Try machining a correct aerofoil into a weapon... not going to be easy!
as for cooling- ill see how hot the motors get before acting... the lipo wont get above room temperature as its the same lipo i use in 360 which pulls way more current and it doesn't get warm.
Worst case scenario ill drill some holes in the armor above the motors to let heat out / let the blade blow over them.
Thanks Sam- its something Ive got to think about myself now lol Ive got an idea in the bag though... after our phone conversation i decided to just bite the bullet and go for a 40mm bearing mounted above the blade.
Removing it from the arena....
It will still be easy to lift it, but ill probably use a small crowbar/ screwdriver the lever it off the floor then slide some wood/plastic underneath to act as a cradle... as im a bit worried about dropping the front blade on my finger (will be very sharp) and having it pulled down onto the floor by the magnet....chopping of my finger.
