Or you could just steal another realie:
Miss Struts
Stomp
Mammoth
Anorachnid
Miss Struts
Stomp
Mammoth
Anorachnid
How about no.
Stomp and Anarachnid werent true walkers as far as I know.
What about if I had a walking-system like Clawed Hopper and Gammatron had? With the two rims that made them skip across the arena? Not sure if you count that as a walker, but it is to me.
Its you that steals realies Mark, not Chris!
Ignore Mark. Any advice on a walker?
The Gammatron system wouldnt count either, as I recall it ran off a continuous rotary motion, and it violates the rule on each leg having multi-axis movement...although obviously its up to the tournament writes what theyll accept.
I think the only true walkers there have been are Mechadon and Miss Struts, out of the ones that have been on TV anyway. I was going to design a walker myself, basically a 200kg hardox brick with no weapons...
What did Arnarchy use? That was effective.
Am I dreaming or did some walkers use linear actuators?
Jeroen, who also made Tough as Nails also made a 6 legged walker with linear actuators. It was very slow though and was never ment for robot combat.
Mechadon from team Sinister is probably the best example of a true walker that is linear actuated.
Ive made some changes to a few of my vapours,
Systematic Shocker previously System Shock
Shape: Invertible box
Weight: 110kg with setups 1, 2 and 3, 100kg with setup 4
Dimensions: 80 x 100 x 30
Motivation: 2 x steel tank tracks
Power: 2 x B42-500 magmotors running at 60v, gives 60HP
Armour: 4mm hardox, skirts are 5mm titanium
Weaponry: Interchangeable:
1)3mm hardox front scoop which can lift 200kg, powered by 1 x LEM-130 at 36v.
2)3mm hardox horizontal spinning disc (50 x 50) powered by 1 x LEM-130 at 36v. Approx. 30Kj hit
3)2 x 30cm long tungsten tipped hardox lifting spikes, powered by 1 x LEM-130 at 36v, can lift up and down to work both ways up.
4)The scoop from setup one, but static. This gets the weight down to 100kg and gets around any 100kg for tracks rules.
Top Speed: 15mph
Ground Clearance: Effectively 0 due to scoop and skirts, 8mm behind them
Turning Circle: 0
Srimech: Invertible
Colour: Red with the name painted on top in green.
Strengths: Interchangeable weaponry, loads of HP
Weaknesses: Tracks exposed from above.
Henry VIII
Shape: Box, slightly arched from the side (like Ally Gator from RW3 if you don€™t get it), with sloped sides
Weight: 100kg
Dimensions: 85 x 85 x 20
Motivation: 4 x vulkalon tyres
Power: 4 x S28-400 magmotors running at 24v, 24HP
Armour: 4mm thick hardox on top and sides, 3mm hi-grade 7075 aluminium base
Weaponry: Tungsten tipped double-headed hardox axe on a rack and pinion system, powered by co2 at 750psi, can hit robots at the back and front due to it being hinged in the middle and being 60cm in length, also has a 3mm titanium static scoop at the front to get underneath other robots.
Top Speed: 20mph
Ground Clearance: Effectively 0 at front due to scoop, 8mm behind the scoop and on sides and rear
Turning Circle: 0
Srimech: The axe will easily right the robot quickly, no matter what position it is at.
Colour: Black, red axe head, name painted in red on the scoop
Strengths: Marital experience, quick Srimech, powerful weaponry
Weaknesses: Base armour is fairly weak, but it is hard to hit anyway as the Srimech is fast.
Hatchet
Shape: Invertible box with stiff tail
Weight: 100kg
Dimensions: 60 x 60 x 20
Motivation: 2 x go-kart wheels
Power: 2 x B42-500s at 60v, provides 60HP
Armour: 5mm hardox
Weaponry: 4mm hardox front scoop, 50cm long 3cm wide hardox tail with two tungsten tipped spikes facing in opposite directions (T shaped), when the robot spins this can deliver a 65Kj blow.
