Velociraptors Fanfic Tournament - Series 6!
Steve - 2
Overkill - zip :proud:
HEAT G
ROUND 3
REVENGE OF THE REVENGE OF THE BLUDGEONATOR VS Seggy the Third
Basic tactics here - slip around the side n rear and batter the shell a while (lets try and get a few potshots on those wheel guards :proud:). Once Ive got a few good blows in, Ill grapple on and feed it to either the Arena Disc or the Pit.
Go Richie! Go Richie! :proud:
Heat H is coming up, I can tell. Here are my tactics.
Dantomkia (me) Vs Mortis Vs Razer (31) Vs Tough as Nails
Keep away from TaN & Razer, flip Mortis OOTA & maybe pit either TaN or Razer. I gotta keep outta trouble in that fight
Tom, not to be rude, but do you have a memory problem or something? YOU CANT DOO OOTAS!
Oh yeah, well, pit Mortis & then pit of the other 2
I will be using the skirts and the scoop.
Get around the sides, underneath and push into arena disc, walls, pit.
So will the hammer or the interchangable weapons get through to the semis - Revenge Of Revenge Of The Bludgeonator or Seggy The Third (using a steel scoop with a flail)?
3, 2, 1 - ACTIVATE!
Seggy The Third had a faster start than ROTROTB, and turned faster as well, getting behind ROTROTB as it also turned, and then giving it a good shove! ROTROTB fired its hammer, but bounced itself into a sideways position on the scoop, and found itself against the north wall! Firing the hammer again, it whacked the steel scoop and left a dent in it, and bounced itself off! But before it could turn its front into Seggy, the other robot moved and got under its side, ramming it quickly into the pit corner so ROTROTB flew onto Seggys top! The hammer came flying down and bashed the top edge! Seggy quickly reversed and ROTROTB began sliding off, but it landed another hammer strike before it found itself on the scoop again! Pointing itself in the right direction, Seggy accelerated its prey towards the arena disc! Using its hammer to bounce again, ROTROTB went up and caused Seggy to run right past it! It chased Seggy, who stopped, then realised the situation and carried on going to outpace ROTROTB! Once at the south wall, it came charging back, missed another hammer hit and got to the side, proceeding to deliver ROTROTB to the disc and send it bouncing across the floor, on its side and rear! Seggy reversed towards it, hoping to overturn it, but ROTROTB had already landed on its back! The hammer selfrighted it quickly, but it ended up landing on Seggys scoop! Carrying ROTROTB more carefully this time, Seggy took it straight back to the arena disc!
ROTROTB entertainingly skimmed off again, with only scratched armour, but while it wasnt flipped, it did bounce, spinning like a frisbee! Seggy The Third came after it again, and caught it with its wheels off the ground, pinning it against another wall! The pin lasted a while, with ROTROTB firing its hammer twice and managing to shift itself onto the side of the scoop, forcing Seggy to drive it into a corner to keep a hold on it, and tilt it upwards using the wall. But when ROTROTB fired its hammer again, it came down on Seggys body again, and the hammer hit the scoop! A quick reverse from Seggy got ROTROTB off, so Seggy could pin it from behind again! Turning around, it began taking ROTROTB towards the pit release! ROTROTB fired the hammer again, but Seggy caught it as it bounced and carried on, shoving it hard against the release! As they turned towards the pit, ROTROTB tried its hammer once more, but was easily caught by Seggy and rushed into the pit, leaving Seggy The Third the second unseeded semifinalist!
CEASE!
SEGGY THE THIRD GOES THROUGH TO THE SEMI FINALS!
Next time on VFT6, 15th seed The Crashing Bore will show Constrictor, In-terror-fied and Storm 2 that age doesnt always mean weakness!
And 31st seed Razer will have an all-real-robot clash with Dantomkia, Mortis and Tough As Nails!
Nice performance from RotRotB there, I must say :)
HEAT H
ROUND 1
1) Constrictor VS In-Terror-Fired VS Storm 2 VS The Crashing Bore (15)
Storm batters Doms bot and the Bore bashes ITF up to win on a judges decision
2) Dantomkia VS Mortis VS Razer (31) VS Tough as Nails
Mortis gets sent 6 ft under thanks to DTK, while Razer crunches TAN up a bit and casts it into the abyss as well
Top stuff as always!
