Hardox has the same weight as steel, as it is a low alloy hi strength steel. 7.85kg/dm³
Thanks Mario.
Is it expensive to get hardox cut?
You can cut it with an angle grinder, so not really unless you want complex shapes. I made an axe head for Mayhem from hardox with nothing more than a grinder. Drilling can be hardwork, sharp drills are vital, once they are slightly blunt they need to be resharpened before using again. You can get away with it a bit more on ali but there is no chance with hardox. There are quite a few laser cutting places about these days, but they will be fairly expensive for one offs.
the axe head on mayhem is 4mm hardox and that was bent by hornet 2 so if you want something realy strong you would have to go thicker
Tut, these kids never look after the things you make for them. Matt do you need a new one or need it straightening? Ive still got the template.
Lol,yeah my axe head is quite a complex shape (same as THz) so maybe laser cutting is best.
I got a mate with a plasma cutter maybe he would do it....
Still havnt got a suitible axe arm,any suggestions on something thats easy to find?
ti bar or thick ali bar might do depending on what grade ali you use
ed its ok still fits in the arm lol big chunk out of it though:sad:
Ok,will I need one of these for my buffer as well as my main tank?
http://www.shop.justpaintball.co.uk/acatalog/Co2_On___Off_Valve.htmlhttp://www.shop.justpaintball.co.uk/...Off_Valve.html
And does this need to be accessible like a link is?
Thanks.
No.
You will however need a dump valve of some sort connected to the buffer.
Ok,thankyou Woody.
