ok guys, 2 tactics to go :proud:
My spatula is very low, so if I do manage to get under it, take the oppertunity, and then axe its underbelly.
If it doesnt get it over however, bludgeon with the hit and run tactics that black panther uses normally. Get a few blows in but speed away before retaliation.
Disco 5 vs Psyclonised
Pretty simple plan here. Those sides are just asking to be attacked with no real protection, so generally my plan is to get as many blows in to the sides as possible.
If the weapons are causing me some troubles then a few swift blows to the flipper may well jam it shut or at least weaken its flipping efficiency. The disc is pretty nasty, but if I can catch it side on then hopefully I can mess the mechanism up. From there theres no worries and its all about causing damage.
If Salamander III in the C&BT2 could do it, imagine what Psyclonized can do...:uhoh:
Grand Finals
Fight 1
3€¦ 2€¦ 1€¦ Activate!
AND THE GRAND FINALS ARE OFF! Only four robots are left in this competition, and in this fight we see arguably the two most destructive among them. Disco5 stands tall with its classic wedge shape and devastating vertical disc, and Psyclonised looks dangerous with that big spinning cage all around him. Martyn€™s tactics involve relentless attacks with the disc, so he the first one to leave the mark while Psycolined still spins up. Psyclonised tries to get away but there€™s no escaping today!
CRASH
Disc meets ring, what a blow that was! A quick damage-check is done by the contenders, but there is no damage that meets the eye. Disco backs off to get the disc spinning again, whereas Andy tries to sneak to the side of his nemesis. Martyn tries to prevent Psyclonised from succeeding this evil plan, but he is too late!
CRASH
Psyclonised hammers rattle against the titanium ribs that hold Disco together. Most of them snap, but the hammers slow down too. Disco drives away, but a trace of destruction can be seen at its side. Disco steers away now, straight towards the pit-release button. Psyclonised gives chase, and Martyn suddenly has a very confident smile on his face, what is he up to? The faster Psyclonised is almost within arm length of Disco, WHEN DISCO SUDDENLY TURNS AROUND! Both weapons meet again, at full speed this time. And instead of the two machines flying away, it looks as if Disco€™s weapon has dug its way underneath Psyclonised ring. In fact, they€™re stuck! Neither weapon spins, but Psyclonised does have its wheels lifted off the ground. Martyn makes the most of it and rushes in a straight line towards the wall.
CLANG
Psyclonised is banged against the wall, and still stuck on Disco€™s disc. Martyn turns his bot around in search of another wall, but soon discovers the current link between his bot and Andy€™s isn€™t designed to maneuver around very well. Psyclonised falls off Disco and Andy is can be seen breathing again. Time to spin up your weapons gentleman! Andy is taking this advice happily, but Martyn seems to be hesitating. Is there some odd reason for Martyn not to spin up his weapon? Or is it the collision with Psyclonised that jammed it in some way? It seems to be the last option, and suddenly things aren€™t looking all too well for Martyn! Disco once again rushes towards the pit-release button; will Martyn pull another trick out of his hat? The answer is plain and simple; no. PRUUUUUUUUUUUUUUUT. The pit descends, and Psyclonised turns on the aggression. Martyn is aware of this, but he is too late!
CRASH
Psyclonised hits the already damaged side of Disco, and injures it even further. Disco recovers as fast as it can and turns his wedge towards Psyclonised. The wedge comes in and the flipper goes up€¦ and meets the hammers!
CRASH
Psyclonised is€¦ well€¦ inverted now, but Andy doesn€™t really care. Disco however is in a worse state, his flipper almost ripped off. Psyclonised comes in again. Disco tries too flee, but he doesn€™t move as smoothly as he used to do€¦
CRASH
And another deathblow is to be seen. Can this be the final blow? There€™s not much life left in Disco€¦The judges start counting 1€¦ 2€¦ 3€¦ 4€¦ 5€¦ 6€¦ 7€¦ 8€¦ 9€¦ 10€¦
CEASE
Disco 5 has been beaten into submission
PSYCLONISED GOES THROUGH TO THE GRAND GRAND FINAL!
Coming next
Who will join Psyclonised in the Grand Grand Final?