Not sure about what In-Terror-Fied is like, so Ill go for Constrictor first. Its got plenty of places I can get under safely, and a nice flat top, ideal for latching on to.
Whos controlling Storm 2? Im not suggesting a team up as such as an Ill leave you alone of you leave me alone pact :proud:
My heat will be after this one. And, seeing as everyone ELSE is going for Dominator 2, I might as well join in.
After that, I think Aaron and I should do a team-up on Disco Dancer (I do NOT want to attack Tengu and have ANOTHER bot torn to shreds).
Frank, I control Storm 2, Ill take on In-Terror-Fied while you go after Constrictor. Storm 2 should be able to get underneath ITF from anywhere and should easily outpush it. The weapon also shouldnt do much damage to the Storm 2, so I shall aim for it head on and get it down the pit ASAP. If you havent successfully taken out Constrictor. Storm 2 will come in and help.
And no Chris Mason, this time Im not acting over-confident, all these plans are quite arguable. And if you wanna argue it, please use my new arguing thread. :proud:
Welcome to VFT6, where weve reached Heat H, and are just about to get halfway through the heats, so lets get on with it!
15th seed The Crashing Bore reached its heat final in VFT5, and put up a good fight against Influenza, but took too much damage and lost the 34-26 decision! This old but still tough Vapourbot is a box with a wedge and an extension to help getting under opponents! Its arsenal consists of a jagged Mousetrap-style blade, a drill that comes out of a hole in the wedge and rear spikes that rest along the floor and can be used as a rear wedge! Hard armour, good pushing power and skirts all around will make The Crashing Bore difficult to knock out!
31st seed Razer has an excellent RW record - 1st in RW5, 2nd in RW6, twice World Champion and more! Its VFT record isnt that impressive however - two Round 1 losses, a heat final in VFT3, and it was ripped by Influenza in Round 2 of VFT5! Razer remains a wedge robot with a much-feared hydraulic crushing beak, that has wings on the side to selfright the robot, and a winkler on the wedge to get under just about anyone! Razer has skid steering to make it manouverable, but will its outer wheels, though shielded by guards, be vulnerable to powerful spinners?
Constrictor is a newcomer to VFT, after making its debut in RW7 where Tsunami sent it OOTA pretty quickly in Round 2! Its a low octagon-shaped robot with a lifting arm at the front! Constrictor is invertable, and two wheels give it manouverability, but also make it a bit tricky to control - will Constrictor be crushed?
Dantomkia has been in VFT before but never done that well - a Round 1 elimination by Firestorm 3 and Spin Dash in VFT2, out in Round 2 of VFT3 thanks to Behemoth, and immobilised in VFT4 Round 1 by Demonic Element 2 and MOE! However, it has done well in RW, making two semifinals and beating robots like Chaos 2 with its powerful flipping arm! This uniquely shaped wedge-like robot is fast, and as well as flipping, can spin on the spot to whack anyone who comes too close! Will Mike Lambert impress his children with Dantomkia this time?
In-terror-fied, one of only two Vapours in this heat, is a box with sloped sides and a rounded back. At the front are hydraulic clamping jaws that can produce about 7 tonnes of force, and at the back is an equally hydraulic crossbow! In-terror-fied is invertable, fast at 18.6mph and manouverable, but it has poor traction and well armoured machines wont be too terrified of its weapons!
Mortis has never entered VFT before, but is a golden oldie of RW, having appeared in the first four series and reaching a semifinal, two heat finals and one Round 2! Out of retirement for VFT6, Mortis is a tracked robot with a tanto blade that can hit 3 times a second, and a lifting arm! It can selfright using its weapons, but they are a little unreliable, and its tracks could be vulnerable to low spinners!
