Yeah, and whether or not they do compete depends on whether or not Jordan can get his stats in.
yeah i hope he does i want to see my bots go crazy and have fun
You two thought of getting msn messanger :rofl:
and having that long a list of robots on the left panel seriously makes the forum look stupid...
I would, but it says I need an adult to get on.
i cant anymore cos it says i have to install a new one ( or should i say download) :shock:
Why don't you just download the new one then? :lol:
seriously though why bother listing all your vapourbots in the robots section? :? It does make the forum seem a bit stupid, even from a vapourboteer/fan 's point of view :proud:
I have to agree with Liam there, sorry :P I've got loads of vapours - I still have updates planned for them should they require them - but I don't list them with the altogether more real ones as it'd make the forum look silly.
If you can't MSN, maybe stick with PM's :)
Here is my second vapourbot for your perusal, what does everyone think?
Weight: 90 kg
Shape: Conical Frustum (truncated cone)
Colour: Green, White and Gold (well orange)
Dimensions: 77cm * 67cm * 11cm
Drive: 2 * C40-300 Magmotors running on 26.4 V with 8 * 10 cell A123 ANR26650M1 battery packs
Locomotion: 4 * 12 cm diameter 5 cm wide titanium hubbed wheels with rubber coating
Armour: All over hardox (10 mm forks, 10mm shell, 5mm base and top)
Speed: 15 mph
Ground Clearance: 0 cm at the front under forks, 0.5 cm elsewhere
Turning Circle: 0 cm
Weapon: 5 cm wide rear hinged hardox lifting arm powered by an S28-400 Magmotor running off of the same batteries as the drive.
Geared down @ a ratio of ~160:1 to give a 90* lift in under 0.5 seconds and the ability to lift a large amount
Srimech: The arm is the srimech but has the ability to run inverted
Notes: This one had a CAD done to make the parts fit and check weights easier
