFFT: Series Two, I am sorry, but I no longer wish to continue it because of mistakes on my part
So, FRFFT: Series Two is being redone! This time, Im going for a much simpler design!
The rules have changed. I need 8 people to enter 4 robots: 1 featherweight, 1 middleweight, 1 heavyweight and 1 superheavyweight
Here are the seedings!
Featherweights
1: Little Hitter
2: Deadly Lampshade
Middleweights
1: El Media Diablo
2: Hazard
Heavyweights
1: The Hurting
2: Nitro-Gene 5.0
Superheavyweights
1: Drive
2: Ziggy
The Robot Wars S7 arena will be used. The House Robots arent making an appearance, but Refbot will be there.
Weight Limits:
Featherweight: 1kg to 13.5kg
Middleweights: 25kg to 50kg
Heavyweights: 50kg to 100kg
Superheavyweights: 100kg to 200kg
Walking robots get a bonus of double the weight limit
Vapourbots and real robots are allowed. I dont care how many of each you enter. Just as long as 1 robot is in each weight class.
Thanks for reading! The thread titled FRFFT: Series Two is no longer active. Ive transferred to this, now!
Deadly Lampshade
Purer
Maleficent
Cause and Effect
Stats on ZED. :)
Little Flipper 3
Complete Control
Nitro-Gene 5.0
Shrederator Supreme
There you go :proud:
Thank you, Paul and Daniel.
So far:
Featherweights:
Deadly Lampshade (Daniel FTB)
Little Flipper 3 (Paul C)
Middleweights:
Purer (Daniel FTB)
Complete Control (Paul C)
Heavyweights:
Maleficent (Daniel FTB)
Nitro-Gene 5.0 (Paul C)
Superheavyweights:
Cause and Effect (Daniel FTB)
Shrederator Supreme (Paul C)
Sorry, but Im not entering this time.
I understand that, Kody.
If it is something to do with me, Id like you to make it known. If not, I apologise for nagging you
Featherweight - Ill come back to you :)
Middleweight - Typhoon
Heavyweight - BIACS-IS (stats on Zed)
Super Heavyweight - Ziggy
FW: Little Hitter and Arrgh
MW: T-Minus and Hazard
HW: Blue Hurricane and 2nd Revenge of Black Death
SHW: Ziggy and Toro
Blue Hurricane
Weight: 100kg
Shape: Disc
Dimensions: 88 X 88 X 27
Colour: Royal Blue for the sides, and a nice shade of midnight blue for the top and bottom.
Power: 2 X LEM-130s @ 36v, with a couple of NiCad Batteries.
Wheels: Two Aluminium Wheels with a nice layer of Asmaprene Urethane on it.
Armour: 3.25mm Hardox for top and bottom, and 11mm Grade 5 Titanium for the sides.
Top Speed: 13mph
Ground Clearence: 5mm Everywhere.
Turning Circle: Zero! Need I say more?!
Weapon: Ok, the weapon is a nasty 32kg spinning rim, which is made out of 11mm Grade 5 Titanium, with 4 X Tungsten-tipped teeth. (2 teeth on bottom, and 2 on top) The teeth are all made out of hardox, and also curved to rip off skirts and panels with ease. It also runs on a single LEM-130 Lynch, and spins at about 2000RPM. This can rip through titanium and dent hardox quite easily. Heavily Shock-Proofed, as well.
Srimech: Invertible
Strengths: Can cause a lot of damage
Weaknesses: Not the best pushing power by a long shot
Weight: 100kg
Shape: Very low wedge with a Firestorm style wedge extension on the front
Colour: Black Body, Blue Flipper
Dimensions: 100 X 75 X 27
Power: 2 X Bosch 750s @ 36v powered by a couple of NiCad batteries
Top Speed: 13 mph
Tyres: 2 X Foam-Packed Aluminium Tyres with urethane rubber on it for more grip
Armour: 3.25mm Hardox everywhere
Ground Clearence: Zero on the front, and 3mm on the sides, and 5.8mm on the rear
Weapon: The weapon here is a flipper similar to Envy (forward hinged ), powered by 2 X 2kg Co2 Tanks. The power also matches Envy. Its capable of bringing out 30 to 32 flips and can flip up to 900kg. At the back, there is an 8kg vertical disc thats powered by an S28-400. It has 3 teeth on it to rip and tear out skirts/panels, and spins at 5000 RPM.
Sriemech: Flipper. Side spikes can also stop the robot from getting beached.
Strengths: Pretty Good Flipper, Deadly Disc, Nearly Impossible to Get under from front, Decent Pusher
Weaknesses: Limited CO2, as always.
Will: Thanks
Samuel: Thanks as well, but Ive changed the setup. One robot per weight class, thanks (One FW, One MW, One HW and One SHW) Also, Will has already entered Ziggy
Thanks guys
Micrompression, Hyper-Ventilate, Armoured Wedgie & Vertigo
http://www.strickenone.proboards99.com/index.cgi?board=teammmvapourshttp://www.strickenone.proboards99.c...=teammmvapours