Storm 2 is a much respected RW entrant, thanks to invertability,a low wedge,a lifting arm and even more speed and pushing power than Tornado! The box wedge won the New Blood Championship and 3rd World Championship in RW, but lost in the RW7 final to Typhoon 2 (I still think it was robbed!) Unfortunately, its performance in VFT isnt fantastic - it lost in Round 1 of VFT3, was beaten in a close match by Forcepower 2.0 in VFT4 Round 2, and then Leprosy Infection and Wheely Pure Evil teamed up to eliminate it in Round 1 of VFT5! Storm 2 will certainly be fuming, and ready to wreak as much havoc as a hurricane on anyone that crosses its path - but will it succeed?
And Tough As Nails is another real robot that has done well in RW but not in VFT - the top 16 in RW, but out in Round 1 of two VFTs! This Dutch robot is basically a giant pincer with two wheels attached - its favourite tactic is to grip opponents and use its excellent traction to show them where the pit is! But its easily flipped, and its tyres have proved vulnerable to spinners in past VFTs!
First up are The Crashing Bore, Constrictor, In-terror-fied and Storm 2!
3, 2, 1 - ACTIVATE!
The Crashing Bore and In-terror-fied both rounded on Constrictor, as Storm 2 took off into In-terror-fied! Reaching Constrictor and manouvering to get a grip with its jaws, In-terror-fied had to turn suddenly to meet Storm 2 head on! Ramming it in the front, Storm 2 began pushing In-terror-fied, while Constrictor went for the side and lifted it a little, allowing Storm 2 to come right underneath and shove it against the wall! Left alone, Constrictor was quickly attacked by The Crashing Bore, who came straight underneath it and swung its guillotine, which dug into Constrictors top, just missing a wheel! Meanwhile, Storm 2 was already lifting In-terror-fied, taking it into the pit release, swiveling around and dumping its helpless victim in the pit, before returning to help The Crashing Bore with the struggling Constrictor!
The world champion rammed into Constrictors side and shoved, but took The Crashing Bore with it, forcing the 15th seed to release its guillotine! But a moment later, Constrictor was pinned against the wall and on top of Storm 2, and The Crashing Bore moved in to bring its guillotine down again, now burying it in Constrictors left wheel! It proceeded to drag Constrictor off Storm 2, who wasnt happy and came out to rejoin the fun, giving Constrictor a knock. Once The Crashing Bore had retracted the trap again, Constrictor was struggling to manouvre with its squashed wheel, and couldnt escape Storm 2 getting under it again and delivering it back to The Crashing Bore! This time, the jagged blade hit the wheel and the armour as well! Constrictor was pinned for a moment, before being released again and then having the blade brought down on it for a fourth time, causing more armour damage! The Crashing Bore retracted its guillotine, and Constrictor was suddenly driven away by Storm 2, rammed forcefully into the wall and sent ricocheting off! Both robots moved to resume their attack, until it was clear that the guillotine had left Constrictor stone dead! Storm 2 did a fast victory spin, while The Crashing Bore did a more methodical one!
CEASE!
Constrictor and In-terror-fied are eliminated!
THE CRASHING BORE AND STORM 2 GO THROUGH TO ROUND 2!
Now VFT6s only all-real-robot melee, featuring Razer, Dantomkia, Mortis and Tough As Nails!
3, 2, 1 - ACTIVATE!
Razer came straight towards Tough As Nails, who was wheeling towards Mortis, along with the faster Dantomkia! Once Dantomkia was there, Mortiss tanto blade began whacking away, leaving scratches along Dantomkias side until it had overturned Mortis! This provided the perfect oppotunity for Tough As Nails to capture Mortis as it was selfrighting and try to snap the tracks! But Razer was now approaching from behind, forcing TAN to turn away from it, but Razer also turned and prepared to crush the rear ram - until Dantomkia suddenly attacked TAN and Mortis and flipped them on top of Razer! Tough As Nails quickly turned itself off Razer, still gripping Mortis, and as the 31st seed was following it to attack, Dantomkia attacked faster and flipped TAN again, then began running it towards the pit release! As it was turning the TAN-Mortis complex around towards the pit, Razer seized its moment, gripped TANs claw in its own, and dragged it off Dantomkia! Dantomkia quickly followed and lifted the three-robot-group, taking them back into the pit release! Razer was quick to release its grip on Tough As Nails, which allowed it to attack Dantomkia, biting into the shell and carrying Dantomkia away! After a bit of struggling, Tough As Nails touched the floor and quickly took Mortis to the open pit, finally releasing its grip on the RW veteran and removing it from the melee!
