Featherweight Database
Yeah JH-Q has been pestering me with the progress (joking) of this bot for awhile now. I really like the use of the 24v dewalt and I would try this out if I hadnt had invested in my Ev Warrior and actuator collection lol.
Anyway good luck with the event and I hope that drive works fine for you, last time we spoke it was having some trouble steering but it looks like you may have sorted that out with the mini wheels.
Wish it could come to the Uk for a drum bot battle. All the best of luck for the weekend.
Chris - http://www.featherweights.org/forumBreak
won the event, 3-0... two knockouts (:proud:) and at finals managed to flip the opponent over. :)
some damage: http://www.robosota.fi/funktiot/naytarobokuva.php?roboid=77http://www.robosota.fi/funktiot/nayt....php?roboid=77
and updated pic on profile, i ripped that aluminium skirt off this robot at finals: http://www.robosota.fi/index.php?sivu=robotit&robo_id=90&toiminto=robottihttp://www.robosota.fi/index.php?siv...iminto=robotti i got it as a trophy, woooo! ill get a pic of bot internals probably this evening and upload video as soon as i have time to edit it.
got vids about the event: ftp://ftp.edome.net/media/robosota/Model%20Expo%2005ftp://ftp.edome.net/media/robosota/Model%20Expo%2005
its 61mb big for anyone with 56k
Wow just seen the video ... you have a killer there JH-Q
Youre right there - I dont mean to be heavy handed and all but I wouldnt want that robot running in that arena (note my use of inverted commas) anywhere near where I am.
Now Ive watched the rest of the vids I wouldnt want to be near it with any robot running in it PERIOD!
is it in an ice rink?
Its dam good though, well done on an impressive machine!
Karoline, luckily audience was behind 15mm polycarb/steel net at this event, bad thing was that roboteers didnt have that shield because it would have been too difficult to drive so far away. at next event audience doesnt have any shielding so i drop HCs rpm to 450. (and the weapon HAS a failsafe to prevent a runaway robot killing people)
JH-Q you have re-sparked my want to build a drum bot i have been drawing plans for ages and the result is .....Void.....
Ah I must have missed that bit on the video edit when you activated the failsafe, and removed the link before picking the robot up from the middle of the arena floor. BTW it was a very clear picture taken through the 10mm thick polycarb walls required for an arena to safely run spinners in the UK, but you are in Finland so perhaps it wasnt there.
BonX is ready
http://home.hccnet.nl/h.bouwens/Test1.avihttp://home.hccnet.nl/h.bouwens/Test1.avi
wow very good Tim , i really like the lighting Lol
got kang done for its event, here it is done -
http://photobucket.com/albums/v357/Cobrarobotics/Kang/?action=view¤t=DSC01449.jpghttp://photobucket.com/albums/v357/C...¤t=DSC01 449.jpg
and here it is after it got smashed in wouldnt you know it, the only weak spot...
http://photobucket.com/albums/v357/Cobrarobotics/Kang/?action=view¤t=DSC01456.jpghttp://photobucket.com/albums/v357/C...¤t=DSC01 456.jpg
that 10mm 5083 doesnt work too well :s
i ended up refitting it with an IBC too in the end.
Just finished rebuilding DragonStrike Dragon 2 and Tiamat. DragonStrike is the spinner the only diference is that the top and bottom is now 3cm thick high impact plastic instead of 6mm Ali. Dragon 2 is now 4wd with 18v drill motors. The bottom is 4mm Ali the top is 4mm polycarb and 1.2mm Ti. The sides and rear are 2cm Nylon the front is 2cm Nylon and 1cm Ti. Tiamat is a full pressure Flipper (courtesy of Mario). The side armour is 2cm Nylon the rear is Polypro.
Pics on profile.
Tony
All looking very nice - I love the new Dragonstrike paintjob
Ill join Ewan in that - looks fantastic Tony, most people are happy to have a box that moves - the dragon robots always look fantastic though !
Ed
After 2 years of me saying i will.... Its Done!!!!
Alpha MX
Drive: Bosch 120watt (300Peak)
Battery: 12v BotPack (soon to be changed)
Control: Vantec RDFR23
Armour: 3.2mm Ti
Weapon: 3.2mm Hardox Wedge (with spike!)
Status: Done apart from a few little things to be done for the Winter Tour
Pic on Profile
http://www.blazerbotics.co.ukwww.blazerbotics.co.uk (will update next week sometime)
looks crap :):):):)
nah looks ace
Nice deadly-looking spike there Alan, and liking the slanted sides too.
Looks great. :)
Lenny
Just putting the final touches to DB5, the weapon should be done in the next week. When it is done will put a video on the web site, it should in theory have about 4KJ if I can get the speed up to 8000rpm. Looks like an Astroflight.
Ed - Team Turbine.
Robot- EL Diablo
Speed- ??
Power- NIMH
Drive- 4x drill motors
Weapon- pusher
Aromour-???
Just finishing the rebuild of Dragon2 Drive 4 18v drill motors run at 24v. Armour front 20mm nylon and 10mm Ti. Sides and rear 20mm nylon and 4mm Hardox. Bottom 4mm ali Top 3mm poly and 1.2mm Ti. Now to put together the new sorry the 2 new spinners.
New picture on profile of the new DragonStrike on the left. Kishar on the right. Will be Ready for this weekend.
Oh bloody hell! I hate spinners! :wink:
Pleh!
(Message edited by Robotic_Ants on October 26, 2005)
Just tested the disc on DS scary very scary
Having had no end of problems with microCHIPs drive motors Ive now gone with drill motors. Im fitting in a pair of James Coopers drill motors. So far so good. Ive also mounted the big pulley on the hardox disk. See profile pic
Rob
like the polycarb milled bulkheads
Soon we could have a rumble with only robots using Christians Hardox disks...!
MicroCHIPs looking very swish Rob, btw what was the drive motors ment to be before you changed to the drill motors.
Chris - ^_^
window motors Chris. They were heavy and hard to secure to a wheel and a bit slow.
Rob
Ah its all the best youve fitted some drill motors then. Im keeping an eye on the Team Whyachi and the cheaper BaneBots planetary gear motors but for the moment im sticking with my own modified drill gearboxes.
Chris - ^_^
Just getting the parts together for my next feather. drive 2 EV Warriors Just ordered a Sidewinder got some hardox for the front scoop rest of body 20mm nylon.
How did the HTI spinner do at XFM Colchester tony?
The disc worked great it cut a 1mm deep hole in my 4mm hardox on Dragon 2 with 1 hit. But he had drive proplems so did not do well spent most of the time trying to fix the drive. The HTIs worked great he controlled it with a 30amp Elextronize with external relays.
