Typhoon 2 used a 1000A military grade connector that retails around the £1000 mark (probably more with inflation and brexit in the decade and a bit since). But failing something like that, your other options should handle more than enough current. If you are drawing 600A in any continuous fashion then I would expect either your fuses to pop on the lipo or your wiring to melt.