Razer had taken Dantomkia to the arena disc, and successfully caused more damage with it, gashing Dantomkias rear! However, once Tough As Nails appeared on the scene, Razer released its victim and charged towards the Dutch robot, trying to get to the rear, but TAN was turning quickly as well! As they turned around each other, Dantomkia advanced to attack Razer side on, and successfully flipped the former RW champ! Tough As Nails quickly took advantage, gripping Razer before it could right itself, then started trundling to the pit release with it, but Dantomkia charged from the rear and took it to the release faster, flipping it against the wall! TAN began using its large wheels to come off the wall, but Dantomkia caught it again and rammed both TAN and Razer into the pit! With Razer and Tough As Nails pitted at the same time, the match would have to be paused!
CEASE!
Razer and Tough As Nails were removed from the pit, and all three robots were returned to their starting positions.
3, 2, 1 - ACTIVATE!
Razer and Dantomkia both advanced on Tough As Nails, who turned towards Dantomkia! Dantomkia met it in the front and fired the flipper to overturn TAN before the claws could come together! Razer arrived on the scene to grip TAN, but Tough As Nails was able to turn quickly and they ended up parallel to each other - and fair game for Dantomkia, who flipped Razer on top of TAN! A quick shift from Tough As Nails brought Razer into the claws again, and TAN just reversed into the pit release, then carried the 31st seed to the pit! Dantomkia cautiously followed, waited until Tough As Nails had dropped Razer into the pit on top of Mortis, then rammed it in as well, before jumping in itself just for fun!
CEASE!
Razer and Mortis are eliminated!
DANTOMKIA AND TOUGH AS NAILS GO THROUGH TO ROUND 2!
Heat H, Round 2:
The Crashing Bore (15) vs Tough As Nails
Dantomkia vs Storm 2
Yes!! Im through, my tactics:
Dantomkia (me) Vs Storm 2
Storm 2 is to keep away from the front, get underneath the side & pit it immediately!!
Great, now Im back in action! :)
Storm 2s Tactics:
I should be able to slide in underneath Dantomkia from anywhere, so get underneath Dantomkia from any angle, and quickly get him down the pit. I should be able to accelerate before Dantomkia gets away, therefore being able to get this done. :)
Nice fights... Surprised I didnt get bloody Razer again:proud:
Against TAN... Not too worried, which means Im going to lose:proud:
But seriously, CB may not have anywhere near Storm 2 type power but I should still easily out-shove Tough as Nails. My main target will be to go for the wheels, and try to use the trap to pull his tyres off which will allow me to easily pit him. If he grabs hold of me, Ill shove him around like Storm 2 did in the WCs, and constantly batter the top with the trap. Im not expecting to damage the Hardox much, but my aggresion points should shoot up and I might spark off TANs electrical problems.
For tother fight:
Storm 2 cant get under Dantomkia from anywhere as it hasa 2 mm clearence at the front. Check Storm 2 out on telly, you can see it. If Datnomkias tactics are clever they could win, but Im expecting Storm 2 to bully the fight.
But Storm 2 easily slid under Firestorm in S7.
From the side. From the front it went straight over the top.
Seeing as I cant see RW7 on TV (I dont live in England or anywhere near that), Im not a genius when it comes from these things.
HEAT H
ROUND 2
1) The Crashing Bore (15) VS Tough as Nails
The seed to grapple onto TAN (maybe busting the jaws ram if its aims good) and shove it into oblivion
2) Dantomkia VS Storm 2
Storm to slip under DTKs side and cast it to the screaming void
Nice stuff as always, Richie. Cmon, the realies! :proud:
Hitting the ram with the traps going to be impossible. Maybe the drill can hit it, but Id have to get TAN from behidn so perfectly its not feasible.
