Alternatively, use http://www.teamcosmos.com/ke/ke.shtmlhttp://www.teamcosmos.com/ke/ke.shtml if youre lazy.
Disc Fatality
Weight: 100kg
Shape: Box
Colour: Royal Blue with White tinges
Dimensions: 98 X 96 X 43
Motors: 2 X S24-800 Mags powered by 4 X 24 V NiCad Battle-Packs
Wheels: 4 X Tyres with Foam and vulkalon rubber
Armour: 7.5mm Titanium/Vanadium
Speed: 15 mph
Ground Clearence: 3mm all around
TC: 0 (Seriously, isn€™t there anything that doesn€™t have TC of 0?)
Weapon: 42lbs Laser-Cut Horizontal spinning Disc with 2 X Hardox Steel Teeth (curved and a bit blunt to cause maximum damage) powered by a LEM-130 Lynch Motor spinning at 5300RPM. This is deadly within 1 and a half seconds. This should also give as much as 52 KJs and enough to penetrate through almost anything.
Srimech: Invertible
Strengths: The lethal and devastating weapon, the Storm 2-like pushing power. Has a load of shock proofing inside to help it protect itself.
Weaknesses: As usual, its wheels are exposed a tiny bit from the top, and it€™s prone to be abducted by aliens? :rofl:
Sorry, but thats false. :proud: Team Bravehearts FBS, Whirligig 4.5, has over 100kJ in its hits but cant cut through Hardox, or even thick titanium without a few blows.
The same can be said for many other high kJ disc weapons.
Dont go making claims youre definitely unsure of. :wink:
New Bots:
Minesweeper
Weight: 100kg
Shape: Tornado
Colour: Silver, with Minesweeper written in white on the sides.
Dimensions: 90cm x 85cm x 25cm
Motors: 4x Bosch 750 motors running off of 5x 36V NiCad Battlepacks.
Motivation: 4 Entirely vulkanized rubber wheels
Armour: 6mm Hardox at the front, 4mm Hardox on the top and bottom, 6mm Titanium at the back, and 7mm Titanium/Vanadium alloy at the sides.
Speed: 15mph
Ground Clearance: 5mm at sides, and 0mm at front and back due to scoops
Turning Circle: 0mm
Weapon: 2x snowplow-like scoops, one on the front, and one on the back. These have a little bit of vertical mobility, so the wheels can touch the ground.
Srimech: Invertible
Strength: Enormous pushing power
Weakness: The robot: If Cats Had Wheels, We Could Have Cat Races, How Cool Would That Be?
Roveress
Weight: 100kg
Shape: Growler with a pink bow on top of his head.
Colour: Brown, with black and white splotches in some areas.
Dimensions: 100cm x 60cm x 40cm
Motors: 4x LEM-130 Motors powered by 5x 36V NiCad Battlepacks.
Motivation: 4 foam filled wheels
Armour: 4mm Hardox
Speed: 20mph
Ground Clearance: 0mm at front, and 1cm everywhere else.
Turning Circle: 0mm
Weapon: The lower Jaw is fixed to the ground and shaped like a wedge. Once a robot is stuck on the wedge, which has Mute-Style barbs on it, the upper Jaw comes down with over 5 tonnes of force.
Srimech: A light Mortis-esque lifting arm built into the back of the robot, powered by an LEM-130.
(Message edited by corsair_lightning on May 01, 2008)
What do you mean by 2x snowplow-like scoops, one on the front, and one on the back. These have a little bit of vertical mobility, so the wheels can touch the ground
I just dont get that. And in addition, I may be wrong, but depending on higher knowledge on Bosch 750w motors, I think that your robot will have around the 4hp or 14hp mark - try LEM130s at 36V, as for certain you will have 18hp.
I am trying for pushing power on Minesweeper.
The scoops have a little bit of vertical movement so the wheels can touch the ground and have 0mm ground clearance at front and back without being stranded.
Roveress hasnt got any power for the weapon, plus itll be overweight. You cant get 5 x LEMS into a heavyweight
My renewed Cyrilium:
Cyrilium Mach 3
Weight: 100kg
Shape: Mortis (S4)
Colour: Gold
Dimensions: 95cm x 65cm x 25cm
Motors: 4x S28-400 Magmotors, running off 5x 24V NiCad Battlepacks.
Motivation: 4 Aluminum Boron Carbide wheels with rubber tyres.
Armour: 5mm Hardox
Speed: 21mph
Ground Clearance: 0mm at front, and 5mm at back and sides.
Turning Circle: 0mm
Weapon 1: A pneumatic axe, run off of a 2kg C02 tank at 220psi, that can come down with over 2500kg of force, and can pierce 2mm titanium.
Weapon 2: A lifting arm-shaped flipper, powered by another 2kg C02 tank, it can lift up to 175kg.
Srimech: The flipping arm
Roveress upper Jaw runs off of a 2kg Nitrogen tank, and is supposed to stop opponents from moving, not crush them.
