Gradually welded to avoid distortion. Worked this time!
Both shoulders complete and in position
Second arm bent and ready to be welded
Arm end plates welded on
Both arms all welded. Predator looks great from this angle!
Turning the bearing mount for the head in the lathe
Bearing hole almost finished
Bearing plate with part of the cradle attached
Front of bearing plate drilled and taped ready to be bolted on
Almost finished with bearing pressed in.