DTK to flip Storm out the arena
TAN to bore its claws into the bore :proud:
TAN doesnt sem able to do much damage to stronger armour, and its got grippers not claws. You suck :P
Knightrous, DTK cant flip Storm OOTA.
I think DTK to flip Storm onto its back early on and into the pit.
The Boro to have a good shot onto Tan and remove the aerial.
Plenty of predictions, but which ones were right?
Frank, I may have seen a slight gap between Storm 2s wedge and the floor, but it did get under Firestorms front at least once (there might have been a second time, but it was hard t judge).
Four successful robots in Round 2 - will The Crashing Bore be tough enough to shatter Tough As Nails?
3, 2, 1 - ACTIVATE!
The Crashing Bore came straight towards Tough As Nails, who turned into it and clamped the claws together on the wedge and side, without a particularly good grip on its opponent! It began trying to drag The Crashing Bore towards the pit, but The Bore pulled back - this went on for a few moments, until TAN started pushing instead, taking The Crashing Bore round in a circle until the other robot pushed back against it and a back-and-forth contest resumed, where The Crashing Bore was gaining a slow advantage! Finally, TAN released and swerved into the 15th seeds side before the guillotine could come down on it! But The Crashing Bore suddenly reversed, and Tough As Nails was bashed by the blade a second later, hit in the claw and left tyre! The Crashing Bore began dragging TAN, trying to take the tyre off, and succeeding in ripping it! Once the guillotine was retracted, Tough As Nails scarpered, but its wounded wheel slowed it down and The Crashing Bore caught up, attacking with the blade but only hitting the claws again! It retracted, swung, and just glanced the left tyre!
Tough As Nails turned around into The Crashing Bores side again and gripped it - The Bore swung its guillotine but missed! However, it could drag TAN more efficiently now, so TAN released and aimed to ram The Crashing Bore in the side, but The Bore caught it and buried the blade in the right tyre! It pulled, ripping the tyre even more, and then shoved Tough As Nails across the arena into the disc, to cause even more damage to the wheel! The 15th seed then released, and TAN retreated, its right tyre flailing, and as The Crashing Bore rammed it again and struck the claws, it came off! The Bore gave TAN an ineffective prod with its drill, then turned and managed to hit the left tyre with the guillotine! It tugged on it, then released, and shoved the crippled TAN into the wall as the left tyres rubber also flailed! TCB just brought the guillotine into it again, and as it retracted, the rubber came away! Its wheels now barely touching the floor, Tough As Nails couldnt avoid The Crashing Bore carrying it into the pit corner and giving it a good hammering with the guillotine! A few hits struck the claws and did little, until another hit the left wheel, and bent and immobilised it! TCB reversed to survey its handiwork - TAN was now barely mobile! It aimed to hit the right wheel - and the guillotine went into the floor instead! Releasing, The Crashing Bore repositioned and managed to hit home, disabling the wheel and leaving Tough As Nails immobile, apart from some jerking of the claws!
CEASE!
THE CRASHING BORE GOES THROUGH TO THE HEAT FINAL!
Two realies fight next - Dantomkia and Storm 2!
3, 2, 1 - ACTIVATE!
Both robots rushed out of their squares and turned to attack the sides of the other! With a long swerve, Storm 2 managed to bring its wedge into Dantomkias side, and then run it towards the pit release - except it wasnt quite pointed in the right direction and they hit the wall! Dantomkia tried to get under Storm 2, but the World Champion intercepted it and rammed it in the side-rear - they still werent facing the right way, so it activated its arm and managed to lift Dantomkia so it could bring the wedge underneath, then turn around and run into the release without Dantomkia escaping! A very fast rush to the open pit sent Dantomkia almost flying into the abyss, and Storm 2 almost running in itself, in one of the quickest battles of VFT6!
CEASE!
STORM 2 GOES THROUGH TO THE HEAT FINAL!
