Re: Crash & Burn: Mini-Tournament of Death 3
REVISED TACTICS:
Okay, both of our robots are invertible. That's fair. The downside for me is that I don't have an active weapon, which is okay. The upsides for me are tougher armor, 0 ground clearance at front and back due to my scoops, and better pushing ability. I will not give him a chance to get under either the sides, and will keep the front or back towards him at all times. I will still try to exploit the side and rear ground clearance, and use my pushing ability to ram him around and into the pit. Once again...
If I feel that I can't push him in without suffering major damage/being pitted myself, I'll shove him into one of the house robots. Only after I feel he's been worn down to near-immobilization will I pit him.
Reposting so you don't forget.
Finally, we see the end of Round 1! Let's get it over with!
Eliminator 8
Minesweeper 1.1 vs. Next Stop, Jupiter
Minesweeper 1.1 is a vapourbot by Mark Elam...question is, will it sweep away the competition, or itself be swept away? Box shaped, invertible, 4WD, and bare bones tough. Quad S28-400 MagMotors power it, and it's armoured in a 5.5mm Hardox monocoque. The main weapons are the front and rear scoops, freely hinged and can work invertibly. However, they don't really do any physical damage, and invertible scoops aren't exactly the most leveraging of weapons...
Next Stop, Jupiter is the bassa' child of Phrizbee and Hexadecimator, and actual son of retired bot Thanatos. Basically a Warrior SKF clone with Hardox and Ti/V armour and Bosch motors powering an invertible 4WD. The trademark rim-powering-flipper set-up is there too, on par with the actual Warrior SKF's power levels. However, being a clone, it shares Warrior's weaknesses: the flipper can't work if the rim won't work, and it's relatively unstable.
Roboteers, stand by...
House robots: King Leer, Hexadecimal
3...
2...
1...
ACTIVATE!
Here goes nothing, eh? The last two are willing to give it all, and right off Minesweeper is across the arena, bashing into the incoming NSJ, but unfortunately for Mark NSJ's own momentum and great leverage advantage has its flipper easily defeat the invertible scoop of Minesweeper, and Samuel wastes no time in tossing Mark's bot onto its head...in a 540! Even less fortunately for Mark he lands side-on to NSJ, who proceeds to get under Minesweeper again and launches it across the arena! Being invertible, Minesweeper will always land on its wheels, and proves so by spinning about, but Samuel has scored quite a few points early on and Mark has to catch up quickly, should it go to a judges decision! Minesweeper hurriedly moves back in, and deftly swerves around another charge from NSJ, so getting to the sides of it, but in doing so is greeted by the spinning rim, which cuts into the scoop!
CRASH!!!
And Minesweeper is sent spinning away, straight over the saws which pop up and - BZZT! - cut into the underbelly! Doesn't seem to have done much damage, however, and Minesweeper moves in again. This time, NSJ can't get enough speed to power under Minesweeper and the scoop bashes into the flipper; neither can get under, but Minesweeper's power advantage comes into play alarmingly fast, pushing Samuel's machine back, and into King Leer's CPZ! The powerful house robot pushes back, catches the rim with its wedge and deflects NSJ onto said wedge, pushing it back into Minesweeper. Minesweeper is forced back by Leer's immense drivetrain prowess, but keeps pushing itself against NSJ, unwilling to leave it alone should NSJ escape the king of the DarkZlayerz. Hexadecimal watches greedily from her CPZ as King Leer pushes both robots all the way across the arena towards her CPZ, and Mark realizes what's going to happen, before it does! ...or does it? No! To Mark's intense relief, he is able, just barely able, to extract Minesweeper's scoop from against NSJ's side and scoot his robot away, as King Leer reaches the CPZ of the chaotic queen! Samuel watches on in horror...oh this can't be good!
CRASH!!!
A monumental CRASH later and NSJ is blasted onto King Leer's front by Hex's deadly blades, landing directly on top of the wedge of Leer, in a shower of sparks; Minesweeper waits eagerly nearby, but apparently no damage has been done to NSJ, either...however that doesn't help its situation right now! King Leer's blades can't reach right in front of him, but NSJ is pegged in there and he's helpless! Possibly assured by Samuel's frightful position, Mark goes after the pit release and hits it, lowering the pit, then comes back. But during this Leer has slammed NSJ further into Hexadecimal's CPZ, and Hex is lifting NSJ off the wedge...and he's away! Minesweeper is thus met with a colossal ram to the scoop; such momentum is carried by Samuel's robot and it easily gets under Minesweeper...and he flips Minesweeper, though not as high as Samuel hoped due to NSJ's rim not fully spun up. And this works in Mark's favour as Minesweeper recovers quickly and rams into NSJ before the latter can lower its flipper...and now the pit is in line! A determined gleam in Mark's eyes, he guns Minesweeper's motors to their highest output and pushes NSJ back! NSJ tries to turn backwards but it's too late and NSJ goes over the side edge of the pit, just enough so that it falls in moments later! Perhaps it's the shock of actually winning its match, but Minesweeper drives in moments later! :proud:
CEASE!
