Yes?
Yes?
No
(Jesus Chris Levick!)
Thought I had, turns out I havent
Could you email me with the specs perhaps? (on profile)
edit- (A to chris- messing about on msn like that)
What?
edit- (A to Ewan- he he lighten up!)
Now Im confused!
Geoff just e-mail Ewan, Scrop Jrs disk and gear ratio details to aid in gearing his own spinner.
Chris - http://www.featherweights.org/forum
Ewan I believe the disc is geared down about 10000:1 :)
Chris, The little bot is called Caesar. Its made by Marco who also build Hades.
It uses 2 electric step motors on 2 small mythras speedos, running at 36v.
The pincers where connected to a linac, but it wasnt operational yet. Check the movies to see them both running.
Robot name: Little Spinner 2
Power: 1x NimH pack 19.2v 1800ah for drive. 24v nicad pack 2400ah for spinner.
Drive: 2x 16.8v Drills motors 125mm dia wheels
Controller: 1 Technobots h bridge dual channel.
Weapon: 2kg titanium bar 20 inches long powered by 2 24volt motors connected to a 3:1 bevel gearbox.
Armour: 3mm front grade 5+ ti. 3mm ali top+bottom, sides and back 10mm ali.
Weight: 12.0 KG
Status:2\3 done.
No pics yet.
Just for something scary.
Robot name: Prancing Queen
Power: Was 1 x 24V GP3300 pack, now 1 x 12V GP330 pack
Drive: 2x 12V drill facing down 45 degrees with 20mm rubber door stoppers on the ends.
Controller: Was 2 x IFI Victor 883s, now servo switching.
Weapon: Half a 9kg gas bottle spun by an EV Warrior with 3:2 reduction. Was 24V, now 12V.
Armour: See above.
Weight: 13.5 KG
Status: Shes dancing.
http://www.hellfire-labs.s5.com/Prancing%20Queen.htmhttp://www.hellfire-labs.s5.com/Prancing%20Queen.htm
Details of robot for denbigh event
Robot name: Unity
Power: 14.4v NiMh
Drive: 2x 14.4v drills
Controller: 2x 15A cpu electronize
Weapon: Unity is too kind to have a weapon yet.
Armour: 3mm steel with additional 5mm steel on front edges.
Weight: 9 kg ish
Status: being painted now.
No pics yet.
New machine from the Pillow Torque Team.
Power: 2 X 12V 3Ah Ni-Cad.
Controller: Vantec RDFR-23.
Drive: TBA. (several possibilities under consideration)
Weapon: 2.9Kg Chrome Vanadium Pussycat type blade.
(See profile)
Weapon Power: S28-150 Magmotor.
Construction: 6082 T6 Ali, Nylon 6,
Armour: Grade 5 Ti.
Status: On drawing board / Mock-up model under construction.
Due date: Mid / Late 2005.
How will the blade sit ? vertically horizontallly ?
i guess horizontal, at that size anyway! knowing geoff it will be with a nice tilt forward aswell :sad:.
You read my mind Grant, yep, horizontal with a 10 degree tilt forward :)
quote
oh God no!
Humm... catchy
Nice
not windscreen wipers then
(See profile)
oh poo!
*faints
nice
Armour: Grade 5 Ti.
oh poo..... again
stay there please
Im taking up knitting instead.....
And everyone thought it was just the girls that were scary? :proud:
They still are :proud:!
Mr Stu
Of course we are my dear, but you aint scared of the flying saucers are you :wink:
No thats true - maybe thats your weapon, bring peolpe into a false sence of security with flying saucers then hurt them some way. Hmmm.
Mr Stu
looking evil geoff. You have mail by the way! well, you wil have in about 15 mins.
Still waiting...And its 15:37!! :)
sent it to teamscorpian@aol.com. I will resend if you havnt recieved it
oops, i know y, i put scorpian, not scorpion
silly me
....and heres a bit of shameless self promotion - same stuff as Geoff said above but this is to get you all in the mood
http://www.pillowtorque.com/coming.htmhttp://www.pillowtorque.com/coming.htm
Now THATS scary :proud:
Nah, Prancing Queen (http://www.hellfire-labs.s5.com/Prancing%20Queen.JPGhttp://www.hellfire-labs.s5.com/Prancing%20Queen.JPG) is far scarier :proud: Not by the specs, just the owners and their ideas :proud:
lol, i reckon vertical limits undressing the queen was rather disturbing :D
Cobra (rev *5*, wow theres alot of these..)
Speed: 18.5mph
Power: 2x cp2400scr 12v packs in series, hand made all the way
Drive: 2x 18v team delta dewalts at 24v with custom polyurethane wheels (80mm dia.)