Heat H Final:
The Crashing Bore (15) vs Storm 2
If Id lost I could have made the prediction that a real robot will win. But I won, so I cant. Darn you:wink:
Anyway, I can get under Storm 2 from anywhere, so Ill keep the front pointed at him at all times, and take him for rides into the arena disc. If I can get him on the wedge right I should be able to drill through his wheels which will be a nice bonus:)
I think that the old, worn out, dreary robot will win, as it has the more experiance.
Oh crap, Lets hope this isnt a repeat of the 72-1 match between the two teams.
Storm 2s Tactics:
Try and get a push from anywhere, except for the front, and get it down the pit as quickly as possible, but most importantly, try not to lose. :wink:
Oh yeah, I forgot about that result.
Chris, youre on thin ice here:proud:
Dont you mean Im on thin ice?
Well im definitely on Thin Ice. Mmm, minty fresh breath:)
Fact: Did you know Razer tried to crush TANs wheel and started bending the arm with out any damage inflicted to the wheel. Bit late to say it, but the Bore doesnt have the power to damage TANs wheels, only rip tread off if it was lucky.
Still a nice fight though, just a tad down on the techy side :P But your forgiven!
Storm II VS The Bore.
Im going with the Bore here, Frank only has to keep the front pointed at Storm II and Storm II will drive itself into the trap, ready for Frank to put it down the pit :proud:
Im surprised. TANs wheels dont look as sturdy as that. Whatre they made of?
They are HDPE with track race tires screwed onto it. Just asked Kos himself :) I also appologise, the Razer story didnt actually happen :sad:, obviously my sources were wrong, so I retract my statement from above.
On a similar note, Kos told me Kan Opener had a go at the wheels and managed to slice them a bit and TAN was still able to drive afterwards.
Note to self: Find the owner and ask first before posting!
Sorry, Aaron (and Kos if youre reading). Id just watched the Storm 2-TAN fight to see if the wheel could still touch the ground with the outer part taken off, and the wheel with its outer bit removed didnt look particularly strong.
The first semifinal is about to be filled - but will it be The Crashing Bore or Storm 2 who fills it?
3, 2, 1 - ACTIVATE!
The Crashing Bore had a slower start than the nippy Storm 2, and tried to turn and face it as it turned, but Storm 2 managed to keep ahead of it! Both robots turned until Storm 2 reached The Crashing Bores side and crashed into it, ramming TCB against the west wall! It couldnt get its opponent to the pit from there, so it released, and immediately The Crashing Bore swerved in reverse and caught Storm 2 on its wedge extension! Before Storm 2 could drive off, TCB swung its guillotine and dug into the front! As the rammer struggled to escape, TCB took it to the arena disc, which hit its rear, scratching the titanium armour! For its next move, the 15th seed rammed Storm 2 against the wall and retracted the blade, before moving forward so Storm 2 was on its wedge! The drill came out, pounding Storm 2s underbelly and leaving a mark along it! After a few painful drills, Storm 2 was being knocked onto the side of the wedge, so The Crashing Bore turned to get it back on - but this allowed Storm 2s wheels to touch the wedge and it zipped off, still alive and running away!
Spinning around, Storm 2 came back towards the advancing Crashing Bore, who fired its guillotine but only hit the floor! Before it could make a move to catch Storm 2, the RW7 runner up was at its side and pushing it around in a curve, finishing at the wall close to the pit release - but again, TCB was side on to the wall, and Storm 2 couldnt shove it to the release without pushing from the dangerous front! So Storm 2 turned away, avoiding The Crashing Bores attempt to get under, and reversed into the release itself. The Crashing Bore started retreating, still keeping to the wall, so a frustrated Storm 2 attacked from the rear and showed it what the arena disc felt like! The disc spun The Crashing Bore around so Storm 2 could ram it from the side, and take it close to the pit! Moving to the rear of the Bore, it shoved, the Bores wheels dangled over the hole of doom - and it closed! Storm 2 angrily rammed The Crashing Bore against the wall, driving to get under its rear skirt but failing! After pinning the 15th seed for a while, it rushed back to the release in reverse, while The Crashing Bore made its escape again, keeping close to the wall! As Storm 2 came rushing back in, TCB turned to meet it and brought the guillotine down, this time striking Storm 2 in the front wedge! But it was Storm 2 who had the advantage, dragging TCB away from the wall, so it could move it towards the pit!