Black Panther Queen vs Wedge Devolution
Gimme your predictions, gimme your tactics, gimme your thoughts :proud:
w00t w00t W00T! Amazing fight there Marti! :):proud::)
Grand Finals
Fight 2
Off we go. Where yesterday€™s match had two spinners going against each other, today we see the two most successful flippers of this tournament facing off. One of them, Wedge Devolution, is a classic, skirted wedge, whereas the other, Black Panther Queen, is more of a pyramid, equipped with a powerful axe. It€™s the latter that leaves the mark first and speeds towards Wedge Devo. Steve fears his opponent€™s offensive abilities and tries to stay out of the Queen€™s reach, but the Queen is just too fast€¦
CLANG
Down comes the axe, right on top of Wedge, and Black Panther reverses. This is hit and run as we now it from Black Panther Queen, a tactic that served Alex quite well during this tournament. Wedge Devo, dented, gives chase to the axebot. Alex can€™t keep running forever, but with Wedge driving in his direction, he can€™t afford to make a mistake. Black Panther Queen slowly halts for another face off with the flipper. Steve skilfully drives diagonally towards the Queen though, to ram his wedge underneath the corner of her Majesty€™s skirt. Alex didn€™t anticipate on this and what do ya know, Wedge is underneath! Steve turns his creation into an effective rambot and carries Black Panther Queen forward a meter or so, before firing that mighty flipper! Alex pyramid-shaped robot gains some airtime before landing, on his back. Steve seeks advantage, but the Queen€™s srimech proves very efficient and self-rights her in no time. Black Panther now finds Wedge Devo at her back, and she quickly flicks her axe back-and-forth to give the VFT-champ a good clobbering before he can do anything. And again, Black Panther Queen drives away straight after the hit. Steve is getting pretty much tired of this tactic, and gives chase again. Black Panther Queen makes a quick U-turn, slowing her down compared to Wedge who drives in a straight line and rams the side skirts. He doesn€™t penetrate them straight away, but after pushing the Queen a bit the bent bottom of Wedge€™s flipper slowly penetrate the Queen€™s side. The flipper moves up again, and so does the Queen. She€™s inverted now and Steve is closing in, and fires the flipper again! Steve is on the offensive now, but the back-on-her-wheels Queen isn€™t scared. She manoeuvres her way to Wedge€™s side, and seeks to penetrate HIS skirts now! At a first glance she seems to fail, but another pound on Wedge€™s top ticks him off-balance a bit, and the Queen€™s spatula slide under Wedge€™s side skirt! FLIP! Wedge moves though the air now, though it becomes clear that Black Panther Queen€™s flipper is slightly weaker than Wedge€™s. Alex doesn€™t care, he has Wedge right where he wants him. Wedge fires his flipper, but not before Black Panther fires her axe!
CLANG
The axe hits Wedge€™s underbelly, and Wedge is still stuck on his back! Not only that, his underbelly is sliced! Steve starts to sweat, and fires his srimech again, simultaneous to Black Panher€™s axe! This axe-blow however comes down under a less effective corner, and Wedge self-rights effectively, only to get hit by another axe-blow, straight on top of his flipper! Steve turns on the aggression again and rams his flipper (which doesn€™t look very much like the Hardox sheet Steve once bought anymore with all those dents) underneath Black Panther Queen€™s front (who once again deals a successful axe-blow in the meantime) and flips her up and over.
10€¦ 9€¦ 8€¦ 7€¦
The clock starts ticking, Wedge comes in.
6€¦ 5€¦ 4€¦
The Queen self-rights, just in time.
3€¦ 2€¦ 1€¦
Wedge hurries forward!
CEASE
OMG, what a battle this was! There€™s no time left, but the two machines are still moving, what will the judges say?!
The judges walk down towards the arena floor, where they inspect the damage done to Wedge€™s belly.
Damage: Black Panther Queen ((6 out of 10)*2=12)
Wedge Devolution ((2 out of 10)*2=4)
Aggression: Black Panther Queen ((8 out of 10)*1.5=12)
Wedge Devolution ((8 out of 10)*1.5=12)
Control: Black Panther Queen ((7 out of 10)*1=7)
Wedge Devolution ((7 out of 10)*1=7)
Style: Black Panther Queen ((6 out of 10)*0.5=3)
Wedge Devolution ((7 out of 10)*0.5=3.5)
Black Panther Queen: 12+12+7+3=34
Wedge Devolution: 4+12+7+3.5=26.5
Wedge Devolution couldn€™t impress the judges
BLACK PANTHER QUEEN GOES THROUGH TO THE GRAND GRAND FINAL!
