Re: Bitza Mk2
Trying to wire up this Relay, could do with a little advice:
http://www.electronicnetwork.ca/media/d ... u/sarl.pdf
It's unclear which side is the load side, I'm assuming 30 and 87 (for the motor) and 86 and 85 for the switch.
I'm also assuming it's polarity sensitive but which poles are which is also unclear.....
Thanks!
Re: Bitza Mk2
If its the same as my relay then you are right 85 and 86 are for the switch and 30 and 87 are for the motor. Mine isn't polarity sensitive but we may have just been lucky. Doesnt yours have a wiring diagram on the side?
Re: Bitza Mk2
Yes, but that's not massively clear either. I'll just press batteries to it until I hear it switching.
Re: Bitza Mk2
Word of warning it takes 12v to switch that relay (or mine at least) unlike the 100A one you had on Saturday which you may have been running off your bec
Re: Bitza Mk2
Thanks for the heads up.
Yeh the relay in Bitza can switch on as little as 3v, but the one in BitzaWood (Same as yours) requires 12v!
Also my switches require a common ground, so what ever I'm running the bot on will be the switching voltage. Means I can leave the BEC to just worry about the radio side.
Re: Bitza Mk2
So thought I'd do a quick event breakdown of how Team Bitza got on. This is probably more for our benefit and will be a load of text, but I'll put up some more build photos and vids soon.
In short the robots all performed pretty badly. Spinza never even got started on, let alone finished in time.
BitzaWood was structurally sound, and half wired up, but in our attempts to finish the job at the GSL we managed to wire the weapon motor the wrong way so it span down. Reversing the polarity broke the relay, which by this point was the one out of Bitza since I was unsure of how to wire the one I had in BitzaWood originally.
As for BitzaMk2, well we just ran out of time and it had some quite major issues to iron out. The weight being the main one, meaning we could either run was armour or weapon. Given the first fight against Cobalt armour seemed sound, and we took no damage, but I suspect Kenny held back a bit. Then DoorStop was replaced with LH, so quickly put the armour back on for the 2nd round too.
By this point it was very apparent we had a major problem, no traction. There was too much weight over the front of the robot so the wheels just span beneath us.
For the final fight we put the drum on. But a combination of an additional 3.2kgs over the front and the gyro force meant it didn't drive at all.
Pretty pleased with the drum, spins up very quickly, good RPM it was only when we drove into the wall that we sheared the bolts holding one tooth on, and then the vibration meant we slipped the chain and the drive axle worked loose. Still got a knockout though!
As for the next model, shorter and wider, with more weight over the drive axle. Thinking we may ditch the exoskeleton design. We like being different and it's very strong but difficult to work with, hard to mount anything and heavy. So we'll be looking at a base plate or bulkhead design.
Things worth keeping? The drum seemed sound, just need bigger bolts in the teeth. The car fan motor provided more than enough power to spin it up and didn't draw much current. The one way bearing worked well as did the chain. We think it slipped because it stretched so far.
Our 15a Electronize controllers got rather warm but still working so happy to keep them, same with the dewalt drive motors and gearboxes.
2 Attachment(s)
Re: Bitza Mk2
Just worked out something interesting. In turning this old weight into the sprocket guard I left roughly 51 of it's original 56 lbs on the lathe bed!
No wonder it took 12 hours to turn!
[attachment=1:2na1njra]Photo-0014.jpg[/attachment:2na1njra]
[attachment=0:2na1njra]DrumGuardMockup.jpg[/attachment:2na1njra]
Re: Bitza Mk2
That's a whole lot of swarf!
Re: Bitza Mk2
Re: Bitza Mk2
Can't remember if I did a 2012 Champs PM..... So here is a slightly belated one...
As many of you saw BitzaMk2 had a couple of serious problems. Namely being overweight, which we are working on, but secondly it didn't drive.... Like at all....
You can see the problem briefly in this clip:
http://www.youtube.com/watch?v=R6aOt...tailpage#t=73s
The wheels seem to gain and lose traction intermittently making it impossible to drive. We initially put it down to the wet floor outside (and the dusty floor when inside) but we had the same problem at the champs, and with the drum on it was even worse!
I have an idea why this is, and some thought about how we can solve it, but thought I'd open it up to the forum first to see if there's anything obvious I've missed and for some more experienced insight.
