Re: Mute
For batteries, I've had some luck with these in my new feather using 3 18v Dewalts-
http://www.hobbyking.com/hobbyking/stor ... _Pack.html
Capacity: 2650mAh
Voltage: 6S1P / 6S Cell / 22.2V
Discharge: 45C (119.25) Constant / 90C (238.5A) Burst
Weight: 427g (including wire, plug & case)
Dimensions: 135x44x33mm
Balance Plug: JST-XH
Discharge Plug: 4mm Bullet-connector
The packs seem to hold up very well.
Video of them in use can be seen at http://www.youtube.com/watch?v=H2lOjOWIr2Q
Re: Mute
cheers for the link will take a look at them, nice videos
Re: Mute
We have the pooooooowwwwwwwwwwwer, batteries finally turned up
Only problem now is should we go with 4 packs @ 33volt or 5 packs @ 26.4volt, guess it comes down to either longer battery life or Mute going at silly speed, guess 33volts might be fun.
http://i150.photobucket.com/albums/s...2206/batts.jpg
Re: Mute
Go for the lower voltage. You just can't use the speed unless you are in a car park.
Re: Mute
Re: Mute
I suppose the faster you go, the quicker Adam can drive it in the pit! I would play safe and go 24volts, but then again... :proud:
Re: Mute
LEM 130's . 75A continous power.
Theoretical stall 1100A+ (26.4 Kw of heat, glow in the dark motors) @24V.
138 rpm/V
Those LiFePo4 cells of 2650 mAh, 60A cont, 120A burst
Depending on gearratio and wheelsize... But lets take an old school UK drivetrain. 8 wheels 6-1 gearratio.
@ 8S = 22 km/h 5P = 13.5 Ah 300A cont, 600A burst
@10S= 28 km/h 4P= 10.6 AH 240A cont, 480A burst.
I would even think of dropping to 6S. Still a good speed 17 km/h , with 5P you have 10 cells in spare then.
Re: Mute
Mute rebuild is still going good, currently sitting at 94kg with both bottles full and just batteries and wires to go in, getting close to having a working bot again :)
http://i150.photobucket.com/albums/s...uteRebuild.jpg
Speedo ended up under the side pot, we were just a little short on space for it to fit into centre section
http://i150.photobucket.com/albums/s...uteRebuld1.jpg
Flipper and gas system all fitted back in
Re: Mute
Finally, another front hinged flipper is back
looks so tidy inside, are you still having the rear flippers?
Re: Mute
Yep still got the rear flipper too, the angle bracket at the back holds mute rear valve for the back flipper.
Will get a bit fully with the motor wires etc but not to much.
You should have seen the orginal gas system with hydraulic valves, the whole rear of mute was full, if we dropped a pin in never saw it for weeks until we stripped stuff out.
Below picture was with bits stripped out and the orange lump was the original gas tank, no were near the 4kg we carry now
http://www.team-mute.co.uk/images/gas%202.jpg