+1>ff6000>THE FINAL DRAW HAS BEEN DECIDED
BLACK PANTHER QUEEN VS PSYCLONISED
ff6000>but first€¦
Coming next
THE 3rd PLACE PLAY-OFF
Disco 5 vs Wedge Devolution
*ZOMFGWTFPROTESTATIONSCONTRADICTIONSWEDGEDEVOSHOUL DHAVEONETHEFIGHTWAHWAHWAAAAAAA AAAH* :lame:
Nah, its okay. Looks like a good final line-up!
Disco 5 vs. Wedge Devolution
I think Disco 5s weaponry will serve him well here against Wedge Devo. Disco 5 FTW.
BLACK PANTHER QUEEN VS. PSYCLONISED
Oh boy, the one of the other three Psyclonised didnt want to face. Still, its pretty much in Psycloniseds favour. If BPQ hits Psyclonized with the axe from afar, that will still allow Psy to spin up deadly fast. BPQ needs to get in quick and fast, and weve already seen that Disco 5 has done that and failed miserably. I dont think BPQ can win this one.
PSYCLONISED WILL WIN MECHANICAL NOISE - SERIES 1.
Ooh... BPs doign very well here - here the tactics can be basically summed up in constant harassing - eveyr flip and axe blow will be done and everythign will be as continuous as possible - charge straight in and just keep attacking with each weapon alternatly to prevent them getting up to speed. If he does... run away.If I am forced to ram him at any point, lift the flipper up to do it so it isnt damaged.
Woohoo! This has been a great tournament Martijn, and I€™ll be back for Series 2 regardless of the final result. And for that, lets break some things down a bit.
One thing in my favour is that I€™m around 9mph slower than Black Panther Queen. This works greatly in my favour, as I am therefore much better at accelerating, spinning up and coming in for the kill.
Next is the armour, regardless of it€™s fancy name - it is aluminium at the end of the day, and at that just 5mm thick. Psyclonised isn€™t just there for show; it can do some serious damage to extremes such as Titanium and even Hardox. The hammers are going to go through this bot like a knife through hot butter.
All the extra gimmicks like the skirts and flipper are there just to be eaten. Flipping this bot is completely useless - that€™s the whole point of the design. Another aspect of this bot being that if for some chance the ring is slowed down long enough to get a shot it, the bars act very much like Tornado€™s bars to stop axes and crushers getting an effective shot in.
And if a shot comes in - big deal, I€™ve got over 3mm of Hardox on top to stop the thing doing any damage. The wheels are solid enough to hold their own, but BPQ will be damn lucky to get an accurate shot in on them and cause them harm. Anyway, rubber is a shock absorber as it is.
All in all, there is just one thing to do - use my superior acceleration to get away and spin up to the danger zone and then just take that robot apart piece by piece. Oh, and one extra note, if for some odd reason the ring becomes disabled, then I have four or five times more pushing power than the Queen, so I just need to simply push it into danger.
For the playoffs, I€™ll choose Disco 5 to prevail over Wedge Devo due to its higher destructibility factor. :)
lol Alex, I remember you saying how glad you were seeing your radical changes paying off back in Heat A, well mate, it brought you to the finals :proud:
and cheers Andy, thats one spot in MN 2 filled already :proud:
(Message edited by MajinB on June 08, 2007)
You miss the point of me flipping you - in all liklihood if I do that youll at least come down on your side at some point, thus stopping your spinner. You will in all liklihood land on your wheels, but that gives me time to follow up without your weapon being active.
Are there any pictures of it because readign that stats I dont quite get it really - mainly the relationship between the cage and the spinning shell.
Disco will spin up and just go in with the disc and try and cause lots of damage in the hope of disabling the flipper, if i manage to disable the flipper, try and get under it and flip it, or try and flip it with the disc.
You miss the point of me flipping you...
