How Could I Improve...
My opinion doesnt count for much ,but if I were you Id stop powering lifters with S28-400s and use LEM-130s instead. And you may as well make Armory invertable if the wheels are external.
Ive never heard of astro-flights, maybe someone else has?
Also Tenderizer needs psi for the co2. How much do you plan to run it on? And dont expect your armour on Armory and Tenderizer to be OK if they come against spinners.
(Message edited by Robot_Warrior on April 24, 2008)
Corsairs Srimech: An electric lifting arm, built into the back of the robot, powered by a 24V LEM-130.
I have, for featherweights.
Didnt Biohazard use astro-flights?
Or that american cage spinner
BioHazard 96 to 99 used two permanent magnet DC motors that Carlo ordered from a surplus dealer. BioHazard 2000-2003 uses the S28-400 Magmotors.
There was an middleweight in Robotica I believe that used Astros for drive. Either way, I would not use them in a heavy unless you use a lot of them (2-3 per wheel or so).
if thats the case,
Power: 4x S28-400 Magmotors powered by 5x NiCad Battlepacks.
Tenderizers hammer runs on 210psi Co2.
Mark, you might want to rethink the ground clearance on some of them...Tenderiser for example. I dont see how Hells Teeths shape automatically gives it 0 ground clearance all around, and with 0 all around you wont move anyway.
OK,
Ground Clearance: The shape gives the back half 0mm ground clearance, and the front half 5mm ground clearance.
