Re: UK Kilobots - 1.362kg (3 lbs) Combat Robots
Surely you shouldn't be using push fits if it's at full pressure?
After the valve isnt pressurised
Did you custom build the cylinder or is it a off the shelf part? Looks custom but I may be wrong
Ye its custom, its a mini version of the Flow and Diablo rams
Sorry I'm probably being stupid but isn't it all pressurised when the ram is fired? Or is it that it's only pressurised for a short amount of time so it's ok?
Ye there is a vent hole (exaust) in bottom of ram so it vents before it reaches high pressure, this was only for testing high pressure ones will be used on final build. we do not recommend using 10bar fittings on a system like this as they can still blow
Here is a photo I took last night, Its a crappy photo but it just shows a bit of size differance
http://i1084.photobucket.com/albums/...e/bd2cd937.jpg
You guys never fail to amaze me with what you can achieve, looks fantastic :)
Mount for the self righting servo for 180
[attachment=0:3odceqz9]469207_10151704524930173_673470172_24287816_138236 0071_o.jpg[/attachment:3odceqz9]