Is this before or after I rip the flipper off? :wink:
As for the cage/shell relationship, I guess I could knock you a picture up if you want. In short, rather than teeth it has hammers sticking out and the cage links hammer to hammer for more stability. The anti-axe/crusher mechanism therefore comes naturally as part of the structure.
FINALS
PLAY-OFF
Disco 5 VS WEDGE DEVOLUTION
Attacking the corners of the skirts seemed to work well last time, so Ill try the same thing here. My slight speed advantage should allow me to outmanouevre it, so hopefully, I wont end up eating flywheel too much. Just head for the skirts corners, flip, sneak underneath and ram to the Pit or arena walls for a final flinging.
This has been an excellent tournament, Marti, and these closing clashes should be the cherry on the cake. Consider this your second reservation for Series 2. :wink:
Before... afterwards its more likely that your weapon will get clogged with shrapnel, lol.
One plus side of my weapon is that as its got two halves I in theory get two attempts if Im lucky.
Plus yay for radical changes
Psyclonised to win.
The 3rd place play-off
Almost there
Spicy detail in this match is that Disco has already beaten two of Steve€™s most infamous vapourbots on its way to this play-off, Whirligig and Clawdius no less. How will the discbot fair against Steve€™s most successful entry of this tournament? Steve himself is more than eager to find out and he drives his bot towards Disco. Disco waits for Wedge to come while spinning up its disc. Wedge tries to find a way around it, but bad luck strikes Steve when Martyn skillfully positions the disc straight between the chassis€™ of Wedge and Disco when the wedge tries to slide under and launch Disco into the air
FLIP!
CRASH!
Wedge launches its flipper alright, but it hits a nasty vertical flywheel in the process. While Disco only topples a bit, Wedge is send up and over, and backwards, with a burst of sparks. A cut can be seen at the bottom of the flipper, nothing too serious really. Wedge self-rights, but Disco is already coming in€¦
CRASH!
Two hits in quick succession. This hit doesn€™t send Wedge flying; however, it knocks one of Wedge€™s side skirts right up. Wedge turns around to come face-to-face with Disco, skirt upright and damaged. Disco tries to attack, but Wedge successfully moves to the side and tries to have a go at Disco€™s front corner, but he misses! Wedge now moves towards Disco€™s rear, where he uses his superior speed to shove his flipper underneath! Wedge flips! Disco moves up, nudges the floor with his disc, and is send flying! Disco lands on its back, but uses his srimech before Wedge Devo can come in to cause more harm. Wedge IS coming in though, and again searches for the front corner of Disco to slide under for a flip. Disco tries to put something against this, but he can€™t help himself! Wedge is underneath again, and the match seems to be going in his favour! Another hefty flip and Disco is flying again! The gyroscopic forces of the disc this time send Disco in a full circle and make him land on his wheels. Again the two machines seek a confrontation. Man, 3rd place play-offs are often seen as pity-finals, but that can€™t be said about this match! Wedge tries to bring in his flipper, while Disco seeks to deal serious damage with his disc. Wedge does give his best shot, but Disco€™s weapon is just a little bit easier to get in€¦
CRASH!
WHOA! This attack send Wedge€™s flipper in upright position, just like what happened with the skirt earlier! Wedge backs off, Steve looking desperate at what happened with his only weapon. Disco turns on the aggression now, launching another assault on Wedge€¦
CRASH!
Wedge topples; the flipper has a nasty slice in it now, and still doesn€™t seem capable of any flips. Disco comes in disc-first, to send once again show us some sparks€¦
CRASH!
Martyn now turns around, flipper-first, to see if he can get the badly damaged Wedge on his back.
10€¦ 9€¦ 8€¦ 7€¦
Wedge reverses€¦ and time is running out!
6€¦ 5€¦ 4€¦
Disco is closing in!
3€¦ 2€¦ 1€¦
Too late now!
CEASE
We€™ve gone through one hell of a battle, and still the bronze medalist isn€™t decided€¦ well then€¦ let the judges decide for us!