Next Stop...well actually, there ain't no more stops for you besides the pit, Samuel. :proud:
Minesweeper 1.1 advances to Round 2!
Well well well, we have 8 competitors, and 4 spots left into the semi-finals. Let's see who'll fight for those 4 spots, shall we? ;)
Round 2
Gabriel V vs. Qwertyuiop
Minesweeper 1.1 vs. Envy
Mornington Crescent vs. Monsoon Season
Apocalypse II vs. Under Pressure
Tactics, predictions, the usual. :)
Well, that was unexpected...
Gabriel V. Qwertyuiop, though it beat Lethal Weapon, will lose here.
W00T!!! I won my first fight!!! Against a good robot!!! In a Kody Kunz Mini-Tourney!!!
Anyways, my plan will be to get underneath the back of Envy. The shape's a lot like Firestorm, so there is an area at the back where I can get in. If he flips me, my other scoop will prevent him from getting under me again. Press the pit release button, shove the machine into the house robots, and after he's seriously damaged, pit him.
Good luck, Shane.
I'll say Mornington Crescent. With 2 rims, 1 has to hit Monsoon whenever he tries to get in.
Probably Apocalypse. However, if Under Pressure can get underneath at the beginning, then Martijn will win.
To get to the rear of envy is difficult in itself as envy has a very good powerful drive and will always face its opponent... to get under the front of envy is also difficult too as 80% of envys weight is in front of the wheels. your invertable wedges will only hug the floor under their own weight so envy will win the war of getting under the robot... You will be flipped to the edge and oota. If by some miracle you do get under the front of Envy you will have to lift it quite high to lift its wheels off the ground....envy will simply reverse off. I predict an Easy win for Envy Mr Elam. :)
Oh and good luck
*Cough*Are those supposed to be tactics?*Cough*
And let me remind you that your Powerful drive isn't powerful in the world of vapours. And that I will use my super-powerful drive to ram you into a house robot. And that I will watch in glee as your 3.25mm hardox is seriously damaged by whatever house robot there is. And that I will press the pit release button and shove you down. And they're invertible scoops. And you're only making those statements since you've fought realies that don't have the super-drive, super-armour, and super pushing power that Minesweeper 1.1 has(18hp to 6 hp).
And I wish you good luck also.
With all due respect (or lack thereof), Mark, you may not realize this but your above post was extremely arrogant and ignorant.
Ahhhhhhhh Mr Elam you seem to think i know nothing of vapourbots. you dream on about your s28 mags....they are simply not made for heavyweight robots.....in the real world c40 300 are better than the s28. Equate that to the world of vapour then surly the c40 would be the better more powerful drive....add everything else i have said and your on a looser on every count.
good luck Mr Elam
My apologies to Shane, Kody, and anyone else offended by that.
REVISED TACTICS:
Major Points:
Minesweeper 1.1:
4x 24 S28-400 = 18hp
6mm Hardox
2 9mm Hardox scoops
Envy:
2x C40-300 = 7.6hp
3.25mm Hardox
Co2 low-pressure flipper
According to this, I have more horsepower and tougher armour then he does, but he has an active weapon. I will use my 18hp of drive to shove him into a house robot, and watch in glee as (Insert house robot name here) damages his armor. I will open the pit release button while he's damaged and will shove him into the pit the moment he exits the CPZ. I will use my superior HP to ram him around the arena if he refuses to go down, and I will hope that something breaks. If something does, then I will pit the crippled realie and relax.
Gloat/Make excuses depending on outcome. :proud:
Its hard to explain but your super doooooper18hp drive is next to useless.......remember you only have 100kg of weight. 18hp will simply wheelspin. there is not enough weight to get the power to the floor. the c40 geared like i have will have all the low end torque to out push your wheelspinning robot all day. Thats if your s28 dont overheat and burn out. and thats if my front end doesnt get onder your light weight thingies you have which it will. how can you out push envy if you are riding up my scoop. Flip.....bye bye Mr Elam.