Controller: IBC
Weapon: twin armed thwack hammer with 14mm aluminium scoop on the end
Armour: 6mm steel and 3mm steel lid and base
Frequency: 29.885MHz with a silvertone (http://www.silvertone.com.auwww.silvertone.com.au) military reciever
Status: in the build.
Notes: this one is *the shiz*, 56mm tall steel everwhere, totally welded, extreme drive
heres the design piccie along with the cad of kang (sawbot):
http://www.robowars.org/forum/album_pic.php?pic_id=711http://www.robowars.org/forum/album_pic.php?pic_id=711
Robot name: The DOMC
Power: 25.2v sanyo 2400 nicads
Drive: 14.4v drill motors @25.2 via additional chain reduction
Weapon: 330mm 8mm ali disk @6000rpm (ish, subject to change as we adjust gearing). steel teeth
Armour: all built from 8mm 6082 ali
Weight: should be 11.5Kg bu who knows
Status:building.
DragonStrike rebuild.
Power 12v 3300 nimh for drive.
Weapon power 12v 3300 nimh running EV Warrior.
Weapon 33cm long, 5.5cm wide, 6mm deep Titanium bar running at a 1 to 2 chain drive.
Armour 6mm Ali and 10mm polycarb.
BonX (aka Turbo Bonx) version 3
Speed: 12 / 35mph
Power: 2x 3000 NiMh 7,2v packs in series
Drive: 2x 12v Drillmotors with 1:2 gearing
Controller: IBC
Weapon: 3 kg thwack hammer
Armour: 10 mm ali base, 3 mm hardox armour
Notes: can change gearing on the go, topspeed is 35 mph, toprotation is 700 rpm
progress pic in profile
Tim I like the shape of the new BronX, stealthy and it looks very well built as well.
Samuel any pics of the new addition yet? sounds like another Mag spinner to add to the list.
And same question for you Tony, any pics yet? or is it looking same as it was before and how it is on your site.
Oh well good work guys and look fwd to meeting these bots in the arena sometime.
Chris - http://www.featherweights.org/forumBreak
No mag motor personly I dont see how you could put one in a 12kg bot and use it to its full potential. its ev powered with drills for drive. I have a design without motors or axle on my profile.
Same shape as before. Just changing the weapon to Ti and going to chain drive for the weapon.
All these robots just look awesome!
Oh right sorry Samuel, its just that you quoted 6000rpm for the disk and only a Mag motor could privide that off the bat.
So are you gearing up an Ev warrior then because on no load at 24v they only do 4480rpm and maybe a couple of rpm over that for 25.2v?
And while im online for anyone who is interested Ive started a collection of parts for my next project, picture on profile. Possibly not a featherweight!
The disk is geared up at the moment but I may drop to 1:1 (current plan is around (1:1.5), it depends on the losses in the bearings and the performance of the batteries.
For reference pimp 2 has a ev warrior at 1:2 @25.2v and we have measured it at over 8000rpm with a calibrated tacho. in theory this bot should be less powerfull than pimp 2 @1:2 but more powerfull than pimp 2 @ 1:5. Im going to try it geared up 150% and drop it if there are problems.
Hello all, I have a featherweight called cataclysm, see my profile for build pictures. Its my first bot, and has only been in one comp so far, beating last years Australian New South Wales champ (called Sorry) for its first match, then being flipped and stuck against the wall in its second by El Bravo.
Power: 2 x 12v cordless drill batteries
Drive: 2 x 12v cordless drill motors and gearboxes
Control: Servo microswitching
Weapon: Passive Wedges. Uses opponents spinning weapons against themselves through self-destruct.
Armour: 6mm mild steel bullbar and 4mm mild steel wedges
Status: Finished, with constant upgrades.
Just about to start to rebuild Tiamat. Getting a new hp ram from Mario 60 bore 75 stroke. Pic on profile.
50 bore, 50.
I shall introduce the toughest drumbot in Finland or probably the toughest one this side of the pond!
Name: HC (hardcore :P)
Drive: 2x 14.4v/550rpm drills at 12v with 76mm wheels.
Battery: 24v/3300mAh matched GP brand high-quality cells, 45A continuous.
Weapon: 24v dewalt spinning 4.3kg/165mm (365mm wide) drum at 2000rpm (can be 450rpm if needed due to safety) Teeth are 3.5mm thick mild steel and will be replaced with 8mm thick hardox 650 ones ASAP.
Frame: 8x50mm 6063 T-6 aluminium flat, 3/8 and 10mm polycarb.
Armor: 3.5mm aircraft alu baseplate and 4mm polycarb top.
Status: 13hr 18min to 3-2-1-GO!
(pic on profile) will post how it did in the event tomorrow.
Ive been following JH-Qs progress with this bot and it sure is nasty! Good luck with the event.