Damage: Disco 5 ((8 out of 10)*2=16)
Wedge Devolution ((4 out of 10)*2=8)
Aggression: Disco 5 ((8 out of 10)*1.5=12)
Wedge Devolution ((7 out of 10)*1.5=10.5)
Control: Disco 5 ((7 out of 10)*1=7)
Style: Disco 5 ((5 out of 10)*0.5=2.5)
Disco 5: 16+12+7+2.5=37.5
Wedge Devolution: 8+10.5+7+3.5=29
Disco 5 wins the 3rd place play-off!
Coming next
We know who came 3rd€¦
Who will come 1st?
BLACK PANTHER QUEEN vs PSYCLONISED
Come and see it€¦
Come and see it€¦
Wow third place :D
Ahem€¦
Back in October 2005, I decided it was time for the FRA to get a new major. As a matter of fact, there weren€™t many majors left at that point in time, so it was me who took it upon himself to break the deadlock and show people how important major€™s are for the FRA. Mechanical Noise turned out to be a major like many others. It had arguments, controversy and HUGE delays.
Right now, over a year went by. Eight Heats were finished. Four Semi-Finals resulted in two Grand Finals. The Grand Grand Finalists have been decided. Forty-six robots met their defeat; two remain, fighting for the first place.
Before the final battles starts though, I feel I have some awards to give away.
Mechanical Noise - Series1; The Awards
Most original design
An award meant for the robot of which there was none other, a one of a kind. Several machines fit this description. How about S.D. IV with its low-mounted saw blade, Flank Attack with its huge rubber coated pincers and scoop, Going Crunch, the only clusterbot and Omniforce, with its omnidirectional drive-system? The machine I give this award will be one that was rather unlucky being overpowered by two highly destructive full-body spinners in round 1, namely Slammer V. It is the self-flipping device of this axlebot that makes it so unique, combined with a wide range of interchangeable weapons. Congratulations Alex H!
Best design
Meant for the most thought-out design. For that one design that is ready for everything thrown at it, be it a powerful flipper, a destructive spinners of a high-powered rambot. Machines that fit this description well include Disco 5, Wedge Devolution, Die-Ceratops Re-Invertus, Achilles and SOR 5.0. The one this award will go to however is Psyclonised, for being a great invertible design, merging Son of Whyachi€™s spinning cage with a standard spinning ring to create a great line of both offence and defense. Congratulations Andy!
Best engineered
Meant for that one technical masterpiece out there. For the machine that is build so smart, so well, that it€™ll make my science teacher cry. Again, there were many candidates. Black Panther Queen, Shovearound 2 and GeForce 4.0 were serious contenders, but I decided to give this award to Wedge Devolution. Congrats Steve!
Best sportsman
I have to admit, there were no bad sportsmen in this tournament. There have been some arguments, but all of them have been settled nicely and quickly. I€™m gonna give this award to Steven McGregor, who is famous for always being his optimistic self, and never complains. Not that he had any reasons two complain, he brought two vapours within the top six of this tournament. Congrats!
Best realie
This is an easy award :proud:. Only three realies were entered, and of them, only one was capable of fighting its way past round 1. 13Black it is, for being the only realie that managed to overpower one of the many overpowered vapours out there. Congrats Chris C!
Most aggressive
An award meant for that one vapourbot designed for offence, rather than defense. Again, many candidates were looked at by me. Black Panther Queen, Disco 5, Forcepower 5.0 and Novastorm 2 were all great. In the end though, I had to give this one to Cyberdemon. Its translational drive-system made it perfectly well suited to come in at opponents and completely destroy them, like it did to Axe-O-Lotle in round 2. It was eventual finalist Psyclonised that had to stop this beast, and did so by having better control. Congrats Anthony!
Best fight
In this category, only one fight stood out. It is shared winner of 2006€™ Best Fight Award. It is the vapour equivalent of Gravity vs Razer€¦ Clawdius Decimus Murderous vs GeForce 4.0
Those were the awards boys and girls€¦ those who won one€¦ CONGRATS! Those who didn€™t€¦ well€¦ you still did one hell of a job!
Next up, THE FINALS!
Yay! Fourth place and 2.5 awards! Not too shabby! :proud:
It may have taken an ice age to get through, but this tourny hasnt failed to disappoint at all, Marti - especially considering this is only your first. Looking forward to the Final and already eagerly awaiting the Series 2 sign-ups. :)
Forty-eight robots started this tournament, two robots are left. One of them will be the winner. Who that will be? We€™ll see that in a minute. But first, how did our finalists get this far?
