Motors for Roveress: 4x S28-400 Magmotors powered by 5x NiCad Battlepacks.
Armour for Roveress: 7mm Titanium/Vanadium alloy.
Psi?
1000psi.
1: Theres a rule against double posting. How do you think TRIPLE posting is going to be taken? The non-edit rule takes place after 10 minutes, you know.
2: You should have included the psi BEFORE putting in the stats.
Minesweeper: Nothing really wrong with it, I am guessing the scoop is like the one on behemoth which is a good idea. The only remark I have there, is why not make the entire robot of the same armour? give it 4 or 6 mm Hardox all round instead of that mish-mash of various types of armour. In real life we want to keep the amount of materials down as well, from a maintenance and repair point of view.
Roveress: make it a little bit wider, like 70cm, and I think it is in good shape. For the srimech a lem130 is way overkill though, just make the robots top a bit rounded so it rolls over easily and use a Bosh with a gearbox to power the arm, it saves on batterypower and is much more sensible.
Cyrilium Mach 3 : Make the robot higher. There is no way in those dimensions that you can fit 2 2kg bottles, pneumatics, lifter and axe mechanism, and 4 magmotors and batteries.
I must say your stats are improving though, keep it up.
Thanks Leo.
Minesweeper
Weight: 100kg
Shape: Tornado (S5)
Colour: Silver, with MINESWEEPER written on the sides in white.
Dimensions: 90cm x 85cm x 25cm
Drive: 4x Bosch 750 motors, powered by 5x 36V NiCad Battlepacks.
Locomotion: 4 Titanium/Vanadium alloy wheels with Vulkanized rubber tyres.
Armour: 6mm Hardox
Speed: 16mph
Ground Clearance: 0mm at front and back due to scoops.
Turning Circle: 0m
Weapon: 2 snowplow-like scoops that can move slightly vertically, so I get good pushing power, but 0mm ground clearance at front and back.
Srimech: Invertible
Roveress
Weight: 100kg
Shape: Growler, with a pink bow on top of his head.
Colour: Brown, with black and white splotches in some places.
Dimensions: 100cm x 70cm x 40cm
Drive: 4x S28-400 Magmotors, powered by 5x NiCad Battlepacks.
Locomotion: 4 foam filled wheels.
Armour: 7mm Titanium/Vanadium alloy.
Speed: 20mph
Ground Clearance: 0mm at front, and 9mm everywhere else.
Turning Circle: 0m
Weapon: The bottom Jaw Is fixed to the ground, and shaped like a wedge. Once a robot is stuck on the wedge, which has Mute-style barbs on it, the top Jaw, powered by a 2kg 1000psi Nitrogen tank, comes down with over 5 tonnes of force.
Srimech: A lifting arm, built into the back of the robot, powered by a Bosch drill motor.
Cyrilium Mach 3
Weight: 100kg
Shape: Mortis (S4)
Colour: Gold
Dimensions: 100cm x 70cm x 30cm
Drive: 4x S28-400 Magmotors, powered by 5x 24V NiCad Battlepacks.
Armour: 5mm Hardox
Speed: 21mph
Ground Clearance: 0mm at front, and 5mm everywhere else.
Turning Circle: 0m
Weapon 1: A diamond tipped pneumatic axe, powered by a 220psi 2kg C02 tank. it can poke holes in 3mm Titanium, and actually scratch 5mm titanium.
Weapon 2: A flipping arm, powered by another 2kg C02 tank at 750psi. It can lift up to 500kg.
Srimech: The flipping arm.
(Message edited by corsair_lightning on May 01, 2008)
For axe power, it might be better/more technical to give tip force than estimates of what it can do, although having said that I dont usually bother.
Otherwise, as much as it pains me to say this, those are actually fairly good :proud:
Wha...
The world is collapsing. Mark Elam just made good vapourbots.
*faints*
Cyriliums axe can come down with over 2500kgs of force.
No it cant.
