How do I connect my 5/2 valve to my battleswitch?
I assume that the 5/2 is a solenoid valve with a coil on, probably has got three pins on. Use the two pins that are opposite to each other to connect to the outputs on the battleswitch I guess.
Cant really be more helpful, never used a battleswitch and dont know what valve you are using.
As Ed said ...solenoid has two opposite pins use them and ignore the third.
Battery + to battleswitch
Battery - to valve coil
Join the spare connections of the solenoid and the battleswitch.
Thanks,so the 5/2 valve then goes to the ram?
http://www.teamdavinci.com/understanding_pneumatics.htmhttp://www.teamdavinci.com/understanding_pneumatics.htm
You might eventually find my webpage on pneumatics flow useful.
http://www.teamonslaught.fsnet.co.uk/pneumatics.htmhttp://www.teamonslaught.fsnet.co.uk/pneumatics.htm
Thanks Woody,your site was very helpful.
Where can I get a dump valve from?
http://www.airlines-pneumatics.co.uk/webcat/Detprod.asp?ProductCode=S070103http://www.airlines-pneumatics.co.uk...ctCode=S070103
Uber quick reply Woody.
