42 is the answer to everything
Yes, but what is the answer to the ultimate question for everything: 6 x 9? :proud:
(dont you dare answer with 54! :proud:)
Just look at The Hitchhikers Guide To The Galaxy :mrgreen:
Its not the answer to several questions, though...like How many bags of free money do you want, sir? or How many inches do you want to be away from Joey when he stands on this landmine?
42 is the answer to How many miles do you want the landmine to be away from yourself and Joey? :wink:
I could throw it :P
Hurricane
Shape- Cylinder
Weight- 120kg
Dimensions- 87 X 87 X 30
Mobility: 4 X Shuffling Pads
Power: 5 X 24v NiCad BattlePacks
GC: 3mm
TC: Guess.
Speed: 15 mph
Armour: 6mm Titanium
Weapon: 32kg Spinning Ring with 8 Pussycat-style blades powered by a LEM-170 spinning at 1500RPM
Srimech: Invertible
Strengths: Devastating Weapon, Able to rip through any armour, 1-hit KO, and extremely good pushing power
Weaknesses: Crushers and Axes
Howz that?
I highly doubt itd be able to rip through every single type of armour...a Kj count would help, and keep in mind spinners are better with blunter teeth for shock damage, otherwise yo have a very nice yet useless giant circular saw...
And what motors does it have on the drive?
EDIT: ...666th post...*puts on AC/DC* :proud:
(Message edited by joeychevron on April 15, 2008)
Got an email from the Killertron team. They said I could build a new Killertron in the vapourbot world.
Killertron Mach 2
Weight: 100kg
Shape: Killertron from Extreme 1
Dimensions: 100cm x 60cm x 0-30cm
Motivation: 6 Vulkalon wheels
Power: 2 S28-400 Magmotors powering the middle wheels. The motors are powered by 4 NiCad battlepacks.
Ground Clearance: 0mm at front due to scoop, and 0mm at sides and back due to skirts.
Speed: 21mph
Turning Circle: 0m
Weapon: The team have switched from the geared pickaxe to a new Terrorhurtz style pneumatic system at 210psi. about 3 1kg Co2 bottles power a large ram which gives the pickaxe about 1.5 tonnes of power, while the old pickaxe had only 1 tonne.
Armour: 4mm Hardox
Notes: Components are shock-mounted to reduce shock damage. Hopefully this Killertron will have the performance that the Series 2 Killertron had.
Srimech: The Pickaxe
(Message edited by corsair_lightning on April 15, 2008)
Riiiiight.Suuuuuuuuure they did