Top Speed: 25mph
Ground Clearance: Effectively 0 at front due to scoop, 8mm behind and everywhere else
Turning Circle: 0
Srimech: Invertible
Colour: Gold with name painted in red on top
Strengths: Lots of HP, strong armour
Weaknesses: Can only spin on the spot
Beta-Rex (previously Alpha-Rex)
Shape: Reverse wedge with rounded sides
Weight: 100kg
Dimensions: 95 x 90 x 35
Power: 2 x B42-500s running at 60v, provides 60HP
Armour: 6mm titanium flipper, 4mm hardox front, sides and top, 4mm hi-grade 7075 aluminium base
Weaponry: 1000psi nitrogen flipper with 1 x 100mm ram, 2 x 3kg bottles provide the power. The flipper is T-Minus style, but the arm goes down the wedge allowing it to act as a front hinged flipper from the rear. 1600kg of flipping force!
Top Speed: 25mph
Ground Clearance: Effectively 0 at front and back (flipper and wedge), 8mm on the sides behind the 5mm titanium skirts which make it effectively 0
Turning Circle: 0
Srimech: The flipper can perform a 540 degree spin, and the sides are rounded to prevent beaching
Colour: Gold
Notes: €œMWA-HA-HA-HA-HA!€ written on the bottom- one more HA than there was on Alpha-Rex
Strengths: Lots of HP, powerful flipper, can flip from front and rear
Weaknesses: Base armour could be stronger
Other Weights:
SLAM! (SHW)
Shape: Box wedge with an inverted wedge on the rear
Weight: 154kg
Dimensions: 100 x 100 x 35
Motivation: 6 x go-kart wheels
Power: 4 x B42-500s at 60v, 120HP!
Armour: 6mm hardox top and base, 4mm hardox, front, rear, sides and skirts.
Weaponry: Full Body Hammer
Top Speed: 30mph
Ground Clearance: Effectively 0 at front and sides due to skirts and wedge, 10mm on rear and 6mm behind skirts/wedge
Turning Circle: 0
Srimech: Invertible
Colour: Black with the name painted in white on top
Notes: Built specially for Battlebots: Beyond the Battlebox
Strengths: TONNES of HP
Weaknesses: Could be stacked, no active weaponry means it won€™t get past the passive weaponry rule
El Media Diablo (MW)
Shape: Like Chaos 2, but smaller
Weight: 50kg
Dimensions: 45 x 30 x 25
Motivation: 2 x go-kart wheels and 2 x casters at the rear
Power: 2 x S28-400 magmotors at 18v, 8HP
Armour: 4mm hardox front and rear/ top, 3mm on sides and 4mm hi-grade 7075 aluminium base
Weaponry: Co2 flipper, 750psi powered by a single 75mm ram, 1 x 3kg bottle, can flip about 800kg
Top Speed: 10mph
Ground Clearance: 8mm on sides, 4mm on rear, effectively 0 at front due to flipper
Turning Circle: 0
Srimech: The flipper will easily spring the robot back onto its wheels
Colour: Black
Notes: If I ever want a heavyweight cluster bot I can duplicate this one to become Dos Diablos. If I want a super heavyweight cluster bot there can be three/four of these depending on the rules.
Strengths: Powerful flipper for middleweights
Weaknesses: Drive slightly under-powered
Titanium Titan V2 (LW)
Shape: Box wedge
Weight: 27kg
Dimensions: 25 x 25 x 25
Power: 2 x S28-400 magmotors running at 12v, 6HP
Armour: 5mm thick titanium skirts, top and sides, 3mm titanium base
Weaponry: Bio-Hazard style lifting arm, powered by an S28-400 magmotor at 24v
Top Speed: 20mph
Ground Clearance: Effectively 0 at front due to wedge, sides due to skirts, 6mm behind those and at the rear
Turning Circle: 0
Srimech: The arm can right the robot as there are no rear skirts
Strengths: Pretty fast with a decent weapon
Weaknesses: No damaging weaponry
