I am serious, it is entirely from my design.
I can borrow things from some bots, so I just combined Laertes body, SHA2s wedge, and a thwackbot axe. It is a new robot.
You never actually answered my question from before...
Why are you still here?
...and WHERE on your vapourbot are the wedges? :P
@ Liam: Because I want to be, and the mods (thankfully) havent banned me. Perhaps it is because I am improving a bit.
@ Kody: The front part of the tracks.
Cyrilium Jr.
Weight: 50kg
Shape: Hydra (S7), but with a full front wedge.
Colour: Silver
Dimensions: 65cm x 30cm x 20cm
Drive: 4x Bosch drill motors, powered by 4x 24V NiCad battlepacks.
Locomotion: 4 fully Vulkanized rubber wheels
Speed: 18mph
Ground Clearance: 0mm at front due to wedge, and 5mm at sides and back.
Turning Circle: 0m, duh.
Weapon 1: a pneumatic axe at 180psi, with a 35mm diameter 300mm stroke ram, that gives me about 250kgs in force. With the Hydra-shaped axehead, it can do some damage.
Weapon 2: an electric lifting arm, powered by a Bosch drill motor, it is usually used for self righting, and can only lift 60kg or less.
Srimech: the lifting arm.
I wish to know weather or not Cyrilium Jr. and Side Swipe have any problems.
You wont fit a pneumatic axe, a lifting arm, four motors and titanium armour that thick in 50kgs.
What would you recomend?
Why do you want to be? And your not to improving at all, your getting worse
Yes, WHY do you want to be here when clearly everyone hates you? :P
To be fair, he has improved quite a bit. Its just his ability at annoying people seems to have increased exponentially...
