Hardox doesn't come that thin it's 3mm minimum and even then you have to have a special agrement, you'll have to mill it to that thickness or get some Docol (same manufacturer) which comes in 0.5 to 3mm so you're not wasting material.
4mm is the easy stuff to come by. 3.2mm is a special arrangement. Any thinner would be pretty useless as a wear plate to industry so they don't make it.
where is a car scrapyard near Ipswich
google it
Breadfield
where about in breadfield alex?
can't remember, near the caterey?
OK next time I see you I'll ask you where it is.
http://maps.google.co.uk/maps?f=q&so...47198&t=h&z=10
The magic of the internet :proud:
I've got all the bits for the lifter (except the esc) but how would I control the motor? How would i wire it up?
My dad says that we use microswitches and make a bang-bang speed controller and at either end of the threaded rod
we have a limit switch that when the nut reaches the extent of its travel the motor cuts out to stop the motor ripping the lifter mechanism and itself apart.
We need to be able to control it so when the lifter reaches the extent of its travel the motor cut outs.
