http://www.ebay.com/itm/New-Paintbal...item5b035321c4
There you go, at 19$ if that ain't cheap then I don't know what is! ;)
I prefer a Co2 fire extinguisher as a supply tank, once it empty I give it back to the supplier and he just refills it.
Yup ok
I will get the things then will update this thread, thanks
Okay, i bought the tank( it weights 1300g non filled and 1700g filled), made of steel, and has testing pressure rated at 250bar, bought from a soda machine vender for 5$(pretty cheap)
so 400g of co2.
Now any modifications i need to do?
Wow! So you're building a 6kg robot and get yourself a 1.7kg tank! As I previously explained, you don't need a tank that big/heavy, a 1/2 kg of liq co2 will last a lifetime for the size of ram you plan to use. Also as I have already told you, the thread on a soda bottle is unusable, you need an adaptor like this:
http://www.ebay.com/itm/Sodastream-B...-/161034825292
which will cost you more...in the end, it would have been cheaper, better, lighter, smaller to get a 9oz paintball tank!
haha no i dont have to buy that, I think I will get some welding done for the fitting I need...
In india we have to make the stuff ourselves, not everything is available here
if i change the valve of the soda cylinder, will it be fine?
maybe i would replace it with the fire extinguisher one, or maybe the paintball one?
I dont know, never used or disassembled a soda bottle, maybe someone else who did could give you some advice. But I strongly advice you against:Quote:
ohk, i will get some fitting then ( if you dont recommend me getting it welded)
I have one of those soda cylinders and the thread on the bottle differs from manufacturer to manufacturer.
So it's not simply a matter of screwing a different valve into it (Which was my wish).
Perhaps to person who sold it to you can help you out with your questions and parts.
the threading in mine one dosnt seem any special, its normal .. i also have some fitting for it, which cud help? also the pin valve is very difficult to press with fingers(impossible) , so will it be any trouble?
i will upload a pic