Quickly, The Crashing Bore released its guillotine and charged at Storm 2, attacking with the blade again, but missing! Managing to drive around TCB again, Storm 2 took it into the north wall again, as the pit closed! Storm 2 released its grip, and The Crashing Bore turned towards it, but this exposed its side to a ram! Curving as they went, they hit the wall just south of the release, and Storm 2 could swerve to hit it, but The Crashing Bore turned to attack it! Storm 2 ran past the front, and was almost caught on the wedge, but drove off! Reversing, it pinned the 15th seed against the wall again, then swerved to get its front into play! The Crashing Bores attempt to run didnt come quickly enough, as Storm 2 finally rammed it down the pit just before it closed!
CEASE!
STORM 2 GOES THROUGH TO THE SEMI FINALS!
So were now halfway through the heats, and have half of our semifinalists:
*MANIC MONSOON, seeded 3rd, entered by Daniel, this rammer/lifter beat Cholera, Slammer IV, Growling Storm 2.5 and Whirligig 4.0!
*TEMPEST EVIL-ER-UTION, seeded 5th, entered by Frank, this ring spinner beat Bender, MOE, Not Another Pushover 2 and Hacked Off Ha-ka!
*PSYCLONE, seeded 17th, entered by Andy, this full body spinner beat Pulveriser, Voltronic, Biohazard and The Disc 4!
*ACHILLES, seeded 25th, entered by Alex, this lifter beat Chip, Hefty Kick In The Balls, Juggerbee 3.0 and SOR 4.0!
*WEDGE DEVOLUTION, seeded 27th, entered by Steven, this flipper beat Blizzard, Happy Birthday Party Pooper, Wedga Revo and Glasgow Kiss!
*ORKA MK3, unseeded, entered by Chris, this lifter beat Cuffy, Pink Panther, Disco 5 and Windiest Killer Just Got Windier!
*SEGGY THE THIRD, unseeded, entered by Dave, this interchangable robot beat Wheely Pure Evil 2, Deep Impact 2, Baldur and Revenge Of The Revenge Of The Bludgeonator!
*STORM 2, unseeded, entered by Matt Macdonald, this real life rammer beat Constrictor, In-terror-fied, Dantomkia and The Crashing Bore!
Next time on VFT6, 16th seed Push-Ish will give Dallas, Nightmare and The Ultimate Wedge the old heave-ho!
And 32nd seed Leprosy Infection will try to infect Disco Dancer 2.5, Dominator 2 and Tengu VI!
5/8 Heat Winner predictions correct. What, no trophy? :proud:
HEAT I
ROUND 1
1) Dallas VS Nightmare VS Push-ish (16) VS The Ultimate Wedge
The seed dumps Dannys spinner, while TUW deals Nightmare the same fate
2) Disco Dancer 2.5 VS Dominator 2 VS Leprosy Infection (30) VS Tengu VI
Chris chews up Dominator, while Alex permanately cripples the Disco Dancer
Halfway there, Richie! Dont stop now! :proud:
Ill just state once more...
LEPROSY INFECTION
I read that the other two are teaming up to get rid of Dominator 2. So, why not? Ill go for him too.
Then, Id like to form a team-up with Tengu VI to get rid of Disco Dancer 2.5.
That way, the seed will go through, and the fav for this heat (well, MY fav anyways) will go through with it.
Aaron, want to gang up on the other robots in the melee?
If not, head towards Nightmare, and give it a lovely push into the wall. Hmm, torque.
I will team up Chris, always lower the odds is my view.
Hell yeah Dave, Im up for some teamin! Nightmare is mine. Im going to reverse into it and use the back to slow down the disc before it gets up to speed to quick and then get under it and hopefully push that weird shaped robot into the pit :proud:
Question To Richard: Is this the version of The Ultimate Wedge where I had the dual flysaws or the HP Flipper, its been soooo long I cant remember :proud: Coz if it is the flipper version, Ill have a go at flipping Nightmare like Biohazard did.