Black Panther Queen
Round 1: Destroyed Cosmic Thunder, with help from Yet Another Cut Above the Rest
Round 2: Flipped Judo Chop! OOTA
Round 3: Flipped Yet Another Cut Above the Rest OOTA
Round 4: Beat Die-Ceratops Re-Invertus on a JD
Round 5: Beat Wedge Devolution on a JD
Psyclonised
Round 1: Beat Slammer V on a JD, with help from Cyberdemon
Round 2: Destroyed Winde Chaser
Round 3: Destroyed Cyberdemon
Round 4: Destroyed Flank Attack
Round 5: Destroyed Disco 5
and now we know all of this€¦
The one and only :proud:
Black Panther Queen vs Psyclonised
AND THE FINALS HAVE STARTED! Both machines fighting today had to overcome great odds to get where they are now. Two great finalists we have, and two great potential winners. Fact is, though, that only one of them can take it all. Black Panther Queen seems slightly more eager as he bashes out of his starting square and into the upcoming fray. Psyclonised is still stationary now and starts spinning up his outer ring. Black Panther is storming in at high speed, and with high, I mean HUGE.
Psyclonised isn€™t 100% ready to fend off Black Panther Queen, yet Andy isn€™t quick enough to avoid that what will be the first impact of this grand final! Black Panther Queen rams Psyclonised, nearly stalling the ring, followed by a swift hit of the axe. The axe reaches all the way over Psyclonised spinning ring and dents the Hardox that€™s on top of the spinner! A mere dent it is though. Black Panther Queen employs her other weapon next, but Psyclonised is already moving backwards and the flipper misses its target. The Queen does not want to be left behind and she follows Psyclonised, getting her flipper within the right reach again, and this time using it with more success. Psyclonised is flipped, and Black Panther Queen moves forward to keep on attacking. What Alex didn€™t calculate though, is that when Psyclonised€™s slowly but steadily spinning out ring hits the ground, Psyclonised is levered sideways, negating Black Panther Queen€™s intended onslaught.
Psyclonised is back on its wheels, away from Black Panther Queen, and can finally start spinning up effectively. Alex does not intend to let this happen and rushes across the arena. Psyclonised is only backing off further and further, until its ring reached that deadly top-speed Andy loves so much. With Black Panther Queen being bloody close, Psyclonised moves forward a bit to get that ring in. Alex isn€™t in the mood to sacrifice his flipper just yet and turns around, causing the ring to hit Black Panther Queen€™s side!
CRASH!
A piece of metal flies off the Queen€™s side as she bounces back. Psyclonised€™s ring hardly slows down and Andy goes looking for more blood. Alex himself now advances to his secondary tactic; he raises his flipper up into the air and goes out to box-rush Psyclonised. The ring-spinner has already beaten four of it€™s opponents by pure knockout this tournament, and he seeks to do same with Black Panther Queen. The bots drive in at each other head-on€¦ that€™s gonna be one hell of a collision!
CRASH!
Psyclonised€™s hammers make a huge dent in the Queen€™s aluminum, but also reveal what€™s right behind that aluminum, 2 inches of titanium foam! Most of the impact is absorbed by Black Panther Queen, and the ring is slowed down a bit€¦ but hardly stalled! The Queen now employs her axe€¦ but the remainders of impact caused by the collision send her backwards a bit€¦ enough for her to miss Psyclonised€™s top and hit its ring! The axe-head is caught in that great spinning cage that know bends the axe-shaft€¦ and almost breaks it! Alex pulls back his axe right in time, giving Psyclonised another opportunity to attack Black Panther Queen€™s aluminum again!
CRASH!
Pieces of metal are send flying now, but the Queen€™s inside is still protected by that strong foam of hers. Alex has to come up with something now, with his axe made virtually useless and time running out! Alex tries another box rush€¦ flipper raised, and slightly closer to the arena wall. In comes the Queen, but Andy doesn€™t look all that scared.
CLANG!
