Already written your run, sorry Kody.
BTW, due to unforseen circumcisions, the posting may have to be delayed.
Unforseen circumcisions? *raises eyebrow*
4D61796265206865206C6F6F6B656420696E20746865206D69 72726F722E2E2E00
*presses doorbell*
A message from Clover:
Gamma Trident shall team-up with Disco Dancer and attack QJS.
Splitz: Ramthrax is a wedge rammer, no? So just be aggressive as possible.
Kick in the Teeth: Spin up and slice and dice.
She Loves You: Not sure what to do here. Possibly just hack the top of
Wrecktangle.
Balderdash: The path that has the pit, and try and get out of the HBs way.
The Spin Factor: Again take that same path.
Divide and Conquer: Axe them all.
13 Black: Again spin up and attack.
Odysseus 2
Lift the harpoon up and the whoel robot rocks backwards giving me ample clearance to clear the ramps
Tengu 6: hmm.. prehaps the trickiest; i spose realistically if i went for the maze i could just smash my way through it bu i think the opposote path would make more sense
Slammer V
If I equip say the lance my clearance at the fron is ample to get voer the middle ramps.
Splitz v Ramthrax 2 (11)
Dunno what its like so slam it into the walls till the cows come home. or soemthing like that...
Battle Raptor 3 v HtBP 3 (24) v Swwet Children O Mine v Stalker
Go for either whomever has the weakest armour on top and bludgeon them.
My massacre enterign robots should hold there own in there due to there design, you cant really tactic cuh fights cos there too unpredicatble, if i can last til later in the fighr then i should be able to do well
Whats wrong? I thought this tournament had started :sad:
*feels sorry for Matt*
Yeah, I was wondering when this tournament was gonna start. Whats up, Mr. Fowler? AJ stealing your shorts? :proud:
WTFH?! :S
If you can remember back about 24 hours this tournament has moved forums, too see it you must go and sign up. :P
I wont warn you from now on unless appropriate, but the gauntlet is up. You wont be able to read it unless youre a member.
http://fvagroup.proboards39.comhttp://fvagroup.proboards39.com
If thats the case...
Announcement from Dave
I do not wish to continue in this tourney if it is moving forums, so I€™m redrawing my vapourbots from it at immediate effect.
Thank You
Dave S
