Damn, there goes my side defenses :proud:
At the start I will wait for Frankys attack, then dodge his attack, get under, smash with axe, pit, drink coffee
Oh well in that case Ill just change my tactics to Spin up, kill. Still reverse at the start though so I can spin up.
Another change of tactics, Im using the 3rd weapon setup, the flipper.
Drive forward at the start, get the flipper in the ready position, and wait until Franky attacks, then I will use a lovely collection of dodges, anti-dodges and the very rare anti-anti-Dodge which I brought from a spotty teenage on ebay for £20 :proud:. Once underneath Franks machine, get the front flipper underneath, and push towards pit, and then flip down the pit.
Will National Speed Limit Applies win its third fight and keep the Belt forever? Or will NSBFR-X take it away?
3, 2, 1 - ACTIVATE!
NSA came forward, quickly bringing its flipper into a operable position, while NSBFR-X reversed and turned right to get its spinning bar spinning! NSA stopped and waited for NSBFR-X to come in, before doing a neat little swerve that resulted in NSBFR-X charging past it! Turning, NSA went to drive its flipper under the skirts of its opponent, but it ended up going into the corner and NSBFR-X was able to escape and graze NSA along the side! It went to strike the Belt Holder in the rear, but NSA outran it, before turning around, advancing again and suddenly dodging NSBFR-Xs attack! However, NSBFR-X was again able to avoid an assault from the flipper, and hit NSA on its other side! As the two robots ended up parallel to each other, NSA took another blow from the bar, slicing its side armour! However, it reversed as NSBFR-X tried to attack again, and was able to rush into its opponents side, and shove against the skirting! The two robots turned around in a circle, until NSAs straining paid off, and the low flipper slipped under the hinged skirts! Coming underneath NSBFR-X and able to gain control, NSA went speeding into the pit release, then twisted around successfully, rushed NSBFR-X to the open pit and flipped it in with a flourish! National Speed Limit Applies now had a VFT Challenge Belt to call its own, forever!
CEASE!
NATIONAL SPEED LIMIT APPLIES KEEPS THE BELT, AND GETS A SECOND ONE FOR THE LAST MATCH!
Last VFT6 Challenge Belt Battle:
National Speed Limit Applies (Holder) vs Wedga Revo (Challenger)
Keep driving in at it over and over and try to pit it. If I use the flipper for self righting use, it should go down to pushing where I think I win. Failing to shove it, Ill try to flip and pin it down or push it about inverted.
Woo :)
Against Wedga Revo, one of the most perfect robots off all time, do I have any hope???
Normal blade, slam into it, try to get under, slam with the blade, push into pit?
Whoever wins the final VFT6 Challenge Belt battle wont have secured it, but will need to fight for it twice more next time! But will that winner be National Speed Limit Applies, or Wedga Revo?
3, 2, 1 - ACTIVATE!
Both robots came rushing out of their starting posts and slammed into each other head on! They strained to get underneath each other, their low scoops counteracting each others efforts! Eventually, Wedga Revo broke away from the stalemate, turning on the spot and finding itself parallel to NSA! Wedga Revo fired its flipper, but missed, as NSA reversed away just in time! The Belt Holder then ran into Wedga Revo from behind, and as Wedga turned to try and catch it, NSA went into its side! Giving Wedga a good shove on a curving path, NSA found it hard to get past the skirts, but brought its blade down into the titanium top and caused a sickening gouge! The two robots struggled with each other in this way, until AJ had the idea of firing his flipper under the blades attachments! The arm successfully lifted the rods, and NSA went into the air and rolled onto its back! With its srimech arm, NSA began turning itself over right away, but before it could do so and bring its vacuum into play, Wedga Revo gave it another toss with the flipping arm, sending onto its back again, when it could be neatly shoved against the wall! Wanting to get the fight over with quickly just as NSA had done with its previous opponents, Wedga Revo began racing NSA towards the pit release! NSA could still use its srimech, however, and began rolling itself off the wedge, but reacting quickly, Wedga fired its flipper and sent NSA cock-eyed into the air, then got under again and rammed it hard into the pit release! A few seconds later, National Speed Limit Applies was being flipped into the pit, bouncing off the edge and sliding in - while it already had one Belt, it now wouldnt get to keep the second one!
CEASE!
WEDGA REVO TAKES THE BELT FROM NATIONAL SPEED LIMIT APPLIES!
So in VFT7, therell be some more Challenge Belt fights, and Wedga Revo (or another Wedga robot) will be the Holder, needing to defend the Belt twice to keep it!
Next time on VFT6, its our second All Stars tournament! Taking into account performances in VFT5 and 6, here are our sixteen competitors!
*ACHILLES, by Alex Holt, top 16 in VFT6!
*FIRESTORM V, quarter finalist in VFT2 and top 16 in VFT6!
*FLIPPING MAD TU, by Dave Sheppard, top 16 in VFT4 and VFT5!
*GIGAVIRUS, by Nick, came 2nd in VFT4 and is our current All Stars champion!
*HYPERTENSION MK2, by Matty Fowler, will be in the top 4 of VFT6!
*MANIC MONSOON, by Daniel Strickler, came 3rd in VFT5 and top 8 in VFT6!
*MASS DISCTRUCTION ULTIMATE 3.1, by Aaron Knight, champ of VFT3 and VFT4!
*MAXIMUM VELOCITY, by Scott Anderson, came 3rd in VFT4!
*ORKA MK3, by Chris Mason, top 16 in VFT6!
*SD IV, by Steven MacGregor, came 2nd in VFT1, 4th in VFT2, top 12 in VFT3, and top 8 in VFT5! (In case youre wondering, Steve, I did consider Wedge Devolution, but SD IVs record just beat it.)
*SOR 4.0, by Andy Jackson, champ of VFT1 and top 8 in VFT4!
*STORM 2, will be in the top 4 of VFT6!
*SV IV, by Tom Roper, came 3rd in VFT1, 2nd in VFT2, top 8 in VFT3 and top 16 in VFT4!
*THE DISC 4, by Frank Goacher, champ of VFT5!
*THE ROBOT THAT WASNT THERE, by Hector Gilbert, came 3rd in VFT3!
*WHEELY BIG CHEESE, came 4th in VFT1!
And heres the lineup:
Mass Disctruction Ultimate 3.1 vs SD IV vs SOR 4.0 vs Wheely Big Cheese
Achilles vs Firestorm V vs Maximum Velocity vs The Robot That Wasnt There
Gigavirus vs Hypertension Mk2 vs Orka Mk3 vs Storm 2
Flipping Mad TU vs Manic Monsoon vs SvIV vs The Disc 4
As in the last All Stars, two robots go through from each melee, and its one-on-one from there.
Sorry about the most recent fights being a bit short, but Dave and AJ seemed to want to get their opponents in the pit once they had control, which is what happened. The upcoming melees should be longer.
Wooo! Nice battle Richard and Dave. Nice to know there might be a VFT7 too! :)
Am I right in thinking me and Steve are teaming up in this fight?
Im first going to try and take the wheels of WBC with the spinner, which should leave me the rest of the time to try and get MDU out. The only thing I can thing of is suicidal rams and try to get a few flips and slashes in too. Although I could try pushing WBC into it instead... :proud:
To sum it up, I havent got a clue what to do in this battle. :P
Fights dont have to be long just for the sake of being long yknow. Good fights anyway.
Ill go after SDIV, then either of the other two. Anyone fancy a team up?
Nothings definite, AJ, but odds are there will be a VFT7, as I should have Internet access and enough time on my hands. But if I dont have enough time for a big tournament, I may be able to do a smaller one where I will include more Challenge Belt battles.
