Velociraptors Fanfic Tournament - Series 6!
Woot :)
Good fight Matty
*Goes off to find stats of Ankle Biter*
The simple tactic will be to Box Rush it at the start, where I cant see any kind of wedge/skirt device to stop me getting underneath. Once under, bring down the gillotine, straight down, to get a grip. The weapon shouldnt be able to hit anything on me, and the same tactic will apply as the other fight, drive into pit release, open pit, dump into pit.
Good Luck Matt :)
National Speed Limit Applies now has the Belt, and theres still enough time for it to win enough fights to keep it! But the same can be said of Ankle Biter The Second, if it takes the Belt in this battle!
3, 2, 1 - ACTIVATE!
The Belt Holder charged straight at Ankle Biter The Second, whose drum began to rotate! It seemed they would meet head on, but Ankle Biter turned to use its drum on the sides! However, NSA reacted quickly and turned into Ankle Biter! The result was that Ankle Biter ran up the side of NSAs wedge - NSA fired its guillotine at the wrong moment and the blade completely missed Ankle Biter, but the long bit pinned Ankle Biters rear against the wedge! This wasnt a very secure position, so NSA released and reversed, leaving Ankle Biter The Second balancing on its side! NSA considered leaving it stuck like that, but the forces of the drum were causing Ankle Biter to begin rocking a little! NSA gave it a nudge, and it fell back to the floor, but had no time to get away before the guillotine buried itself in its top! NSA found it had an easier job than the last fight of dragging its opponent to the pit release, then moving it over the pit, releasing the guillotine and letting Ankle Biter The Second drop away, with no Belt to show for its efforts!
CEASE!
NATIONAL SPEED LIMIT APPLIES DEFENDS THE BELT!
Next Challenge Belt Battle:
National Speed Limit Applies (Holder) vs NSBFR-X (Challenger)
Woot :)
Ah, I got Mr. Franks machine, so I will allow Franky to post his tactics first mainly because he has a set-up to choice.
Can I see stats for National Speed Limit Aplies please? Im not digging through all those archives for em.
2nd page frank, about mid-way down, but because you believe in the imporatance of being idle...
...quote:
Shorten Name - NSA
Mass - 100 kg
Weapons - The main weapon is a guillotine, this is powered by two ex-hydraulic 80mm rams on nitrogen gas, via a rack and pin system. The gas enters at 1000 psi, which gives this weapon some kick. To protect itself on the way back, some of the gas that was used to fire the weapon is sorted into a buffer tank, which when it is used to redraw the guillotine (gets about 50 psi max). To stop the robot from hopping around, a series of electromagnets are used to attach the robot to the floor when firing the weapon. If a wooden floor is used, the electromagnets are replaced by a heavy-duty vacuum cleaner, which sucks the robot to the floor with about 2.5 Mega Newtons of force. The blade itself can be replaced for two axe heads, which fire both at the same time.
The blade is a simple, straight, but thin (less than 1mm), which could in theory hit other robots at a velocity close to 100 mph, which should cut into armour. On the other hand a secondary blade can be used, which has a diamond coated edge. Used against titanium robots. The third blade is not a blade at all, but a flipper style piece of steel, which comes over the rear. See the picture as it is hard to explain. (Ask for picture if you need it)
The entire weapon system is designed to move within it€™s own free will. To stop it taking off, thick rubber blocks are used around all contact points to stop damage via shaking. In total, we have a finite number of fights, but with 4kg of nitrogen, it is around 50-60 fires, enough to destroy the toughest arena wall.
Srimech - It uses a simple arm to self-right it other the left-hand side. The arm is electric powered
Drive - Four Bosch 750€™s, each at 36 volts, each with a variable gearing system. 1:1, 8:1 or 17.5:1. The drive itself is belt. The front two wheels and rear two wheels are joined by a €œsecondary drive shaft€ which means if one of the motors fail, the power from the opposite motor can be used to turn the shaft, meaning that it will still be 4 wheel drives.
Velocity - 10 mph, 24 mph. We normally use the 24 mph for fights, and 10 mph for pushing. The 1:1 gearing is only used to run away from areas, as it reaches the speed limit of 60 mph, but it is very hard to control, and normally it means ramming into the wall to stop. It has no torque at 1:1.
Acceleration - The 10 mph is within 1 metre of moment, the 24 mph is within 3 metres of moment. The 60 mph is within 5 metres, but we don€™t use this much.
Turning Circle - Dead Zero
Ground clearance - Zero at front, with lifting scoop. 1 cm around sides and rear, enough to stop low spinners getting underneath.
Wheel Type - 4, simple aluminium wheels with dry go-kart tyre nailed onto the aluminium. Solid and light.
Body Shape - Low Wedge, curved sides, and rear.
Armour - Rubbish in comparison, 3mm sides, with 5mm top and bottom. The armour itself, RSP-707 TG off course :-O. The front scoop is 7mm RSP-707 TG, and can lift up to aid moments.
Colour - Unpainted for the light-weight look.
Summary - Low wedge, damaging weapon, cool name, good driver, good turner. Hopefully it will do well. The weapon is designed to eat into arena walls and floors.
Strengths - Control at low speeds, unflappable when held down with electromagnets or vacuum.
Weaknesses - Control at high speeds, has a habit of jumping around when weapon fires if not held down.
^First time I seen these since Frank decided it didnt have a srimech :proud:^
Oh, that thing. Use the spinning bar and knock it around. If he doesnt use the sucky thing/magnets then hell be spun around and unable to attack, and if he does use them hell have no way of harmlessly dispersing the kinetic energy and take a lot of internal damage. Also seeing the blade is 1 MM thin, itll probably distort when it hits anything.
quote:
Oh, that thing.
Im happy you can remember it :proud:
Your assuming one tiny thing Franky...
...that Im using the blade. Axes again please Richard.
Can I stick a line of coffee mugs around the outside of my robot, just for the fun of it :proud:?
I am slighty faster than Franks machine, so at the start, I will box-rush it once more, and see whom gets under whom, if I get under, slam hard down with the axes, like Mortis to put the top of CSBFR-X full of holes, which should damage something in side, allowing me to push it down the pit.
If Frank gets underneath me, then my front wedge should take the blow from the blade, and I will drive up and over the top of CSBFR-X or if this fails, fire both axes at once to hop off.
So recap - Box rush, get under, hit numberous times with axes, pit, eat pie and drink a mug of coffee from one of the mugs on the side of NSA, surly Frank wont destroy mugs and pots of coffee???
Have fun box rushing a bar that spins up in a couple of seconds. Anyway, big blade or axes, it doesnt make much difference, you still need to suck it down somehow so my tactics still apply.
Sorry Dave, but coffee mugs can shatter.
Dave, you are also underestimating my prowess at coffee drinkage. Youll find those mugs and pots are already emptry, and therefore no defence:wink:
Also, Ill reverse and turn right at the start to make box rushing harder. Might also give me a free shot at the side as well.