Black Panther Queen hits Psyclonised rather effectively, and the foam does exactly what it was made for! The ring-spinner is slammed against the arena wall by the flipping axebot who€™s already beaten two robots by OOTA. Psyclonised will not be flipped OOTA right now though, if only because Black Panther Queen€™s flipper is in upright position :proud:. The Queen does have one weapon she can use though, even though it€™s a badly damaged one. She lowers her axe on top of Psyclonised€™s Hardox armour€¦ AND THE AXE-SHAFT BREAKS! The damage done by Psyclonised€™s weapon was to much€¦ and now the shaft breaks on Psyclonised€™s hard armour.
Andy can be seen smiling from his booth, and accelerates Psyclonised forward. With its superior traction, Psyclonised manages to push Black Panther Queen away, and now moves away from Psyclonised itself to get his ring back up to speed. Alex immediately makes use of this great opportunity and drives in at Psyclonised, flipper lowered. When the two ferocious machines hit each other, Psyclonised€™s weapon already reached a nice speed, but not enough to stop the Queen from flipping him. On the other hand€¦ the speed of the ring IS enough to nudge the badly damaged aluminum behind that flipper, and knock a hole in the foam!
Psyclonised topples up and over in the air and lands on its wheels, with the Queen coming in again. The Queen however, seems to be moving slower than normal! Is Psyclonised€™s constant clobbering finally raking its toll? Psyclonised tries to find out by attacking the Queen again, this time at her side, with an onslaught impossible to evade by the damaged Queen€¦
CRASH!
The Queen makes a 360, and this time smoke is coming out of her. What happened? Burnout? Short-Circuiting? We can€™t tell for sure, but seemingly, there is no live left in Black Panther Queen. Psyclonised comes in for the final hit, but the judges are already counting.
CEASE
Black Panther Queen has been beaten into submission
+2>PSYCLONISED WINS MECHANICAL NOISE - SERIES 1!!!
There we have it brothers and sisters, the winner is known, Psyclonised it is, with this, we can take a look at the ultimate ranking list of this tournament, which might just be the seeds for Mechanical Noise - Series 2.
1. Psyclonised
2. Black Panther Queen
3. Disco 5
4. Wedge Devolution
5. Flank Attack
6. Clawdius Decimus Murderous
7. Achilles
8. Die-Ceratops Re-Invertus
9. Cyberdemon
10. Yet Another Cut Above the Rest
11. Going Crunch
12. Novastorm 2
13. Tengu VII
14. GeForce 4.0
15. Orka MK4
16. Forcepower 5.0
I enjoyed hosting this tournament, a lot, and I hope you lot liked it too.
Yes, there will be a Mechanical Noise - Series 2. I€™ll be looking for a slightly different setup there, as well as 12 entrants. I haven€™t got a single clue when it€™ll start; all I know is that Series 1 is over€¦
€¦ now
Woohoo! :mrgreen: Thats FFW and now Mechanical Noise wins back to back for Team Idiot Technologies. Comiserations to Alex and BPQ, it stood up a lot longer than I thought it would...
But obviously, a huge congratulations to Martijn. This tournament has gone on a lot, lot longer than I thought it had but every moment has been great. For someone writing their first tournament in a language foreign to them, this has been an amazing acheivement and I am honoured to win it - so thankyou!
There were many times where like myself and others, you could have given this up. But you kept on going and have continually delivered great battles. This has been a great tournament and the fact I picked up an award and won the whole thing is the icing on the cake. With four seeds and the champion, you can bet Ill be back to defend the crown whenever that may be.
Now off to make some improvements for next year... :proud:
Good match Andy, and even more so to Martijn! This has been a superb tournament, and I look forward to any more you do. I will have my vengeance, lol.
Whoot! Most aggressive award! Better than walking away empty handed! :D
And 2 seeds! WOOT!
Awesome tourny indeed Marti, cant wait until series 2
+1>WOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOT!!!
AWESOME fight there Martijn! What a way to end a spectacular tournament like yours! Go Psyclonized! Congrats to Andy, Alex, and of course Martijn for one hell of a tournament.
I cant wait for MN2, I can tell its gonna be soooo awesome. :proud:
Fantistico tourney Mr.Benschop.
hooray! Its finally over :D
Nice tournament, Martijn. Very awesome.
